Projects 1950 Ford Business Coupe build
Discussion in 'Traditional Customs' started by SinisterSleds, Apr 29, 2025.
  1. SinisterSleds
    SinisterSleds
    from MA
    Thanks.
    I have spent most of my career working for and around high end restoration shops (most have won Pebble Beach on multiple occasions) so my reference is askew.
    I remember being at a show with a buddy and he made the comment that the car was good but you could see the pitting of the back side of the re-chromed bumper in the reflection of the paint of an otherwise near flawless restoration.
    I stopped looking at others cars with that attention. Now it just needs to look cool. I'm only critical with my own work now.
  2. Rand Man
    Rand Man
    Picking cars apart has been a thorn in my side for years. Maybe 25 years ago, I had just got my 57 Chevy on the road and had joined a car club. This old fart came along at just a Friday night gathering at the Sonic. He was picking apart every little chip that was wrong with it. Each of which I was well aware of. I was just proud of all the hard work I had done. Of course his was still in the garage and I don’t think he ever finished it. **** that ****, life’s too short. I just don’t participate with those kind of dudes anymore.
  3. 210superair
    210superair
    from Michigan
    Man, yeah, looks really great! When my shoebox seats wear out I'll drop it off! Lol.
    Keep up the good work!
  4. ffr1222k and SinisterSleds like this.
  5. SinisterSleds
    SinisterSleds
    from MA
    Agreed. Once I started to just look at the big picture at shows it became a lot more enjoyable.
    Thank you.
    Thanks. I will. Things will slow down a bit again. I need to catch up and find some spare $ to move forward. I may get a chance to get the car to the shop and move the engine and trans back so the manifold will clear but we'll see.
    Next purchase will be the headliner and rear window gasket. I need to find or make some coupe headliner bows first.
    ffr1222k, lurker mick and 210superair like this.
  6. SinisterSleds
    SinisterSleds
    from MA
    Progress has been on a little bit of a hold so recently I have been acquiring missing and needed parts to move forward when ready.
    One of the things that I was not able to recover, and one of the next parts of the puzzle, was the headliner.
    I was able to find the bows and a lost hinge. The bows were rusted so I went over them with some sand paper, ospho and brushed on some epoxy. Prior to removing the #s i made this map to keep the bows in order. Now I will label them and hopefully order the headliner soon.
    I also ordered a few more parts and awaiting their arrival.
  7. SinisterSleds
    SinisterSleds
    from MA
    Another piece(s) of the puzzle showed up today.
    While not generally a fan of moldings I was too lazy / ran out of time to fill the holes for the moldings.
    I felt the factory moldings were too big. So I went on the search for some new stainless moldings. I finally landed on a set of moldings for a Volvo 145. They are about 1/2" wide vs my target of 3/4 vs the originals at about 1 1/8".
    I will have to shorten the door moldings and I may decide to lengthen the 1/4 moldings. The plan is to eliminate the fender moldings and replace them with a crest.
    In order to accomplish the switch i will need to weld the moldings.
    I gave it a few minutes before leaving for the night.
    First I cut a short piece for a trial.
    Next is welded the 2 pieces with some .030, 308 rod at 25 amps.
    This was followed by a quick file and some layout dye. To highlight the problem areas.
    After a couple rounds of sanding (320, 400, 600)
    Then I buffed the area with some stainless polish and 3" grinder. Then some red rouge.
    I'm happy with the results.
    The black mark is the joint.
    Comparison of OE to new.
    Okie Pete, dwollam, ffr1222k and 4 others like this.
  8. SinisterSleds
    SinisterSleds
    from MA
    It took about 5-6 hrs but the door moldings are complete.
    I will measure the 1/4s tomorrow and decide how much longer those will be.
    Adding 10" to the rear moldings.
    After about 10-12 hrs I have 4 pieces of side trim.
    Okie Pete, dwollam, BigRRR and 4 others like this.
  9. SinisterSleds
    SinisterSleds
    from MA
    Pair of the last st of the body modification parts came in today.
    Stripped one of the fenders before I left for the evening. Did not strip the bondo but the metal underneath it looks good.
  10. SinisterSleds
    SinisterSleds
    from MA
    Been spending a few hrs here and there on misc projects on the 50.
    Stripped the fenders. Found the typical rust i have been finding under the old primer. 20251006_181037.jpg 20251006_181042.jpg
    Against my better judgment I broke my rule on this project of not uncovering problem areas and stripped all the bondo out of the fenders.
    Found a double welded lap joint under 1/4" of bondo.
    I have been cutting through the outer joint and grinding off the weld. Then splitting the overlap with the air saw followed by grinding off the back weld. 20251007_164754.jpg
    Once completed i can **** weld the 2 pieces to be metal finished.
    Got as far as tacking them this AM.
  11. SinisterSleds
    SinisterSleds
    from MA
    I also found some time to clean up the rings and metal finish the dents out in prep of installation.
    Couple pics of the difference between tacked and douple lap weld.
  12. SinisterSleds
    SinisterSleds
    from MA
    Well, like a kid at Christmas time molding clips arrived in the mail today.
    When I got home I couldn't resist mounting the door moldings. 20251008_185236.jpg
    Only way I could be more happy would be if the doors were on, had access to the 1/4s and could see the moldings in the sun.
    Spent some time final welding the bottom of the right fender and a quick metal finish. It's still a bit low but less than 1/8 skim will straighten it right out.
    Finished the fender over the weekend. Still going back and forth on which frenched headlight treatment I prefer.
    In any event I sprayed some epoxy on the fender which is close to finished.
  13. SinisterSleds
    SinisterSleds
    from MA
    The beginning of something cool or abject failure.
    Deutscher, Okie Pete, dwollam and 3 others like this.
  14. ididntdoit1960
    ididntdoit1960
    from Western MA
    Judging by your success thus far, I doubt failure is in the cards....
  15. SinisterSleds
    SinisterSleds
    from MA
    Thanks, guess we'll see. I'm often unsure of the outcome either in execution or if I will like the outcome.
    Spent a little time on the mill this AM.
  16. SinisterSleds
    SinisterSleds
    from MA
    Little more progress.
    Awaiting some more material so I can finish up.
    A little sneak preview: with setback. Bottom of my hinge is flat. Factory is angled. I will have to make some wedges in order for these to work or I may choose to make another set. These might be shorter than I preferred, so, I'm guessing these will be remade correctly.
  17. SinisterSleds
    SinisterSleds
    from MA
    Couple little parts done.
    I still plan on making hinges but need to make another set. I'll use the originals painted as a place holder.
    Also I cut and welded the bottom of the left fender primed it while I decide how to finish the headlights and fit them.
    Hopefully I'll roll it out of the garage tomorrow and hang the doors and any other panels and parts I can fit. Clean up and grab anything that I can work on over the winter. 20251107_165923.jpg
