Projects 1947 Krustom
Discussion in 'Traditional Customs' started by justabeater37, Oct 16, 2021.
  1. justabeater37
    justabeater37
    Gutters are part of the factory seam where the gutter is sandwiched between the roof and lower body sections. Just fixing the rot will be bad enough, let alone changing positions. 4AE48758-0ED7-4ADC-B152-658D5AC675F8.jpeg
    bchctybob, Okie Pete, brEad and 4 others like this.
  2. Stogy
    Stogy
    Beater, does the bottom of the two earlier and plan K both have a sharp transition or are they smooth transitions as the Top laid down look has?
  3. justabeater37
    justabeater37
    It will be a smooth transition when I make the new catwalk. Fun with long compound reverse curves.
    Stogy likes this.
  4. justabeater37
    justabeater37
    Went and looked at a couple of parts cars. They may help fill in a couple blanks. D552D816-CDA3-4DD8-8E40-837D590DB675.jpeg F0146F60-B955-4A6C-8EEC-9A561596C803.jpeg
    bchctybob, Kage, Okie Pete and 2 others like this.
  5. justabeater37
    justabeater37
    Chunk of 4 door roof for the profile and this is where it will live. Now to get this all together. 11B49731-1061-42A3-9DC8-972C0335B0EA.jpeg 9E52420F-8475-4A5A-8E31-05677EDAC6AE.jpeg 814C219F-14C4-405C-9CC1-0906CEB25F83.jpeg
  6. Stogy
    Stogy
    Looks great from my vantage point...You are well versed in this rodeo and have a good eye for what works due to your exposure to Hotrod/Custom over the years...it certainly shows...
  7. justabeater37
    justabeater37
    Starting to figure out how to repair the gutters and make them longer. Cut some pieces from a 4 door roof. Ugly but closer. 1E3880DB-502C-46BC-B9AF-7EF5F482A5D5.jpeg E8438F94-E881-4286-93DF-9651ECCFA124.jpeg 0172BF0C-ADF5-47E0-A6EA-372E6EF77059.jpeg
  8. justabeater37
    justabeater37
    I guess I better figure out the radius trunk lid corners before I trim the gutters to length. A5C8E964-8326-452C-8644-A6E04B3816F6.jpeg 6748B59D-49CE-4149-9FF7-A2AFA892D810.jpeg
  9. Stogy
    Stogy
    I can't help think these complicated rail mods influence the removal of the rails which despite negatives can also work in Custom...but the value of including them is also well warranted...I guess you are cutting them in above...there also a tab that fits in between the upper roof and lower roof seam...are you doing that to somehow?
  10. justabeater37
    justabeater37
    Yes. Air saw and lots of blades to cut 4 million spot welds. The area I need to rebuild due to sliding the rear of the quarter window forward will get made with the flanges and the a few plug welds to fix it all back together.
    Hamtown Al and Stogy like this.
  11. justabeater37
    justabeater37
    The repurposed piece cut a bit above the gutter 61F66A0B-B38B-4444-9A94-C28D2772B277.png
  12. Stogy
    Stogy
    I suspect theres actually a lot of strength added to the entire length of the drip rails due too 3 angled details being sandwiched together...
  13. justabeater37
    justabeater37
    This is the cross-section of the roof that I robbed the gutters from, unfortunately it also provided a place for moisture to get trapped because the bottom of the gutters weren’t View attachment 5231081 really sealed very well after all these years so there is a certain amount of rot involved with such a sandwich set up as well. A534F6F6-98BB-469C-B01A-1B2476584C5D.jpeg
  14. Tim
    Tim
    from KCMO
    Just noticed your parts car post. Those front splash aprons behind the front bumper are hens teeth. There are two different versions and neither are easy to find. Someone made a three piece front/back decades ago but nothings been available for a long time.
    just in case you need one or were looking for something to make a little money on
  15. 1-SHOT
    1-SHOT
    from Denton
    What is this going to be? Love the long hood. Frank 83C65ACF-57D8-44BC-91AA-47075C344598.jpeg
    loudbang, kidcampbell71 and Stogy like this.
  16. Stogy
    Stogy
    I'm thinking a tudor...that's a great shot...the sedan back is no doubt worth incorporating...
    It could be an altered wheelbase Hotrod...like the Bantam Flavor
    Make it a Coupe...move the well back into the quarter
  17. justabeater37
    justabeater37
    0C361816-4BA0-4007-852D-F155CAB80C9E.jpeg CA760DFF-D5D4-4043-883A-378EF8357730.jpeg A version of a long hood European inspired concept with a bit of refinement over the Buehrig model A
  18. Fortunateson
    Fortunateson
    I see fro m the pics of your open house that you’re saving up peanut shells to use for media blasting... LOL. I recommend walnut shells.
  19. justabeater37
    justabeater37
    Kind of thinking DOHC 6 Jag power. A bit off topic for here. We shall see when we pull it down if I can come up with an engine. I know where 2 are sitting but haven’t pulled the trigger as my bank account is still bled dry from moving and building.
  20. justabeater37
    justabeater37
    Peanuts are all I can afford.
    Okie Pete, Stogy and Fortunateson like this.
  21. 1-SHOT
    1-SHOT
    from Denton
    The picture that Justabeater posted is what I envisioned when I saw it 29A4D511-8133-4676-B2D2-82920EE94D7D.jpeg B38FF9A6-5B19-4B1D-A09D-F144C28DC162.jpeg
    Kage, Okie Pete, loudbang and 3 others like this.
  22. justabeater37
    justabeater37
    Dropped axle showed up today, posies from spring, Ch***is Engineering dropped steering arms, and a wishbone from my salvage area. I have 53-56 F100 brakes with 46-8 square spindles, adapters, new king pins, and all rebuilt backing plates with new drums coming so hoping for a quick swap up front. The rear lowering 9A0420DF-843B-4D25-83CE-2D4FC5132E85.jpeg A1739E31-07AF-4AE7-8A09-A094E72F2376.jpeg 8B57CB8D-5500-4867-A893-5B4CDC8D327C.jpeg spring is on back order, thinking about flattening the rear crossmember some as well as longer shackles to drop the rear. Work continues trying to get the gutter profile correct. Hopefully have this side wrapped up and on to the other side. It isn’t quite as rotten plus the door actually fit before we started this whole process so I’m hoping it goes way quicker. Less figuring things out as well. Hoping to be starting the actual bodywork on this thing before 1 December. Long ways to go to get to that point though.
  23. justabeater37
    justabeater37
    I was sold on blue until I laid this green pattern paper on tonight. Looks pretty close to 1947 Lincoln Opal Blue Green. 46D95887-40EE-408C-A1D2-8BD5CD5B368A.jpeg 1759A9B3-6D10-4C1E-97A8-A9565A40C3C6.jpeg
    bchctybob, Kage, brEad and 4 others like this.
  24. justabeater37
    justabeater37
    Blue or green? Green or blue? Either goes with WWW and a white interior. I hear paint is getting to be a longer lead time everyday so I should probably make the decision soon. D58C7346-B688-4116-8420-4CFE8E5AF343.png B7F36A7E-361A-4FED-9B1D-9B060918CC14.jpeg 68F3C8F6-5A85-4D85-8EE9-1C1C8911D867.jpeg
    Kage, brEad, Lone Star Mopar and 3 others like this.
  25. topher5150
    topher5150
    I kind of like the blue that's on the fender
  26. 1-SHOT
    1-SHOT
    from Denton
    There is a wait on black and some of the hardness right now, and other primary colors are also affected. I like the green
  27. charleyw
    charleyw
    I prefer green also, blue reminds me of winter, lol.
  28. justabeater37
    justabeater37
    Trying to stick with inexpensive off the shelf colors. This may be close though. 10661358-9C0D-43B6-8914-7828A95217F5.jpeg
    kidcampbell71 likes this.
  29. atch
    atch
    I like your profile
    way better than most of the chops on these cars; like this:
    Keep on keepin' on...
  30. [​IMG]
    That a red cattle dog?
    Long way from home if it is...
