Technical 1947 Ford Pickup Horn Button
Discussion in 'Traditional Hot Rods' started by knuckle44, Sep 12, 2023.
  1. knuckle44
    knuckle44
    I am trying to ***emble the stock horn ****on ***embly for the 47 Ford Pickup and can not seem to compress the two springs far enough to slip the three tabs of the horn ****on into the steering wheel so that I can rotate the horn ****on counter-clockwise to lock it into space. Does anyone have experience and suggestions as to how to accomplish this?
  2. Dak Rat
    Dak Rat
    from NoDak
    Two springs? Pretty sure there is only room for one coil spring under the ****on. Thats the way mine is.
    34 GAZ and dirt t like this.
  3. pprather
    pprather
  4. knuckle44
    knuckle44
    Thank you. I believe you are exactly correct. I don't know where the extra spring came from??
    Thank you. Yep that is what my ****on and spring look like. I appear to have too many springs.
    pprather likes this.
