Customs 1950 ford front end adjustment
Discussion in 'The Hokey Ass Message Board' started by aces52, Feb 11, 2024.
Tags:
how to1950 ford front end adjustment
Poll closed Feb 18, 2024.
  1. adjust
    0 vote(s)
    0.0%
  2. how to
    1 vote(s)
    100.0%
Multiple votes are allowed.
  1. aces52
    aces52
  2. gene-koning
    gene-koning
    By the factory service manual procedure?
    Missing much information.
    What is the suspension? Are there wore out parts? What is your issue? Has it been done recently?
  3. badshifter
    badshifter
    Like this:
  4. On a stock front end the castor is adjusted by turning the threaded lower outer bushing to shift the bottom of the upright forward or rearward. Camber is adjusted by rotating the eccentric upper outer bushing. If the front end height has been altered these adjustments may not be enough to get it to spec. Toe in is adjusted by changing tie rod length by adjusting tie rod sleeves.
    D type likes this.
  5. Mr48chev
  6. @Center of the Galaxie pretty much covered it. Caster is adjusted by the threaded bolt connecting the lower upright to the lower a-arm, or the threaded rod connecting the upper a-arm to the frame. The camber is adjusted by the eccentric bolt holding the upright to the upper a-arm. Special wrenches are required (I made my own). As suggested, a factory service manual is required. This only pertains to stock suspension. Things such as dropped uprights or coil springs (I have both) changes all this. You are not offering much info.
  7. aces52
    aces52
    Sorry but when I adjust it to a 1/4 toe in and then move it around it goes out of adjustment again ?
  8. It sounds like you may have something in the front end that is worn and affecting your alignment. Or perhaps something isn't bolted securely and moving the steering alters the position everything was last in. It sounds like a thorough inspection is warranted.
  9. flatheadpete
    flatheadpete
    from Burton, MI
    Car, truck, tractor?
