1948 Chevy Coupe
Discussion in 'Cars For Sale' started by paul55, Dec 15, 2017.
  1. paul55
    paul55
    from michigan
    City: Warren
    State: Michigan
    Price: SOLD
    Listing this for a good friend(His words/description); This listing is for a 1948 Chevrolet Stylemaster 2 door coupe. This vehicle is one that I inherited from my father at his p***ing. It was in a body shop that was too far from my home so we brought it to Michigan and had it completed by a body man I know. I built the Stovebolt engine. While my father had the car he sent it to an upholstery shop to have the interior done. He also paid for some initial body work and after the car came to me I had it painted. I have some new parts and some hot rod parts that go with this vehicle so that who ever buys it can either work with what is there or go a more modern route with the drive train. I have an S-10 rear end with 3.23 or 3.42 gears, and a T-5 trans 5 speed with overdrive that will work with the addition of an adapter that is available, or you can chose to have the automatic trans adapter minus the trans, the choice is the buyer's.
    The engine started out as a 261 Stovebolt. It has been bored and stroked to 302 cubic inches. It has H beam rods and custom pistons for a 9 to 1 compression ratio. The head has been ported and has a rebuilt rocker arm ***embly. A custom Comp Cams camshaft designed for max torque was also degreed and installed. The engine also has been converted from a 10% oil filter to a 100% filtering system with a remote filter. The crankshaft has been stroked from 3 and 15/16 to 4.220 stroke with a max overbore of 3.900 for a final cubic inch of 301.9. The engine is topped with a trio of Rochester carbs on an aluminum intake with 3 chrome air cleaners complemented by a Fenton dual exhaust header/manifold. The exhaust has not been completed but the hardest to make pipes, the ones from the headers to the area below the frame, have been fabricated. The engine also sports an aluminum valve cover and an aluminum pushrod cover. The engine is finished off with an HEI distributor and Taylor red wires. The generator has been rebuilt and is upgraded to 12 volts along with a new voltage regulator. The last incredible thing as far as the engine is concerned is the tripower carb linkage. The engine runs off the center carb with a progressive linkage opening the end carbs at 2/3 throttle. The engine was dyno tested in 2010 and made 229 hp with 450 ft. lbs of torque at 2400 rpm. The funny thing is we never thought to pull it lower than 2400 rpm and that was the area of max torque, but the curve was higher at a point lower than we recorded.
    The rear end that is in the car is the original and has 4:11 gears. That is why we are offering the other S-10 rear end to go with the vehicle.
    The car was on display at the 2017 Detroit Autorama in the lower Auto Extreme area.
    The car does need a few small items addressed. The brakes are just okay and I will include a new, dual port master cylinder along with a 7" vacuum booster and the mounting brackets (it all came in a kit form) so that the new owner can bring it up to more current standards. I have a new 12 circuit new wiring system to go with the car. The wiring to the tail lights has been run and the rear tail lights are new but must be wired. All the wiring for the headlights (new 12 volt halogen) will need to be wired to a relay. All the bulbs in the car will need to be replaced with 12 volt units. The wiring that is in the car is original, and the new owner can either work with that or install the new wiring harness. The clutch operates as it should. The linkage for the trans will need to be modified to clear the Fenton header if the new owner decides to run the 3 speed trans.
    The car has been lowered 3 inches front and rear. It has drum brakes on all 4 wheels. The tires are so/so and good for around town. The door handles and wiper transmission towers are pitted but we could not find replacements. The front turn signal chrome has been covered but they are pitted. The trunk latch works but needs adjustment. It has an adapter plate behind the water pump to use the original 216 water pump and keep the 5/8 wide belt. The belt is a few inches longer than it needs to be so there is an extension on the upper bracket. The doors need weather stripping in areas. I have both bumpers but they need to be replaced or rechromed . I have not tested the wipers so I will say they are what they are. It has a spare underseat heater that goes with it which is untested. There is a heater in the dash unit as well but I have no knowledge as to if either heater works and will not guarantee that they do. The interior will need some new door handles, and the shift knob has long since been lost. The gas tank is new. The headlights are halogen. The intake manifold pushrod cover and rocker arm/valve cover are all Offenhauser. It will need the 2 arm rests for the doors. The interior is all new from headliner to carpet.
    The car is a representation of a mid 50's hot rod. While the body work is great, the floorpan is good, but has had a few places repaired. Overall, very straight, solid car. With the mechanical things fixed it should be a great cruiser. The reason for parting with this car is it is not my style and I have way too many projects.
    $16,500 or best offer. Trades considered such as a 36 Chevy coupe or a late-model low mileage vehicle. PM or pladclark@sbcglobal.net
    00g0g_3mRlk5Zmzgb_600x450.jpg 00I0I_cyOYuvSxSYz_600x450.jpg 00q0q_kGsaZbvJjnB_600x450.jpg 00H0H_3pkttzin6oc_600x450.jpg 00D0D_4NWnfViG1uJ_600x450.jpg 00b0b_f5OofJFvwww_600x450.jpg 00F0F_8XLu4qqO18Q_600x450.jpg 00v0v_j1nLp2dbX1w_600x450.jpg 00202_k7k3EDL97WD_600x450.jpg 00v0v_6Kkma1pXonH_600x450.jpg 00202_eKo3euDRARF_600x450.jpg 00505_4G9btCQWjyr_600x450.jpg 00H0H_2JSDL28MOJE_600x450.jpg
  2. paul55
    paul55
    from michigan
  3. paul55
    paul55
    from michigan
  4. paul55
    paul55
    from michigan
  5. paul55
    paul55
    from michigan
  6. paul55
    paul55
    from michigan
  7. paul55
    paul55
    from michigan
  8. paul55
    paul55
    from michigan
  9. paul55
    paul55
    from michigan
  10. paul55
    paul55
    from michigan
  11. paul55
    paul55
    from michigan
  12. paul55
    paul55
    from michigan
  13. paul55
    paul55
    from michigan
  14. paul55
    paul55
    from michigan
  15. paul55
    paul55
    from michigan
  16. paul55
    paul55
    from michigan
  17. paul55
    paul55
    from michigan
  18. paul55
    paul55
    from michigan
  19. paul55
    paul55
    from michigan
  20. paul55
    paul55
    from michigan
  21. paul55
    paul55
    from michigan
    bump
    iron dave likes this.
  22. paul55
    paul55
    from michigan
    bump
    zeph4057k likes this.
  23. paul55
    paul55
    from michigan
  24. paul55
    paul55
    from michigan
  25. paul55
    paul55
    from michigan
  26. paul55
    paul55
    from michigan
  27. paul55
    paul55
    from michigan
  28. paul55
    paul55
    from michigan
  29. paul55
    paul55
    from michigan
  30. paul55
    paul55
    from michigan
