1947 Ford pickup with car front clip
Discussion in 'The Hokey Ass Message Board' started by 55 Mercury, Jun 30, 2011.
  1. Thats fantastic!
    I love it.
  2. CW's40TPU
    CW's40TPU
    The lettering and striping looks great, really finishes it off, very nice looking PU.
  3. dvzdeathtrap
    dvzdeathtrap
    from austin, tx
    man, that does look good. very clean. great job -DVZ
  4. sodas38
    sodas38
    Sid, looks great. Excellent shop truck and advertising banner.
  5. LowKat
    LowKat
    Turned out great!
    Looks like it's always been there. Cool back bumper.
  6. Never been a fan of that model until now! Wow, now I want one.
  7. Hamtown Al
    Hamtown Al
    Great idea and even better execution. Good job!! I like "special" pickups. Al
  8. 46-48 Mercury front sheet metal would mess up some minds too! Brilliant! I do like the later fenders, but this is sweet!
  9. epic man! looks bad***!
  10. chrisntx
    chrisntx
    from Texas .
    What is the better way, Please?
  11. michaelmoore
    michaelmoore
    looks great . wow thats thinking and thrifty
  12. Sweet as, good work.:)
  13. 55 Mercury
    55 Mercury
    If I was to do it over again I would pinch the hood from the back to the front to match the nose of the car hood. I would not flatten the nose like I did it to match the pickup hood width.
  14. jalopy45
    jalopy45
    You going to bring it down to Chikashaw?
  15. hotdamn
    hotdamn
    I cant believe this isnt a common swap as the 47 truck front end is hiddious and the car front end looks great!
    good job :)
  16. flynbrian48
    flynbrian48
    Your s**** pile is evidently better than mine!;) Great idea, the truck looks great!
    Brian
  17. fryguy
    fryguy
    Just came across this thread and I have to give Kudo's. That looks really good, flows well, very easy to look at. Its definitely looks like something that could have come from the factory.
    -fryguy
  18. Gumpy1940
    Gumpy1940
    It looks factory....you could always say its from Argentia!!
  19. 55 Mercury
    55 Mercury
  20. koolkemp
    koolkemp
    So just curious ...do/can you drop an original axle for one of these trucks?
  21. jalopy45
    jalopy45
    Yes you can, Sid gave one of mine a deep drop, this is his shop truck with the car front end.
  22. 55 Mercury
    55 Mercury
    Thanks Jalopy45. I can drop the 46-47 pickup axles up to 4" overstock. I think 4" is to much. My 47 shop truck has a 3" dropped axle with Posie Dual-flex springs. It drive and rides good.
  23. Bigf350sd
    Bigf350sd
    from Georgia
    You said above that you think 4" drop on these axles is too much, is that just personal opinion because of the look of the vehicle sitting that low, or does it create problems? I have a 47 Ford truck myself, and have removed some of the front leafs, which softened the ride up a bit, and gave me some drop, but I'm at the limit of how low I can go with springs, because my bump stops are only about 1.25-1.5" from the frame now. I really love the look of the really low trucks, and want to go lower, for sure, however I do it. I'd love to keep the truck's 'old' styling and looks, so it'd be awesome to keep a beam up front, if I could get it lower like I want. The stock axles on these trucks, as you know, have some drop built in, but when you say 4" over stock, you do mean an additional 4" more, correct? As in if I bolted one into my setup right now, I'd gain 4 MORE inches of drop? Sounds awesome, to me, if so, as long as I could use tie rod drop blocks, or drop tie rod ends, and get everything hooked back up, and it drive decent. What's your take on that, is it something possible to do? What about drag link? What problems do you foresee me running into?
  24. 55 Mercury
    55 Mercury
    The 3" or 4" dropped axle will lower your truck 3" or 4" from were it is now. You don't use tie rod drops on the 46-47. You heat and bend the steering arms like you do for the early hot rods. I offer that service if needed. A 4" dropped axle tie rod is close to the spring and your into the scrub line. For the drag link I reversed the tapper in the pitman arm and put the tie rod on the top side of the pit man arm.
  25. Gman0046
    Gman0046
    There was a dark blue one at the NSRA Nats from southern Indiana. Its super looking. Putting a car front is something Ford should have down.
  26. OahuEli
    OahuEli
    from Hawaii
    I was thinking the same thing. Here's a photoshop of what it could look like.
    [​IMG][​IMG]
  27. Bigf350sd
    Bigf350sd
    from Georgia
    Thanks for the reply, and, by the way, your truck looks awesome. Wish my frontend looked like that. Anyway, speaking of the scrub line on a 4" dropped axle, isn't that dependent on the wheel/tire combo you run? I was really leaning towards 17's or 18's, and not sure on the tire size yet. I'll have to do some measuring to figure out what I can run, and what height certain tires are, etc... Could you give pricing here, or is there pricing on your website for dropping my axle vs. purchasing one already done, and are they exchange? I would also like to know the cost to bend the steering arms.
  28. koolkemp
    koolkemp
    I agree 100% they match the fronts perfectly Eli ! I dragged home my freebie one last weekend gonna see if I can find a set locally that I can repair...that should be fun lol!
  29. OahuEli
    OahuEli
    from Hawaii
    Hey Steve why not do what 55 Mercury did and put a 47 Ford clip on your truck but customized to match your '47 Ford, grill and all? That'd be cool!
