1950 Ford Gasser
Discussion in 'The Hokey Ass Message Board' started by custom300, Jan 26, 2010.
  1. 54fordgasser
    54fordgasser
    from Kansas
    Awesome man! I know how that works. One thing at a time. I love shoebox g***ers. I'm sure you saw the lime green one that used to be on here?
  2. zach from ny
    zach from ny
    from New York.
  3. custom300
    custom300
    G V Gordon I don't have any other pictures from the day I put the straight axle under my car. I used a 46" wide straight axle kit from Thompson's Garage. The front of the frame is stock how Henry made it. I just removed the original a-arm set up, used universal GM side motor mounts and modified the original transmission mount.
  4. G V Gordon
    G V Gordon
    from Enid OK
    OK, that tells me what I wanted to know. The one pic looked like you may have cut part of the spring pocket to make the side rail straighter. Good looking Ford.
  5. 32csr
    32csr
    from cincinnati
    Another well built g***er from Cincy....good job beavis:D
  6. Falcon Gasser
    Falcon Gasser
    Kevin its the first weekend in June 4th to 6th.
    Jon
  7. custom300
    custom300
    Jon,
    Thanks I looked into it that is my weeked to work at the hospital but I will try to trade it out. Since that is only about 4 1/2 hours from my house.
    Kevin
  8. G V Gordon
    G V Gordon
    from Enid OK
    Another quick question. Did you use the original steering box and arm?
  9. nutajunka
    nutajunka
    On the one video getting squirrely you can see daylight under both back tires, reminds me of a car I had, but it would jump up 3 times before settling down. Shake the beegeefeers out'a ya...:D
  10. custom300
    custom300
    NutaJunka,
    It will jolt you in the seat pretty good. But a friend of mine in Ill. told me to try and put longer travel shocks on the back. Since I might be out of travel with the stock replacement shocks when the car launches and that could cause the car to pull of the ground.
    Kevin
  11. smarg
    smarg
    Thing looked like it ran good in the videos.
  12. custom300
    custom300
    G V Gordon,
    I used the stock steering box and heat and bent the pitman arm down to let the tierod have more clearance on the oil pan and the give a better angle to the tie rod end. The pitman arm side wanted to bind up a little when turning.
    Kevin
  13. nutajunka
    nutajunka
    Are you running stock leaf springs in the rear?
  14. custom300
    custom300
    Nutajunka,
    I have new 2" wide wagon/woddie springs from Posies. I took the three small leafs out and plan on clamping the leafs. In the video I had all 8 leafs in the springs.
    Kevin
  15. 51 Hemi J
    51 Hemi J
    Shes a Honkin' for sure! Very cool man!​
  16. Butch M
    Butch M
    look's like fun... cool car.
  17. custom300
    custom300
  18. edweird
    edweird
    A friend just bought this one from va. 455 buick power. anyone know this car?
  19. Deuce3wCpe
    Deuce3wCpe
    from New Jersey
    Hey Custom/3 , thought you might enjoy this vintage shot. Taken at the long gone Flemington Dragway, NJ - Oct 1964.
  20. freebird101
    freebird101
  21. custom300
    custom300
    Duece3wcpe
    Thanks cool photo
    Kevin
  22. Carfanatic
    Carfanatic
    LOVE IT, LOVE IT, LOVE IT. Be still my heart. Awesome car. Building a 50 g***er myself. Been waiting 4 years for the guy to sell me the car. Not to many pics of those on line as g***ers. Nice to see another one. Definitely inspirational. Loved the video. Where did you get your headers, and how well did they fit? Drive the HELL out of it.
  23. breeder
    breeder
    turned out kick***!!!
  24. custom300
    custom300
    Carfanatic,
    I got my headers from Thompson's Garage 513-237-4428. They fit well clear body mounts off firewall by about 3/4 to 1 inch on p***enger side and about 1 1/2 on driverside. Made my own turn down bolt on tips to point towards the ground instead of into floor pan.
    Kevin
  25. Carfanatic
    Carfanatic
    Those headers look like the ones I have on my truck in the pic. Speedway called them fat fendered ford headers. I thought they might work but wasn't sure.
  26. custom300
    custom300
    Those are the headers I believe they where listed for 46-48 fords
  27. 1oldrat
    1oldrat
    My uncle and I are building a 49 coupe.65 327 .060 with 11:1 pistons .510 lift cam.2.02 heads backed by a 62 t10 to a 10 bolt with 3.73 gears.I love the look of your car,He wants to straight axle it and when I show him this it will be a done deal.What axle setup did you use?
  28. custom300
    custom300
    1oldrat
    I used the 46" straight axle kit with disc brakes from Thompson's Garage. It was $1275 all I needed was wheels and drag link. Call Steve he will help you out 513-237-4428
    Kevin
