1948 Ford F4 build thread
Discussion in 'The Antiquated' started by Hivolt5.0, Nov 8, 2011.
  1. Johnboy34
    Johnboy34
    from Seattle,Wa
    Who made the gl***? Made off your pattern or theirs? If theirs I would be calling them.
  2. cowboyinachair
    cowboyinachair
    from colorado
    he had it cut after the one he bought was broke so its on him
  3. Yep, this one’s on me. I took the broken windshield to a local gl*** company and they cut a new one. I’m hoping they can sand (not sure what the process is) some material off so that it will fit. Probably wouldn’t take much.
  4. cowboyinachair
    cowboyinachair
    from colorado
    i would have them install it too
  5. I called and asked but the lady I talked to didn’t know. I left my number for them to get back with me.
  6. I don't know how they do it today, but back in 1969, the Safelight guy smoothed the edges and brought the gl*** down to pattern size using a water-sprayed belt sander, which I think both cooled and lubricated the cut. I doubt they make house calls with that equipment, but like I say, don't know how they do it today.
    Did you opt for a tint, or clear gl***?
  7. Good point Osage. I’m gonna try and go by the business next week and explain the problem at which point I’ll probably have to take the gl*** out and take it to them to sand. Your explanation of the process makes perfect sense to me.
    I opted for the clear gl***.
  8. I finished polishing the hood Spears today and got the installed. Have you guys ever seen a hood without the character line?
  9. charleyw
    charleyw
    "Have you guys ever seen a hood without the character line?"
    No, but I kinda like it.
    osage orange likes this.
  10. Johnboy34
    Johnboy34
    from Seattle,Wa
    Only on 51 and 2's.... is it an f4 or bigger series deal? I like it too!
  11. It’s an F4 but that isn’t the original hood.
  12. Looking back at a picture of the truck "as found", the original hood had that character line. I've never seen a hood that didn't have it so I'm a bit perplexed but like you guys, I like it without the character line too.
    JUNK ROD likes this.
  13. atch
    atch
    Very interesting. I've considered for many years slicing and dicing Clarence's hood to remove that line. I've envisioned it but now I get to actually see what it would look like. How 'bout a few more hood pix?
  14. Atch, I wasn’t sure what angles you wanted of the hood. Let me know if you’d like more pics. I didn’t see any evidence of “slicing and dicing” when I removed all the filler that was on the hood prior to paint.
    charleyw and Johnboy34 like this.
  15. Johnboy34
    Johnboy34
    from Seattle,Wa
    I looked at f3 f4 f5 f6 f7 f8 pictures on the interweb and this 49 f5 is the only one that looks like it "could" be the same, a rare and unusual hood you got there!
  16. Thanks for the pic Johnboy. It’s definitely and interesting anomaly.
  17. atch
    atch
    Thanx for the pix. That hood is way cool.
    I know where there used to be a few of these big trucks in a bone yard. Looks like I'll be visiting sometime to see if they are still there and if they have any hoods like this.
    Hivolt5.0 likes this.
  18. I got a little bit of time in on the truck today. I forget who recommended it, but I rounded the edges of the taillight brackets. Now to paint them.
    I bought some rust encapsulator and painted the insides of the doors. Sorry no picture.
    I installed the door lock.
    Finally, I decided to try my hand at painting the Ford script on the dust caps. I've noticed the older I get the more shaky my hands are. The painting isn't perfect but considering what these caps looked like before, I'm pretty proud of the outcome. Both caps were beat to death so I heated them up and hammered them back into shape.
    Then I had them chromed and painted the script.
    55Deso, osage orange and Johnboy34 like this.
  19. HOTFR8
    HOTFR8
    That Hood - Bonnet looks factory to me. Just the same as on my F4.
  20. Very cool!! Nice to know the hood isn’t a fluke.
  21. Excellent work on the dust caps. Those are always pieces that get abuse, and you've given them a great second chance.
    Johnboy34 likes this.
  22. Well, I was to get the windshield trimmed and it popped right in place!! Also installed the driver vent gl***. The p***enger side gl*** needs to be trimmed a bit.
  23. Windshield magic? Thanksgiving miracle? Change in temperatures, tide, barometric pressure, or just danged luck? Never look a gift horse in the mouth.
  24. Just a small update. I mounted a fire extinguisher, installed the review mirror, made some small adjustments to the window divider bar and bolted on the door access panels. Not sure if I mentioned this earlier, but the lower radiator tube I made had a couple more leaks in it. I removed it a couple of weeks ago and welded up where the leaks appeared to be and repainted the tube. So this past weekend I installed the tube and put the coolant back in. Unfortunately I missed a small hole around the drain plug so I took it back off and took it to a local radiator shop. I got the tube back yesterday and they sealed it up for me. Time to reinstall it, hopefully for the last time. Also took the p***enger vent window gl*** to a local gl*** cutter today. They're going to try and sand a bit off of it because it wasn't fitting very good.
    Fire extinguisher: I know it sticks out a bit but I wanted it quickly accessible. I thought about mounting it on the floor between the shifter and seat but didn't.
    Review mirror mounted.
    I love the contrast of the stainless screws against the red paint. Also mounted the door handle and window crank as parallel as I could. OCD kicking in.
    So nice to have the windshield in.
    You can see the vent gl*** over laps the divider bar which I have adjust as far to the back as I can.
    Here you can see the gl*** doesn't seat in the vent window frame very well. Hopefully the gl*** company can sand it enough to fit correctly.
  25. Got the p***enger vent gl*** trimmed and installed!! Yah!!
    The lower radiator pipe I made is finally leak free. Although I haven’t run the truck yet to fully test. That will come soon, I hope.
    I took the carbs back off and adjusted the floats. Hoping for a leak free trio of dueces.
    Went ahead and changed the oil and filter just in case the excessive gas running through the carbs washed down the cylinders and got in the oil. Also changed the plugs. Can you say running REALLY rich?!?
    Anyone want to come by and help me tune this truck? I’m not a tuner...wish I was. Guess this is OJT.
    Worked on covering the opening on the seat belt reel since I have to use them backwards. I bought some ABS plastic and tried Gorilla gluing a cover on. FAIL! Didn’t even hold. Came apart when I started t******* the excess. I’ll figure out try number 2 and report later. Good thing I have plenty of ABS!
    That’s it for now. I probably won’t get to work on the truck until after Christmas. So, I wish all of you and very blessed Christmas!!
    God bless
    David
  26. Johnboy34
    Johnboy34
    from Seattle,Wa
    Looking good, thanks for the update. Have a great Christmas David
  27. atch
    atch
    There are about a million adhesive products on the market and someone here probably has a better solution than I do, but try Shoe Goo. Maybe that's not the exact spelling. You can find it in the shoe section with the polish and shoe strings at WalMart. It's a contact cement; meaning you put it on both pieces and let it dry and then put the pieces together.
    Let us know what you finally use that works.
  28. Interesting atch. I didn’t think about a contact type of cement. So the shoe goo is similar to weather strip adhesive?
  29. atch
    atch
    Really similar; perhaps the same thing. One or the other might be better, but I don't know .
  30. I think Atch is onto something. Clean all surfaces as best you can, rough 'em up a bit. I have used two different types of epoxy lately, and the stuff that also can be used for ABS plastic works quite well for that. Might work for your application, but I was bonding ABS to ABS (BMW key). Didn't work as well gluing some gl*** flowers back together.
    If Shoe Goo stays pliable and doesn't turn brittle over time, I'll bet it would be as reliable as anything.
