1947 Ford vin location?
Discussion in 'The Hokey Ass Message Board' started by 4ever17, Oct 21, 2006.
  1. My father just bought a 1947 Ford coupe. In Connecticut all we need to register the car is a ***le, bill of sale, and a trip to the DMV for a vin verification.
    Where on the frame should we look for the ID #'s ?
    Thank you for any help you guys can give.
  2. on top of the driver's side frame rail , somewhere between the front crossmember and the firewall
  3. Thank you!
    Thats what I thought but I was not completely sure.
  4. Roadsir
    Roadsir
    I the body is off the frame:
    On the same rail it may be stamped mid-way (under the door area), and on the top of the rear kick-up.
  5. Duende
    Duende
    Can't find it on mine. Need to register it soon. Any ideas where else it could be?
    Thanks!
  6. 19Fordy
    19Fordy
    Vin # is also stamped into the flat space at the top of the transmission where the transmission bolts to the engine.
    Here's a helpful thread. Open and scroll down.
    http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm
    and this
    https://www.fordbarn.com/forum/showthread.php?t=35505
    Scroll down to posting #6 here to see location of VIN # on transmission.
    https://www.fordbarn.com/forum/showthread.php?t=248899
    There always the remote possibility that your transmission doesn't have a stamp. That would indicate that the transmission case was replaced with a Ford case available to dealers. The VIN # would have been stamped on the shiny surface at the top of the transmission. Here is a photo of a case that does not have a number. Came out of a 1947 Ford. IMG_6798.JPG
  7. Duende
    Duende
    19Fordy, I think I know why I can't find it. Looks like someone has painted or primed the frame and it must be under the black paint. What is the best way to remove the paint without messing up the stamped VIN? Thanks!
  8. gimpyshotrods
    gimpyshotrods
    I know that it ****s to have to do this, but a razor blade.
    Preferably one with a handle. Flipping one ain't fun.
    The number should be between the front cross member and the steering box mount.
    These were stamped on a moving ***embly line. If your number is not there start working towards the back of the car.
  9. 19Fordy
    19Fordy
    Safety Razor blade is good idea. Put a little paint thinner on the paint to soften it first.
    DON'T DO ANY GRINDING OR SANDING. at all.
    A br*** wire wheel would be ok, not steel.
    Wear safety gl***es as razor blades often snap off.
    After you find it, take a photo.
    gimpyshotrods and Budget36 like this.
  10. BamaMav
    BamaMav
    from Berry, AL
    After I found mine under a layer of grease and dirt, I carefully went over the area with a wire brush. Then I took one of those paint pens you get in the craft section at WalMart and dabbed a little paint into each number, and wiped off the top with a rag so only the imprinted numbers retained paint. After that dried, I sprayed clear paint over the area so it would be visible for a long time.
  11. Budget36
    Budget36
    Good advice here. Easy to make the numbers disappear.
    gimpyshotrods likes this.
