Technical 1949 Ford Custom cranks for only a second?!
Discussion in 'The Hokey Ass Message Board' started by askforjonny, May 15, 2021.
  1. Doublepumper
    Doublepumper
    from OR-WA, USA
    For the door issue, check for worn striker plates....very common to find them worn out.
    askforjonny likes this.
  2. jimmy six
    jimmy six
    Glad you got it but you still shouldn't swear at it...it will come back on you...
    '34 Ratrod and askforjonny like this.
  3. manyolcars
    manyolcars
    Its still not turning over well. Are you using 6V battery cables? It matters. 12V cables will do exactly what yours is doing. I hate 6V systems and suggest going to 12 volts. When you do, leave the 6V starter and use a modern Bendix. You will be happy.
  4. Onemansjunk
    Onemansjunk
    from Modesto,CA
    When I was 15 dads 41 Ford PK used to crank slow like yours . Parked it on downhill slopes if available. We could push start it faster. One day while push starting on flat ground I got my foot to far back and the rear tire pulled me to the ground hard. Tire walked right over my leg. At 15 we just laughed and shook it off.
  5. F-ONE
    F-ONE
    from Alabama
    Congratulations.
    The first thing I would do right now is...
    nothing.
    Since it cranks and runs, let it run, let the rings seat. Break it in right and most likely it will loosen up. Try this first.
    1949 was a one year only door latch. It can be fixed, it just takes good parts and patience. Oh, seatbelts are always a good idea.
  6. askforjonny
    askforjonny
    I Have a Modern Bendix sitting on the garage floor. I couldn't get it to fit into the housing... So I used the old Bendix from the smoked starter.
  7. askforjonny
    askforjonny
    Good Advice. That was the plan. We got the engine bay rewired. Now I need to figure out. why no power inside the cab, No break lights. Also, None of the doors close...........
  8. askforjonny
    askforjonny
    We made our own cables with some copper 1/0 we had laying around. Perks of the electrician career.
    I'm 100% sure the timing is off I don't have a dwell meter. However I did just order the electronic ignition for the 6v positive ground.
    Once I get the old ***** back on the road I will tackle the 12v conversion. :)
  9. jimmy six
    jimmy six
    Your swearing at again... not a good idea...they just know?:(
  10. askforjonny
    askforjonny
    Where do you get the repair parts for the latches?
  11. 210superair
    210superair
    from Michigan
    Eighty degrees when I tell dis ***** please, raise up off deez n-u-t-z, cause you gets none of these.
    At ease!
  12. askforjonny
    askforjonny
    Hahahah
    210superair likes this.
  13. 210superair
    210superair
    from Michigan
    Man I swear at my motors all the time. Badly. They love it.
    Any shots of the rest of the car? Glad you gotter runnin.
  14. askforjonny
    askforjonny
    Don't have any pics on the cell. 49 fordoor.
    Newer interior just needs paint and some tires :)
    Aside from everything else not working.
  15. F-ONE
    F-ONE
    from Alabama
    Everybody's favorite auction site .:rolleyes: Look for NOS stuff.
    I would consult the shop manual. There is an "art" to adjustment. Likely the reason the doors do not shut is someone has monkeyed with it......Ahhh It's a pain in the ***.
    Shoebox Central may have these off their collection of parts cars.... No joke, I would give them a call. They may can steer you to a source and give some advice.
  16. askforjonny
    askforjonny
