1950 ford 8 ba fuel pump problems
Discussion in 'The Hokey Ass Message Board' started by Toddjg, May 16, 2010.
  1. Toddjg
    Toddjg
    from florida
    ok then its a bad pump since it works it just doesn't work at higher rpm.
  2. 19Fordy
    19Fordy
    Could be. Also check your oil level to see if it smells like gasolene.
  3. Toddjg
    Toddjg
    from florida
    ok this is driving me nuts new fuel pump new fuel pump push rod. it runs fine at idle it runs up to 3rd gear then cuts out stops running won't start. carb fuel bowl is empty but there is fuel in fuel pump fuel bowl.
    so if there is fuel in fuel pump fuel bowl is the problem carb ? what would cause carb to quit on higher rpm?
  4. thesupersized
    thesupersized
    the gl*** fuel bowl on the pump will never go empty as the fuel pump ****s the gas from the top of the fuel bowl
  5. Toddjg
    Toddjg
    from florida
    ok so what could be wrong ? whats left to check?
  6. Toddjg
    Toddjg
    from florida
    i thought it might be a vacuum leak since i noticed the manifold vacuum port that i had pluged became un plugged so i put a br*** fitting in there. I just got back from pushing car home by myself it got half way around block then quit.
  7. dirthawker1313
    dirthawker1313
    id check 2 things. first take the fuel sending unit out of the tank and see if you might have a clog where the fuel line enters the tank. mine had a screen that was clogged full of gunk. theres an access door in the trunk. if thats clear then id look for pin holes in the fuel line. i had both problems on mine and it caused similar problems as you are having. a little pin hole in the fuel line can cause a big headache.
  8. Mike51Merc
    Mike51Merc
    Check the gl*** bowl and make sure it is seated and sealed on the pump. This is a secret place for a vacuum leak.
  9. Toddjg
    Toddjg
    from florida
    would a vacuum leak cause the problems that i have said.
  10. Toddjg
    Toddjg
    from florida
    engine is bogging when i get on it before it dies. could it be the power valve?
