Projects 1941 Oldsmobile 98 Coupe Custom
Discussion in 'The Hokey Ass Message Board' started by speters, Aug 30, 2011.
  1. speters
    speters
  2. speters
    speters
    Sold the Olds to another HAMBer!
  3. csimonds
    csimonds
    MINT! Good for you man. Are you going to the swap meet on Sunday at the Lake?
    Chuck
  4. speters
    speters
    I want to. Do you think they will still have it?
  5. csimonds
    csimonds
    Yes they will have it! Rain or snow
  6. StLouisSled
    StLouisSled
    "Decided to chrome paint it since I got tired of looking at all that black"
    For paint that looks good....what brand of paint did you use. I got a 51 Olds coupe I'd like to shoot the bumpers with until I can afford chrome.
  7. speters
    speters
    That was Rust-Oleum Metallic Chrome paint I picked up at the local Autozone
  8. looks like I am the other hamber so i will take over this thread and continue it
    bought a lot of parts including a polished intake, new grill with a finish on it! and just got a narower track width 9 in Ford rear end housing
    been waiting on doing anything as I have this in a chop contest and hopeing I will win
    I put in temp and oil press gauge and found it had hardly any oil press when hot so if i win chop will switch to another engine and drive this fall
    a friend is giving me another 455
    I am going to pull out a really hot 350 chev and install with a 700 OD and put in air cond when i start. I dont think i can stand the can of worms of putting money in a olds engine
    my last winter show car $ losses on ISCA almost wiped me out on $$
    I also found out the the brake petal is below the accelerator so I got a fast ride through a stop sign so that needs some work
    got a set of 4 bar flippers for front and a set of steel bubble skirts for the rear
    I sure am happy about others working on buicks just like this so i can get inspiration on the HAMB:D
  9. cowboy1
    cowboy1
    from Austin TX
    Can't wait to see more of the build.
  10. lost the chop contest to a 11 year old kid
    been paying insurance and got tags on this so i took it to town and did some gravel damage on the trip in to bottom edges
    had flush in this all summer and rad seems to be 50 degreee diference in top to bottom so that may be good
    dwell was 10 degrees off and run poor, fixed dwell and changed timing to try to get it to run cooler,
    but the water pump is squirting water all over the place and i dont want to spend for a new pump being i am going to a SBC engine reason being i drive all over the usa and dont want a dead olds on a weekend
    i will be working on this this winter and have put some bags in the rear coils, not working like I want but will lift car 3 "
    turned the steer wheel to end and it slips on the sector splines so should deal with that too
    and it sure gets hot inside this car when cruising
    did give it a 20 w 50 oil change and flush and it seems to maintain oil press
    think it got some coolant in the oil, just dont want to invest in a olds
    so thinking on a really hot 350 that i got and a 200 r4 so i can keep the tunel low
    found some nice pod lites for the rear think they are off the top of a cad ambulance?? swap meet
    got to change brake petal and accel so they dont over lap
    tire squealing is not good when stoping and turning:eek:
    going to m***ively insulate roof and floor
    stainless sidepipes
    would lke to narrow front if shorter a arms are available for a G body??
    should be a adventure
    shure wished i had not bought a ton of stuff for the olds engine,
    just another mistake in the custom rod world
    better get eady to leave for a show # 35 this year!!!:D
  11. well the 455 turned into a cadillac, dont know where to hide that guess i want a SBC being i tour the usa IF WE STILL CAN AFFORD FUEL:cool:
    well i got 2 mirrors on the car so i can see to drive
    put on a new water pump and it runs at 208 degrees and looks to have a bad thermostatic fan
    threw in a used rug, polished the left windshield gl***, polished the dash chrome and fixed the tack too, put the light switch in the dash and burned out the lite fuse for ****s and giggles, mounted the hood pull
    doing the 2nd rad flush , the block was a dirty mess and is starting to run cooler
    put in a power port for the GPS used for a spedo
    a lot of chicken **** stuff but it all makes for a better driver
    tightened the stering connector, that sliped in the shop when it went to lock end , loose bolt, moved the throttle away from the brake petal, that caused a wild ride once
    this pretty much took up the last 2 days and i really want to be getting my big garage door sealed and painted for winter time to shift gears on what i work on:eek:
  12. olds vroom
    olds vroom
    Nice score I love the way that looks , that looks almost exactly how I was thinking of building mine when I was bringing it home but went in a different direction . Again nice score
  13. well i got the seat tucked n rolled candystripe, photo in my top album, got car outside and tarped too many other projects:)
    ordered bag kits for front and rear not exactally sure on using them
    found some shorter tube a frames will order someday
    got the truck in that i am taking the engine out of for this car it a hot 355 with a ton of cam not sure on ****** 200 4r or 700 if i got lots of room
    got a water pump riser so i will have fan at top of radiator
    so i am getting parts even if i have not accomplished anything hope to start on it late spring or summer will put the 9 in rear first and do bags on the rear first its hard to get it high enough to drive love the look though thinking on getting a shiney stainless firewall but getting it lasered sounds spendy:D
  14. lukey
    lukey
    Do you have any updated pics? Sounds like its coming along nicely
  15. the car looks physically the same, the seat is not in it and to top that off this old fart just cant get that URL picture thing together
    i am getting a 1951 ford ready to go to tulsa and got a 53 chev to completely finish and ***emble and paint and just wrenched my back so i got lots to do before i get really into the olds
    other that i got lots of spare time:eek:
    actually i work on my cars full time, but sometimes get waylaid on more car work, like going to detroit and gettina a vehicle and moving most of them in my shop and warehouse, shoved the model a sedan in the showroom to get rid of it:eek:its a nice car but i dont think i will ever finish it:cool:
  16. put on a new used thermo hub for the fan and have been driving this around our town has oil pressure and don't overheat but the engine had all those old oldsmobile clanks, am still way behind on car work but got the 53 chev to run and a lot done on that
    will be working on this car next winter got a lot of the parts bought to start on it
    it is starting to be a nice driver:D
