Hot Rods 1950 Merc help
Discussion in 'The Hokey Ass Message Board' started by Kevin Proper, Apr 29, 2021.
  1. X38
    X38
    In the case of these cars, that would be the custom look.;)
    There's a whole (long) thread on 49 -51 Merc customs.
  2. Hoses are cut to length by you. The screw clamps don’t work as good as these in my opinion.
    the lowering will be easy to figure out what’s done on a lift. Look for spacers under the front coil spring mount on the lower control arm.
    Collapsed coils if torched.
    The back could be missing leafs or a lowering block.
    Mercs look great chopped. There are a lot of bad chops. The Merc on American Graffiti is the poster child for a bad chop. Study it, don’t repeat it.
    Pist-n-Broke likes this.
  3. First up that's a Great looking 50 Merc If I had it I would leave it
    I have a lot of Chopped Merk's & the 50 merc. in my avatar is not
    Chopped & I could have had it done but I didn't.
    The only thing I have done is to put a SBC in it
    I left the Drum Brakes the Work Great & the Merc weight is 35 hundred Lbs.
    Just my 3.5 cents
    nochop and guthriesmith like this.
  4. Kevin Proper
    Kevin Proper
    What is an SBC? I racked my brain for that acronym and can't figure it out.
    Kevin
  5. Small Block Chevrolet, the Generic replacement motor for a Flat Head. Sad isn't it?
  6. warhorseracing
    warhorseracing
    from cameron wv
    Mr. Proper.
    Leave the Merc flat head as it is already factory stroked.
    Aussiepete. and Pist-n-Broke like this.
  7. I put this Chevy Engine & Trany in my Merc. in 47 years ago
    when my 63 Chevy Impala was hit head on & Bent the Frame
    The only thing that was good was the engine & ****** & a few other things
    327/300 hp with the Powerglide Trans.
    Just my 3.5 cents
    Live Learn & Die a Fool
  8. brady1929
    brady1929
    Beautiful Merc
  9. banditomerc
    banditomerc
    Great looking Merc. If it was mine ...go thru all critical components as mentioned and drive it till the wheels come off..
    Sent from my SM-T560NU using The H.A.M.B. mobile app
