Projects 1950 Chopped Chevy Sedan Delivery
Discussion in 'Traditional Customs' started by RMONTY, Jan 15, 2016.
  1. 1-SHOT
    1-SHOT
    from Denton
    I broke a 1/4 gl*** in a Ford Probe about 35+ years ago and it cost me over $1,100 then. I put my hand thru it when I was installing it didn’t have the line up pin properly located and when slapped with the palm of my hand to set it, it shattered into what looked like salt rocks
  2. RMONTY
    RMONTY
    Sounds like it was tempered gl***. I slung a rock with a weedeater into the side window on a 89 or 90 model Ford Ranger once. I found gl*** EVERYWHERE in that truck.
    guthriesmith likes this.
  3. 325w
    325w
    GoJo hand cleaner works great for gl***/rubber install.
    loudbang, RMONTY and Dick Stevens like this.
  4. 1-SHOT
    1-SHOT
    from Denton
  5. 1-SHOT
    1-SHOT
    from Denton
    In the newer cars Temper gl*** is used in everything but the windshield
    RMONTY likes this.
  6. '51 Norm
    '51 Norm
    from colorado
    Tempered gl*** was used in the corner windows of the Chevy AD pickups in the '50s. So, it is traditional.
    SS327, Okie Pete and RMONTY like this.
  7. RMONTY
    RMONTY
    Trevor and Saul showed up this morning and we did some wiring, and started ****oning up some stuff under the dash so I could get the firewall pad in and get the Vintage Air evaporator hung under the dash permanently. We got the windshield wipers working and had to knock off so Trevor could go get some POS plastic off topic junk. I let him borrow my trailer but he earned rights to the trailer years ago by helping me rebuild it. The wiper motor is a Newport Engineering unit with intermittent wiping and the "park" feature. Easy and neat, clean install on that motor. Works excellent!
    https://youtube.com/shorts/Oz8yXzwoS1k?si=c42x0vfmOTuI_JjT
    Deutscher, Jrs50, drdave and 6 others like this.
  8. RMONTY
    RMONTY
    Doing all the little things needed along the way. Made a bracket to hold the drier for the a/c system. Cut all the hoses to length and am headed over to see Mike at Sachse Rod Shop to get them all crimped. Then its just a matter of a little bit or wiring, oil up the o-rings, snug the lines up tight, pull a vacuum and charge the system up. Don't need the a/c at the moment but it won't be long before summer is here. I hope to drive the car to Stray Kat in May. 20260210_100749.jpg 20260210_103612.jpg 20260210_111716.jpg 20260210_111733.jpg
  9. drdave
    drdave
    Getting closer!!!!!
  10. atch
    atch
    I'll be looking for you and your car in Dewey. If you see a white haired white bearded fella in a lawn chair next to Clarence say hi. I used to very seldom hang out around my own stuff 'cause I was walking around looking at all the other cars. However, age is catching up with me so I sit more and more as time goes on.
  11. RMONTY
    RMONTY
    Have you got Clarence fixed? I saw a while back he tried eating a trailer tire. I looked for you last year but you must have been out roaming. Hopefully I can catch up with you this year.
    Okie Pete and drdave like this.
  12. atch
    atch
    Clarence is in the bodyshop and should be back home sometime in March.
    Okie Pete, i.rant, 1low52 and 2 others like this.
  13. RMONTY
    RMONTY
    Trevor and Saul showed up "bright and oily" this morning and we got to work. Within a couple of hours we had 29 degree air blowing out of the Vintage air system, of course it was rather chilly out this morning, like 45ish degrees. We then mixed up a batch of epoxy primer after doing a final scuff on the parts of the car that we hadn't primed yet. By the end of the day the car is finally sealed and primed. Now to make it look nice from 50' to begin with, or 50 mph o_O:cool:;) 20260222_123559.jpg 20260222_123625.jpg 20260222_164718.jpg 20260222_164729.jpg
  14. Lone Star Mopar
    Lone Star Mopar
    Looking good Robin !
    RMONTY and guthriesmith like this.
  15. atch
    atch
    I'll be looking for thiks thing in Dewey. The outside color might change but I bet the seat will still be the same.
    RMONTY, Dick Stevens and guthriesmith like this.
  16. RMONTY
    RMONTY
    I doubt the outside color will change much by May. I still have a lot of makeup to put on this old heap before it gets color. Im focusing on mechanical stuff right now so i can at least drive the damn thing after 10 years since starting this project and getting all the bumps and scuffs and ooop'es out of the way before paint. Thats just my approach, I'm sure there are many other approaches i dont know of lol!
    drdave, SS327, Okie Pete and 2 others like this.
  17. RMONTY
    RMONTY
    Trevor and Saul came over yesterday to work on some gates for Trevor's shop fence. We rented a skid steer last weekend and opened up th we fenceline by his shop. Took out some trees and pushed some dirt around to make his shop more accessible. It is hotttt here in Texas and it made sense to build the gates in my shop as it is air conditioned and we are still working on getting power hooked up to Trevor's shop. But I digress. This post isn't about off topic gates and ****. We were headed to lunch, so I told the guys to hop in the Sedan Delivery to go to lunch. I wanted to check the speedometer against the one that comes up on MAPS on everyone's phone anyway. Trevor decided to make a short video of us turning onto the State Hwy. The video is not very long but its proof that the old car that many skeptics thought would never see the road does in fact runs pretty well for an old Frankenstein jalopy! The a/c even helped a little considering there is no insulation in the car, or windlace/door seals yet.
    SS327, patman, 1low52 and 4 others like this.
  18. guthriesmith
    guthriesmith
    Looks like it runs pretty good! :cool:
    RMONTY likes this.
  19. Okie Pete
    Okie Pete
    AWESOME love the sound of the exhaust
  20. RMONTY
    RMONTY
    It will get out of it's own way for sure! Its not going to impress anyone at a dragstrip but she is a cruiser for sure. 70-75 mph all day long. Just right for the 4 hour drive up to Dewey in September hopefully!
  21. RMONTY
    RMONTY
    Thanks Pete! Trevor says it sounds like a low flying airplane. I said that is EXACTLY the sound I wanted!
    Okie Pete likes this.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    Love the sound of a six... sounds like it runs great!
  23. TrailerTrashToo
    TrailerTrashToo
    Okie Pete and guthriesmith like this.
  24. RMONTY
    RMONTY
    Thats even better!!! Gives me some more time to take a few longer shake down runs!
  25. patsurf
    patsurf
    sounded like butch leal driving....!
  26. atch
    atch
    ...and May.
    Outback, Okie Pete and guthriesmith like this.
  27. RMONTY
    RMONTY
    HA! The car is funny looking, but not a funny car!
  28. RMONTY
    RMONTY
    Yep....wasnt able to get it there in May....I made it but the car just hadnt been shaken down enough. It was great meeting you there tho Atch! Hopefully Clarence will be out of Paint/Body Shop Jail by then if he isnt already.
  29. drdave
    drdave
    Fantastic Robin!!! Sounds great!
    Okie Pete, guthriesmith and RMONTY like this.
  30. RMONTY
    RMONTY
    Thanks Dave...rowing through the gears is a helluva Lotta fun but once you hit 5th it takes a minute to push it on up to 85mph. Hahaha. I just need to get some insulation in it. Its like driving down the road in a 55 gallon barrel. :eek::confused::cool:
