1948 Ford F4 build thread
Discussion in 'The Antiquated' started by Hivolt5.0, Nov 8, 2011.
  1. cowboyinachair
    cowboyinachair
    from colorado
    goop plumbing is clear and bonds like nothing i have ever seen stays pliable too
  2. Thanks for the info guys. Time for some research.
    brEad likes this.
  3. I used the weather strip adhesive to great success!! I roughed up the surface and applied the adhesive and then placed the retractors on a flat surface and put a heavy object on top of them to make sure the two pieces were pressed together well. Thank you for the advice!!
    Then I started the motor with the adjusted floats. Still leaking and the motor just doesn’t want to run right. I asked a neighbor, who builds cars for a living, for some help. He said it acted like it was starving for fuel while gas was leaking out of the outer carbs. I’m starting to wonder if I should just cut my losses and put a 4 barrel carb on it. I love the dueces but I just don’t have the knowledge to tinker with them.
    brEad and JUNK ROD like this.
  4. So from my last update I've decided to take the deuces off and put a Holley 4160 on the motor. I took the one off my Ranchero to see how the '48 ran and while the idle was really high, it ran good and didn't miss a beat. So I'm making preparations for the switch. But since I can't take the completely easy way out I decided to modify the stock oil bath air filter ***embly to work with a 4 barrel carb and normal air filter. Here's what I did.
    Here's what I started with.
    I cut the bottom of the air filter ***embly off. You can see how rusty the ***embly was so I didn't feel too bad about cutting it up.
    Then I cut the bottom off a 4 barrel air filter ***embly I had laying around. Not sure what it went to.
    I plan on running a tall air filter and needed a smooth bottom for it to sit on so I filled in these recesses.
    Test fitting the two pieces together so I can make the dip in the new bottom to match the dip in the original ***embly where the handle came through to tighten it to the carb.
    My original plan was to use the dip from the original air filter ***embly bottom, but the metal was so thin I just kept burning through so I ended up having to fashion my own dip.
    So here is where I fashioned my own dip in the bottom. I'm no metal shaper so I did the best I could. I ended cutting strips of metal, tacking them in and then formed the contour I was looking for. It worked, not very pretty, but it worked.
    The two have become one.
    osage orange likes this.
  5. Just for giggles, I put the 3 deuces on the Ranchero to see what it'd look like.
    Here's a test fit of the modified air filter ***embly on the Holley 4160. I need a one inch spacer between the carb and air filter because to make it fit better. In the end, the ***embly will be painted black and have the factory stickers on it. Not as ***y as the deuces but if it will run right and not require as much fiddling I'll call it a success.
  6. Bigcheese327
    Bigcheese327
    Now, can you make a set of convincing 1948-style valve covers?
    OahuEli likes this.
  7. Now that would be an accomplishment!
  8. Bigcheese327
    Bigcheese327
    Come now, surely if you can slice-and-dice that aircleaner housing so nicely, it would be a small matter to re-work some period valve covers from a Chevrolet, Nash, or some other OHV engine. :D
    Hivolt5.0 and OahuEli like this.
  9. woodbutcher
    woodbutcher
    :D Looking good sir.Adapt and overcome.
    Good luck.Have fun.Be safe.
    Leo
    Hivolt5.0 likes this.
  10. Got a few more things done today. A friend came over and helped me straighten out the front bumper with the fire wrench. We then mounted it to see how everything would look. Just needs to be painted!!
    Then I started working on a bracket to mount the ‘48 Florida license plate. Admittedly it is way overkill but I wanted to make sure the plate would be supported extremely well.
    brEad, JUNK ROD and osage orange like this.
  11. Johnboy34
    Johnboy34
    from Seattle,Wa
  12. OahuEli
    OahuEli
    from Hawaii
    I think I've seen that design before, its called the Hurricane Andrew bracket.:rolleyes::D
  13. LOL!!! Yes!!
  14. HOTFR8
    HOTFR8
    Plate mount is overkill. Just how I would have done it. It should not break.
  15. So I took the week off while the wife and kids are out of town to try and get a lot accomplished on the truck. First order of business is to get the blasted truck running right!!! A buddy and I did a lot of tuning on the 4 barrel. It is idling good but at about 2k rpm it was backfiring bad out the exhaust. To try and eliminate the good from the bad I byp***ed the fuel pressure regulator first. Still backfired. Adjusted the timing; still backfired. Put the carb from my Ranchero on; still backfired. We can’t tell if it’s a fuel or ignition problem.
    Before byp***ing the FPR I noticed the FP gauge wasn’t reading 6psi where I had set it. It was down around 1psi. Not sure if it’s the gauge, fuel pump or what which why we byp***ed it but it didn’t make any difference in the backfire.
    I checked the temp of the headers while it was running. All of the cylinders were between 285 and 301 except cylinders 3 & 4 which were around 420 degrees. Not sure what that is all about.
    I haven’t pulled the plugs yet, waiting for it to cool down.
    Any thoughts?
  16. cowboyinachair
    cowboyinachair
    from colorado
    check the firing order old sbf are diff then new sbf
  17. Ok. I double check that.
  18. Ok. Double checked the firing order and it is correct. The engine is 1989 302 Non-HO. (1-5-4-2-6-3-7-8)
  19. cowboyinachair
    cowboyinachair
    from colorado
    you have dura spark whats the coil
  20. I have a MSD coil.
  21. cowboyinachair
    cowboyinachair
    from colorado
    the coil is to hot and its jumping around in the small cap
  22. Interesting. Would a large cap help?
  23. cowboyinachair
    cowboyinachair
    from colorado
    that is why the big cap came about
  24. Ok. I’ll look at getting a big cap. I had one on it but it didn’t fit with the 3 deuces but now that I’m going back to the 4 barrel I have room for the big cap.
  25. cowboyinachair
    cowboyinachair
    from colorado
    you could try a stock coil too
  26. And give up the nice shiny chrome coil. [emoji22] but I’d rather have a motor that runs like it’s supposed too.
  27. cowboyinachair
    cowboyinachair
    from colorado
    get a coil cover
    Bigcheese327 likes this.
  28. atch
    atch
    Someone correct me if I'm wrong, but if it backfires through the exhaust it's firing when an exhaust valve is open and if it backfires through the carb it's firing when an intake valve is open. If retiming it does not correct the problem then it most likely is crossfiring as mentioned above and it's not likely a fuel problem.
  29. The engine came out of a 1989 grand Marquis so I’m pretty sure it is Non-HO. The engine idles great it’s was just when I held the throttle at 2k rpm that the backfired started.
  30. Well, bad news, #7 cylinder is dead. Started pulling plug wires while idling and there was no change on 7. I plan on doing a compression check tomorrow.
