Technical 1950 chevy styleline
Discussion in 'The Hokey Ass Message Board' started by mcyunger, Sep 26, 2015.
Tags:
  1. mcyunger
    mcyunger
    we have some questions about our 1950 chevy styleline with a 216. is the 216 a bad engine because of the type of engine bearings and oil system? can it be updated? is there a more popular engine swap? is the front suspension worth keeping and does it need any upgrades or tear it out and put in something different?
  2. gimpyshotrods
    gimpyshotrods
    Suspension is fine. A full-pressure insert bearing 235, or 261, is a bolt-in.
  3. gimpyshotrods
    gimpyshotrods
    That said, if you have a 216 that is running fine, be nice to it, drive on.
    samurai mike likes this.
  4. HUSSEY
    HUSSEY
    I had a 52. I replaced a couple of worn components in the front suspension and it went down the road just fine. Also, had a babbit bearing 216, no problems with it either. I don't think I would put the money into rebuilding that motor but wouldn't swap it out if it ran fine.
    53 w/ a Powerglide and all 54 forward had the full pressure with the insert bearings. 53 and 54 were side-mounts, I think they went back to front-rear mounts in 55.
    The Filling Station had a great article on these engines but I can't seem to locate it.
  5. 56sedandelivery
    56sedandelivery
    There are some improvements that can be made to the 216, such as insert bearing conversion for the rods ($$$), and it seems to me there's a way of converting to full pressure also (I'm probably wrong on that), and updated HEI ignition conversions. I think the 80 to 90ish HP of the 216 is a biggest downfall. With the costs involved of these older engines, you might as well start looking for a 261 now, they all cost about the same for parts/machine work. ChevyTalk.Org is where you'll get the most accurate information in the 49-54 forum as there are some
    "old time" Chevrolet mechanics there. Most guys want to get away from the 4.11:1 rear end gearing, and swap to the 3.55:1 the automatic equipped cars came with. The 49-54 cars share essentially the same front suspension as the 55-62 Corvettes. I know there are many guys who have their hearts and souls in the 216-235-261 engines, but personally, I'd lean in the direction of the later style 194-215-230-250-292 sixes. Seven main bearings as opposed to four, more HP, better parts availability, and superior oiling are just some of the selling points. But what do I know? We went the V-8 route with the 51 Business Coupe after I gave the car to my nephew. My original plan was the later six, stock 3-speed trans/torque-tube rear end, and I had ***embled all the parts needed for the swap. I sold all that to a fellow HAMBER, and now I'm putting another kit together for future sale. For a while, the 49-54 Chevrolet cars were being referred to a "Rockstars" here on the HAMB, but that term seems to have died out; I'd like to see it brought back. These are just cool cars. I am Butch/56sedandelivery.
  6. mcyunger
    mcyunger
  7. Keemo
    Keemo
    I wanna do a 250 ci swap for my 50' deluxe. But am told it's longer than the 235. Don't what to do any radiator mods. Might have to go with a V-8 swap ☹
  8. samurai mike
    samurai mike
    I've put thousands of miles on 216s. it's not a race motor, nothing wrong with them if driven easy.
