Projects 1949 Buick Sedanette Mild Custom Build
Discussion in 'Traditional Customs' started by rockable, Mar 16, 2019.
  1. BJR
    BJR
    That is breathtaking!!!!!
    loudbang, Thor1 and rockable like this.
  2. rockable
    rockable
    There's nothing ***y about rebuilding light fixtures but it beats losing your lights at an inopportune time. You have to admit, however, they don't make them like this any more.
    0916211523_HDR.jpg 0916211522a_HDR.jpg 0916211522_HDR.jpg 0916211520_HDR.jpg 0916211518_HDR.jpg
  3. rockable
    rockable
    Need to make some new terminals for your sockets when you replace that rotten fabric covered wire? Solder a 1/8" pop rivet to the wire. Voila! You may have to grind down the o.d. if it's going into a duplex socket like any 1157.
  4. X38
    X38
    ***y? Man I love detail stuff like that and clean work.
    lothiandon1940, Thor1 and rockable like this.
  5. rockable
    rockable
    0917211254_HDR.jpg 0917211241_HDR.jpg More detail stuff. A little brush, some One Shot and some thinner on a paper towel is all it takes.
  6. BJR
    BJR
    That tail light is just gorgeous.
  7. loudbang
    Your attention to "The Details" is what makes your build stand out from others. :)
  8. rockable
    rockable
    Thanks, Loudbang! I've been restoring cars for a long time. I'm retired and in no hurry, so it's much easier for me to attend to the details as I've gotten older. Plus, my skills have improved.
  9. rockable
    rockable
    Waiting for small parts is driving me crazy. "For want of a nail....." has p***ed through my mind many times lately. So, to occupy my time and do something that needed to be done, i made a shallow glove box insert for my SecretAudio control panel. I mostly use the remote but sometimes you need full function access. There is a bezel that snaps onto the controller to clean the install up.
    I used expanded pvc foam sheet and a heat gun to form the corners. Wrinkle finish rattle can paint does a nice job on the inside with a little urethane glue in the corners to seal it up. Voila!
    I usually make this out of 20 ga. steel but this worked so well, I doubt I ever use steel again. It needed to go in from the front and be a little flexible. As an added bonus, the plastic sheet doesn't scratch the paint.
  10. LAROKE
    LAROKE
    ACES! That is really trick!
    rockable, loudbang and lothiandon1940 like this.
  11. rockable
    rockable
    Finished the exhaust. The pictures show the rear suspension at full droop. I was able to avoid using 45 degree bends by canting my mufflers. This worked out well, I think. I am waiting on parts right now but should start it up soon. Buick exhaust 4.jpg Buick exhaust 3.jpg Buick exhaust 2.jpg Buick exhaust 1.jpg
  12. Thor1
    Thor1
    Gosh, that is pretty!
    brEad, loudbang and rockable like this.
  13. Who is doing your chrome work?
  14. rockable
    rockable
    Advanced Custom Chrome in Erie, PA. Chris Waldemarson. Tell him I referred you, please. He has done 3 vehicles for me and does excellent work. They also do pot metal, which a lot of platers won't touch. His pricing is in line with other quality platers.
  15. john W.
    john W.
    SAHHH-weet!
  16. rockable
    rockable
    Well, I started it up last week and I have been fixing a couple of wiring problems,, fixing leaks and fighting other problems. This is the worst startup I've ever had but I'm gaining on it. The rings aren't seated, so it's smoking pretty badly when it gets up to temp but it's running ok. Hopefully time will take care of that.
    Now, there seems to be a transmission hiccup. The reverse clutch pack isn't fully pressurizing. ****. At least I have plenty of time to work out the bugs.
  17. 1-SHOT
    1-SHOT
    from Denton
  18. rockable
    rockable
    I got all my interior panels made and got the parts I need to finish door ***embly yesterday. So, my Upholsterer can start working on the panels while I continue to ***emble and work out bugs. I love using this expanded foam PVC board for interior panels. Cuts like ****er with sheet metal shears plus you can heat it an bend it.
    ****** has to come out. Sigh.
    1207211652_HDR.jpg 1210211454_HDR.jpg 1210211455_HDR.jpg 1210211455b_HDR.jpg
    chryslerfan55, Thor1, brEad and 5 others like this.
  19. Sporty45
    Sporty45
    I like the look of that PVC foam sheet. Do you have a link to it? And what thickness do you use? :cool:
  20. vtwhead
    vtwhead
    ******? what happened to that?
  21. BJR
    BJR
    Bummer on the transmission. Will it come out without pulling the engine?
  22. rockable
    rockable
    chryslerfan55, loudbang and BJR like this.
  23. Sporty45
    Sporty45
  24. rockable
    rockable
    I believe I can remove the ****** without removing the engine. Thank God.
    A friend was supposed to rebuild it for me and he got really busy. So, he handed it off to a friend of his to rebuild. Probably a cut seal on the reverse and a stuck valve on the overdrive. They are really busy, so I will just give them time to fix it and use it in my 34 Ford. I ordered another transmission that should be hear early January. I'm not going to remove it until then.
    chryslerfan55, Thor1 and loudbang like this.
  25. rockable
    rockable
    Buy the "unmasked" board. It is a little less expensive.
    loudbang, Hang'emHigh and Sporty45 like this.
  26. Sporty45
    Sporty45
    Thanks for the tip, but what does "unmasked" mean? :confused:
  27. rockable
    rockable
    Masked has a protective clear film on it, so if you were making a sign board, it would stay clean until you got ready to apply the graphics.
    loudbang and Sporty45 like this.
  28. Sporty45
    Sporty45
    OK, I get it now. I didn't see that listed on the site as an option though. Is it something you just need to ask when you go to the store? I noticed that the store near me says they are a wholesaler. Not sure they will do walk in sales :(
    chryslerfan55, rockable and loudbang like this.
  29. v8flat44
    v8flat44
    Stunning ! What a build. So good to see that engine in that car too. WOW !
  30. Do it Over
    Do it Over
    from NYC, NY
    Incredible work. I find it inspiring. Gonna go work on my 5W tomorrow.
    rockable likes this.
