1950 Ford 4 door
Discussion in 'Cars For Sale' started by 123, Aug 31, 2024.
Tags:
  1. Custom Effies
    Custom Effies
    from Seattle
    City: Renton
    State: Washington
    Price: $6500
    Too many other projects and lost interest in this one.
    1950 Ford Custom (4 door)
    Rebuilt 40 over 302
    HEI ignition
    B&M flexplate
    AOD transmission (overdrive automatic)
    Lokar trans mounted shifter
    Lokar throttle and kickdown cables
    Custom made driveshaft
    600 cfm Edelbrock carb
    Edelbrock intake
    8" rear end rebuilt with posi
    4 wheel disk brakes
    Fatman drop spindles
    Aerostar front coils
    Shoebox central Upper control arm relocation kit.
    Shoebox central steering linkage kit
    Volvo manual steering box with custom bracket
    Champion aluminum radiator with flexlite fan
    Remote mounted trans cooler
    EZ Wire 21 circuit wire harness, 12 volt
    GM alternator
    Mojave heater
    Dual exhaust with cherry bomb mufflers
    Previous 2 paintjobs sanded off down to factory primer and sprayed with flat black.
    Front floors patched with 16ga steel.
    Aftermarket trans tunnel was split and raised 1" to clear transmission. Currently sheetmetal screwed in place but can be easily welded in. Was going to weld it in once everything was finetuned and it got a real test drive.
    Car was originally from Napa Valley, CA and has/had very minimal rust. There are a few small spots in the body that could use a patch. Floors had minimal rust and it wasn't into the inner rockers at all.
    Any gl*** that needs replacing is flat and cheap. Rear window is fine. Has a new windshield gasket but needs new gl*** (ebay $125).
    All door & window trim is in the trunk.
    Starts up, runs, drives and does burnouts but is still a "project". You could drive it but I would trailer it.
    You could spend a few weekends knocking out the small things and have a nice driver.
    Clear Washington state ***le in my wifes name.
    Asking $6500 FIRM
    NO TRADES!
    Located in East Renton highlands. 20231017_153320.jpg 20231017_153320.jpg 20231008_155956.jpg 20231017_153334.jpg 20231008_155934.jpg 20231008_155926.jpg 20231008_155918.jpg 20231007_172730.jpg 20231017_153320.jpg 20231008_155956.jpg 20231017_153334.jpg 20231008_155934.jpg 20231008_155926.jpg 20231008_155918.jpg 20231007_172730.jpg 20231007_141948.jpg 20231007_140347.jpg 20240828_182553.jpg 20240828_182541.jpg 20191005_182835.jpg 20180711_191757.jpg 20161001_175142.jpg 20160914_211150.jpg
    https://www.dropbox.com/scl/fo/m2yy7y1u5fa0w432qlckj/h?rlkey=d6au0kz8n0653mzg65ar8k6e4&dl=0
  2. Custom Effies
    Custom Effies
    from Seattle
  3. Custom Effies
    Custom Effies
    from Seattle
  4. Custom Effies
    Custom Effies
    from Seattle
