Projects 1950 Mercury coupe build “Worm Burner”
Discussion in 'The Hokey Ass Message Board' started by VintageConcepts, Feb 11, 2022.
  1. alchemy
    alchemy
    I highly recommend you hang your doors in the openings to check the gaps before you weld any more parts in that body. I personally think you have about one tenth of the bracing needed to keep it rigid with the whole bottom half removed. Maybe you will get lucky.
    Also be aware that every weld you make will actually shrink as it cools, so putting a dozen more welds in place as you replace those rockers and floor will be a dozen more shrink points. As we all become used to seeing even door gaps of 3/16", how many shrinks does it take to mess that measurement up?
  2. VintageConcepts
    VintageConcepts
    Thank you
  3. VintageConcepts
    VintageConcepts
    Oh yes. I didn’t take a picture but both sides had doors on them, and I did one side at a time. P***enger side door was slightly off and I adjusted it with a strap, then welded. I was paranoid about the whole thing shifting so I didn’t rotate the body and would crawl underneath to weld.
    As far as bracing and shrinking, thats a really good point I guess we’ll see in the end. Boy that would ****.
    Okie Pete likes this.
  4. VintageConcepts
    VintageConcepts
    5754E510-30DF-49D1-8D5E-1E460D55D4D6.jpeg 10049553-2FAD-462E-8FB6-1C7D224818E7.jpeg 93E94930-669C-4D7D-A0E0-29CF649BDA57.jpeg 193B1FCD-FCB6-446D-BD7E-638599094DBA.jpeg Front is too high. I could see how channeling the car would have match my ***le. At least the door fits great with slight adjustment. Bottom bracket needs to be welded.
    I don’t like how front bottom corner which I did years ago doesn’t have proper line. Will have to cut it out and redo.
    Quarter panel needs step radius added and welded. Still not sure how I’ll go about that. Pipe or bead roller or make a buck.
  5. Mopar Tony
    Mopar Tony
    Who's brake system are you running now? Would you sell your old firewall mount brake set up?
  6. Rand Man
    Rand Man
    Looks like you’re doing a great job.
    VintageConcepts likes this.
  7. VintageConcepts
    VintageConcepts
    Hey sorry for delayed response. I made a bracket to hold the booster and welded it to a frame. The brake pedal is mounted to the stock location. Wilwood master with remote access.
    The firewall unit is a universal cut to fit but I might use it on the Cadillac.
    I pulled the Caddy out to get some work done. Once the bottom is done I’ll jump back on the Merc. Oh and gotta go to work once in a while so sorry for delayed posts.
  8. VintageConcepts
    VintageConcepts
  9. VintageConcepts
    VintageConcepts
    Some Caddy progress New bead roller is amazing im no pro but the right tool definitely helps 199C2141-FA73-4EBF-8559-C189170C0C60.jpeg 4B802D86-55D6-45D9-A6D1-09C7A1BFA379.jpeg 794FBE26-EE81-4E91-A1ED-E10B709B3CAF.jpeg D5E2E504-3D2E-4D2D-9928-D3E55AED28D3.jpeg F831A3E8-51B4-4943-89AF-0AB72E012761.jpeg 199C2141-FA73-4EBF-8559-C189170C0C60.jpeg
  10. Rand Man
    Rand Man
    Looks like this guy knows what he’s doing.
