Projects 1946 GMC Bonneville build
Discussion in 'The Hokey Ass Message Board' started by Marcia, Aug 26, 2020.
  1. Bearing Burner
    Bearing Burner
    from W. MA
    Looking good.
    Marcia likes this.
  2. Marcia
    Marcia
    Jalopy racing is something I can do every weekend. Racing is racing no matter how fast you go. The Jolopys are great fun.
    I've raced other people's cars at Bonneville but having my own there is like a dream.
    Thank you!
    Sent from my moto z4 using The H.A.M.B. mobile app
  3. Marcia
    Marcia
    Thanks, Conrad. It will make you proud.
  4. jimmy six
    jimmy six
    Sorry first time back on thread. An ez rubber mount to day is from Circle Track which are sort of wings bolted on the bellhousing bolts and use flathead Ford donuts. Since I see your building a race vehicle solid mounts are fine even with the 6. They have their own vibration problems which I fought for years even when going over 200 at Bonneville in our roadster.
  5. Marcia
    Marcia
    I went 136 at Loring and will be changing gears for Bonneville where the record is 131. Thanks for getting back to me.
  6. Marcia
    Marcia
  7. jerry rigged
    jerry rigged
    Stogy, chryslerfan55 and Marcia like this.
  8. Marcia
    Marcia
    Thanks Jerry
    It's a 3/4 ton. The frame is a lot heavier than the hald ton.
  9. I've been intrigued by the 2 x 8 wood cylinder head on that old Jimmy six.
    chryslerfan55, Stogy and Marcia like this.
  10. Marcia
    Marcia
    Better combustion
    Or just a better.place to pile tools and bolts. Its a 270 we'll replace with the 302.
  11. Nice work, I didn't remember my frame horns on my Chevy dropping down so far but after further review I guess they do.
    I know a couple guys that've built some serious drag trucks out of these and roll bar fitment is always an issue. Here's one of the guy's and he just stepped this up to a funny car cage style.
  12. jimmy six
    jimmy six
    Seems like when you think you have a roll cage that should meet the SCTA rules by ready everything in the rulebook an inspector will find the need for at the need for 30-40 more feet of tubing. A Randy LaJoie seat may not even be enough for some.
    I ran my 311” GMC 6 many years ago at Bonneville in a stock body 40 Chevrolet coupe running boards and all at 141 so your 131 is very doable but the Ford 6 camp has been fighting gremlins/growing pains for a few years and he showed a hell of a lot more HP than I’ve ever had.
    The engine currently holds the XO gas roadster record at 169+ on one 4 barrel. Here’s a photo. Good luck I’ll be watching your progress along with many... 1BFC6651-9821-4D31-9A64-D04CA6AA5EA4.jpeg
  13. Marcia
    Marcia
    I've sent in pictures of the roll cage and i hope they will let me know if they don't like what they see.
    I've seen your records and admired your efforts. You probably know I've been to Bonneville several times. I ran a 302 GMC in a 57 Chevy at Loring and did 136 in the mile and a half. I'm not saying I'm going out to set a record, I know how fickle the salt can be, but we'll give it our best shot.
  14. Marcia
    Marcia
    What carburetor are you using there?
  15. Marcia
    Marcia
    Nice cage, well done.
  16. Marcia
    Marcia
    The truck has arrived in PA to join the Flying Seven team. Going to start cleaning up the cab and get some painting done. IMG_20201206_143930774_HDR.jpeg
  17. Marcia
    Marcia
  18. Marcia
    Marcia
    I so glad I will be able to use this original dashboard in the race truck. IMG_20201227_104008205_HDR.jpeg IMG_20201227_104026523_HDR.jpeg
  19. Bearing Burner
    Bearing Burner
    from W. MA
    Will you use the new decals?
    Stogy likes this.
  20. Marcia
    Marcia
    Yes.
    lothiandon1940 and Stogy like this.
  21. Marcia
    Marcia
    Putting a nice thick coat of Rust-oleum on the frame with a brush. Anyone else do this? IMG_20210103_160610657_HDR.jpeg
  22. jimmy six
    jimmy six
    Sorry haven’t been following. It a early 600 with vacuun secondaries. Built and modified 30 years ago I’ve just stuck with it... tried others but always come back to it because it fits under the hood. In our 40 Chevrolet we ran a Clifford Research 3-2’s tubing manifold with 3 Holley 280 cfm carbs that were stock on 1960 Mercury’s. Tubes were 10” I’ll take a photo and post it.
  23. Marcia
    Marcia
    Frank out the bump stops on the front and back. The master cylinder is in the original location. A lot of engineering went into that, rather than hang it on the firewall. IMG_20210109_150740693.jpeg IMG_20210109_162610012_HDR.jpeg
  24. Marcia
    Marcia
    Got a big order from Jim Carter today. Mostly bed parts. Can't wait to get started. They look like well made parts. IMG_20210114_131259013_HDR.jpeg IMG_20210114_131739797_HDR.jpeg
  25. jerry rigged
    jerry rigged
    Marcia, thanks for posting the picture of your brake M/cyl. I've been wondering how I was going to fit a brake cyl and booster along side a T5 and keep the m/cyl in front of the seat for access to the filler. Duh, turn em around! Sometimes the simplest solution is the most elegant.
    -Jerry
  26. Marcia
    Marcia
    This is the original GM design. Brilliant!
    Stogy likes this.
  27. Marcia
    Marcia
  28. Marcia
    Marcia
    The original floor fits in with little modification.
    Again we're working in the truck daily. As you know, these projects go slowly.
  29. Marcia
    Marcia
  30. Only 508 days to Speed week 2023!
    lothiandon1940 and Marcia like this.
