Projects 1948 Anglia Southeast Gassers build
Discussion in 'The Hokey Ass Message Board' started by Zak Hall, Nov 14, 2021.
  1. mohead1
    mohead1
    That there is a street car for sure...wire up some lights and get it done
    Thor1, loudbang and Zak Hall like this.
  2. Just Gary
    Just Gary
    'Nuther question: Why not a 406" sbc?
    It would be about 80 lbs lighter over the front axle with maybe a bit less torque & the same hp but at a higher rpm.
    Was co$t a decision driver? Maybe less parts breakage?:confused:
    Please don't think I'm being critical, I'm just inquisitive. I absolutely love your build. :cool::cool:
  3. Zak Hall
    Zak Hall
    Injection on gas isn’t terrible to tune as long as you stay ahead of the weather, you do have to tube to the DA, and it is sensitive, so I’ll swap pills 2-3 times a race usually, depending on weather changes through the day. Cam will be roughly .780 lift and 280° @ .050 , as far as Compression will be hopefully Atleast 13.0-13.5 to 1
    Thor1, mad mikey, bobss396 and 2 others like this.
  4. Zak Hall
    Zak Hall
    Because per the rules the small BBC will get to weigh 90lb less at the CI. Plus this is the stuff I’d what I blew up in the 55 in 2020 I’m reusing. It’s a 9000+ rpm engine combo.
    brEad, Thor1, mad mikey and 7 others like this.
  5. If the seats were much farther back, you'd have a short wheelbase slingshot dragster.:p
    Thor1, mad mikey, loudbang and 3 others like this.
  6. Zak Hall
    Zak Hall
    Yeah I had to scoot back in it, I’m not a small guy at 6’ 2” and 250lb, with a size 14 shoe. I wear this thing like a pair of pants lol
    brEad, Thor1, SS327 and 16 others like this.
  7. Looking forward to this matchup. Too bad Donovan bailed.
    EVL401, Thor1, kidcampbell71 and 5 others like this.
  8. bobss396
    bobss396
    We built our stock cars on the light side. That way we could add the weight to bring it up to specs and put it where we wanted to.
    Thor1, SS327, mad mikey and 2 others like this.
  9. Zak Hall
    Zak Hall
    Yes ideally I’d like to be able to add 50-60lb on ballast to make weight.
    Thor1, mad mikey, catdad49 and 4 others like this.
  10. 6sally6
    6sally6
    6'2" and 250 lbs!:eek: Pretty big Bow-ee!!:eek:
    Reminds me of a guy a few years back in a V-8 powered Opal GT.(shrunken Vet) He climbed out while at the starting line. He had to be all of 6'6" and 200+!
    He looked like King Kong! Several peeps in the stands were saying "Holy smoke..look at that dude"!
    The roof of the Opal GT was about belt level!
    He reached over to the p***enger side to press the start ****on (and purge the nitrous system!;))
    Big Bow-eez in tiny cars..quite the site!!
    Keep it skrate!!
    6sally6
    Thor1 and mad mikey like this.
  11. Zak Hall
    Zak Hall
    The first Home Grown car was dads Opel gt back in 1980. It was an injected 454 bbc, 4 speed car too.
    EVL401, pecker head, brEad and 21 others like this.
  12. 6sally6
    6sally6
    Always liked those^^^^^^^^^^^
    6sally6
  13. Zak Hall
    Zak Hall
    Me too! Hopefully one day I’ll get to build one.
    Thor1, mad mikey, AHotRod and 2 others like this.
  14. bobss396
    bobss396
    Once we had the car built and scaled, it was a matter of bolting the weight in place. I don't recall ever moving it or changing it in 3 years I ran the car.
    The late Richie Evans had a great solution. He built a weight-box into the left side frame. It became a matter of sliding the weight to and fro where he wanted it, lock it up and go racing. He had one basic car used on any track, others had 2 or more cars that were track-specific.
    Thor1, mad mikey and loudbang like this.
  15. Zak Hall
    Zak Hall
    4C1203B9-D208-49E3-8743-9C1C8D04DF0C.jpeg B4790FEA-D155-4A96-AFAF-A76F9F688E9A.jpeg 082ECAF2-EC34-4EB9-87C9-E7FDFBBB4578.jpeg F6C458F4-7DBE-4573-94E1-E6AC1651775F.jpeg Stoked my front mag wheels came in today. They match my mag American standard rears perfect, really going to make a cool car.
    I am in search of (1) single magnesium 15” American torque thrust/5 spoke though, can be a 15x6, 7, or 8, wide, any bolt pattern, and can be damaged. Just need it to repair one of my front runners. thanks!
    Thor1, Brian Penrod, SS327 and 13 others like this.
  16. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Check.
    I'm 6'6", 220#.
    The track announcer once said, "Every time I see Greg slide into that altered I expect his feet to pop out the bottom, like The Flintstone Flyer!"
    Hence, the moniker The Frenchtown Flyer was born.
    I too own an Anglia...
    ...and a '33 Willys.
    I also have an Opel GT story. But that's for another time.
    There seems to be some sort of Law of Inverse Proportionality where the bigger the driver, the smaller the car he prefers. Go figure.
  17. I know you will, so I’m looking forward to the do***entation of your Magnesium wheel repair!
    brEad, Thor1, mad mikey and 2 others like this.
  18. Zak Hall
    Zak Hall
    Yep big guys wanna have the tiny cars for sure!
    verno30, Thor1, kidcampbell71 and 4 others like this.
  19. Zak Hall
    Zak Hall
    859B6951-3652-4C65-975E-F4DD4E38BF61.jpeg 6AC7C97A-37C0-4ED5-91EA-17B3E8134F14.jpeg A7C6179D-3395-4CAE-9AA7-F3732D4DA3D0.jpeg 21E3BE26-EB8D-4E6D-BCB4-39EEEA2C42CA.jpeg 37985F75-E003-4844-8997-D099791235F8.jpeg 5EB06C4E-270A-4D51-9B0B-C4F532ADB26B.jpeg C201FC45-4193-4DFB-A7E8-92EEFB4A41C7.jpeg 7DF564B9-98E8-48EE-8CA9-4A15BF54ED86.jpeg FF45EFC5-14EE-4C94-B34E-D7ACD45BBCAB.jpeg 899F3F6B-8AC9-4C61-9F52-5B75290015C8.jpeg View attachment 5249686 14919E12-0C14-42B0-9201-286B6A26CA73.jpeg 5F9A2D55-4478-4619-BEDD-2F252A3DC697.jpeg 1065DC20-DB3D-43CC-A5D3-CC2157ECF188.jpeg 1AC23839-3D00-43BA-A6A6-9EF00D164348.jpeg Pretty good weekend, picked up an Advanced clutches setup, a Simpson chute, and a set of compe***ion engineering front shocks for the car at a local swap meet. Then got the inside of the body primed, and painted semi gloss black, and finished up the brackets and chromoly trans crossmember. We’ll start on the pedals this week.
    EVL401, Stogy, Thor1 and 13 others like this.
  20. Zak Hall
    Zak Hall
    Mocked the brake and clutch pedals up in the car last night, once I get my clutch fork in we can finish this up.
    EVL401, Stogy, Thor1 and 9 others like this.
  21. I see Wilwood on the brake pedal, they also make the clutch pedal ***embly, or is that something special from Hall’n *** Speed?
  22. Zak Hall
    Zak Hall
    The clutch pedal is a chromoly kit from Applied Racing, and it’s a floor mount mechanical pedal setup, I didn’t really have room for a floor mount master cylinder though so I went with the swinging wilwood master setup. Wilwood makes the clutch combo but it’s hydraulic and those are prone to issues when using them on a clutch with counterweight and such
    Thor1, mad mikey, catdad49 and 6 others like this.
  23. AmishMike
    AmishMike
    Like that slip proof clutch pedal. Like your ****** mount also. Have ****** mount to do with an auto trans & besides weight wonder how much torque trans mount has to take & push into frame. Trying to build light weight like you but for street.
  24. Zak Hall
    Zak Hall
    With a mid plate like I’m running, the trans mount really just holds the weight of the transmission and keeps it from trying to whip around. I guess it does act like a crossmember in the ch***is some too though. But technically the car could be ran without one, like a 55-57 Chevy car or Chevy truck. With an aluminum Bellhousing or an automatic it could break the case though. You also want to run a rubber/poly trans mount, not a solid mount if you have solid engine mounts, that way the ch***is can flex around the transmission instead of binding/breaking it.
    Thor1, SS327, kidcampbell71 and 9 others like this.
  25. Zak Hall
    Zak Hall
    E739BC7E-DE8A-4A09-B16E-AE76CEC8F02A.jpeg The finalized 2022 SEGA schedule was just released.
    Thor1, 48fordnut, bobss396 and 7 others like this.
  26. Valentines Speed Shop
    from Boxiron,MD
    I'm planning on Shady Side, hope you have the this car ready for compe***ion by then! Would love to see it in person.
    I was there last year and saw you run the 55!
  27. Zak Hall
    Zak Hall
    I’m hoping to have this car running for the season opener, it may be in sealer primer and need body work still at the debut though.
    brEad, Thor1, mad mikey and 8 others like this.
  28. mad mikey
    mad mikey
    I really like those headers Zak. Hell, I like the whole thing. Looks great. Nice work as always.
    Thor1, 427 sleeper, loudbang and 2 others like this.
  29. glrbird
    glrbird
    Hope y’all are safe, that was a wicked storm!
  30. Zak Hall
    Zak Hall
    Yeah we’re on the northeastern tip of Tennessee so it missed us. I’ve actually been in Indy at PRI all weekend but it also missed me here too. Got a lot of wind and rain but no twisters luckily!
