Projects 1950 Plymouth
Discussion in 'Traditional Customs' started by Tricky53, Feb 4, 2022.
  1. Tricky53
    Tricky53
    from Bend, OR
    Man, it's been a while. Feels good to be back on here!
    I'm going to try and do a build thread of my newest find...
    Cruising FB Marketplace, I came acros 236523679_1038344013644874_8902376701371613338_n.jpg s this ad. Something about the look of the car in this picture stopped me in my tracks!
    •Here’s a 1950 Plymouth super deluxe.
    •Runs and drives killer. •BRAND new interior, headliner included.
    •SUPER solid no rust just surface level patina. Cut, buffed, and waxed.
    •Disc brakes
    •Three speed manual
    •12v converted
    •Freshly rebuilt carburetor and distributor.
    •Recently rebuilt the front end.
    •Have over $9000 in receipts for parts and work done to it.
    •Have some extra parts.
  2. Tricky53
    Tricky53
    from Bend, OR
    Here are a few more pictures of the car in the ad...
    After calling and talking to the owner, we struck up a deal and it became mine... Resized_240655663_1038344190311523_4482402577296204998_n.jpeg Resized_239884803_1038344060311536_4017528114656312121_n.jpeg Resized_240417979_1038344030311539_321930588280088035_n.jpeg Resized_240850600_1038344316978177_1961532433202638985_n.jpeg
  3. Tricky53
    Tricky53
    from Bend, OR
    This car is awesome! It's a great driver too. Just can't really get over 50 mph.
    Future plans include:
    • correct offset mopar wheels
    • bias look radial wide witewall tires
    • NOS Dieterich Visor
    • traffic light viewer
    • steel fender skirts
    • real MOPAR spotlights
    • rebuild and hot rod the 218
    • headers w/ loud dual exhaust
    • s10 t5 swap - rear end swap
    • 2" lowered coils up front
    • 3" lowered leaf springs + 3" blocks
    • heavy duty rear air shocks
    * if I can make it happen (yetiskustoms would be the fella), I'd like to chop the top 4" in front and 6" in the rear with the stock rear window laid down and the B pillars leaned forward
    dwollam, chryslerfan55 and VANDENPLAS like this.
  4. oldolds
    oldolds
    I was with you until you put the air shocks on it.
    I would not chop it either. I do not think every car needs to be chopped.
    Just my opinion. It's your car, build it your way.
    RAK, dwollam, Steve Ray and 5 others like this.
  5. `Leave the visors for the low riders :eek:
  6. Hnstray
    Hnstray
    from Quincy, IL
    @Tricky53
    Nice find! I really like that era Mopar. I have a ‘49 2 dr, same body shell as your, different rear fenders, bumpers and grille. All minor differences. I have owned mine since 1995. I think the longest I have owned any vehicle. It was a ‘driver’ for several years….has sat for many more. Time to resurrect it. Those Mopars have really nice riding and driving suspension.
    A Jeep Cherokee rear axle…..’90 thru ‘01, correct width, 8.25” Mopar axle, from a 6 automatic Cherokees had 3.55 gears, which would be good with a trans upgrade.
    Best wishes with your project.
    Ray
    chryslerfan55, VANDENPLAS and i.rant like this.
  7. Davesblue50
    Davesblue50
    One of the most solid 50 model Plymouths I have seen in a long while. Great pick up!
    41 GMC K-18 likes this.
  8. Hillbilly Werewolf
    Hillbilly Werewolf
    Looks great!
    What's keeping you from running 50+?
    You should be able to run it up to 75-80.
    If you want a slanted pillar, have you considered getting this one cleaned up good and reselling or trading for a pre '49 Plymouth?
    There were lots of hop up parts for these engines back in the day, and still some stuff made.
    For the cheap and easy, I would ditch the little chrome air filter for a 6" one or at least put a high flow style filter in the 4" you have.
    Make sure your distributor is in good shape, has a functional vacuum advance, and that the breaker plate actually moves.
    Split the exhaust.
    Replace that rubber fuel line with metal. Iirc Vic's Dodge Garage has pre-bent metal lines for reasonable $.
  9. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Nice looker. I have had four of them in my life. Could do with another. Enjoy.
    What the Hillbilly said is true. Top speed might also be the limit of too many miles, on the motor.
  10. Pass The Torch
    Pass The Torch
    My mostly stock / original ‘50 P19 (that’s a business coupe for those of you in the back row) with the flat 6 / 3 on the tree will hit highway speeds……eventually. I’ve pushed it. It will get you there; just don’t be in a hurry.
  11. Tricky53
    Tricky53
    from Bend, OR
    I put the visor on it for a temporary "pissed off" look until it gets chopped.
    I've really wanted to have a chopped car for quite a while. This is the one that's going to get it.
    I've seen a bunch of them chopped with either a straight B pillar or no pillar at all. I like the forward lean on them. Makes them look like it's going 100 mph!
    When I'm cruising at 50, it's reading around 2300 - 2500 rpm. I'm not wanting to push the old motor too much. I'll rebuild it fresh and with a 5 speed behind it, it'll cruise 85 at a lower rpm all day.
    I've got a mini HEI distributor, 2bbl carb, headers and a few more goodies coming from Langdons...
    I'm planning on an Edgy Head and a re grind on the cam. Once the motor is rebuilt, I'll do a second carb w/dual intake and steel fuel lines...
    Should rip around pretty good at that point!
    Thanks for all the comments and suggestions! Keep em coming!
  12. Tricky53
    Tricky53
    from Bend, OR
    Hey Hnstray,
    Thanks for the heads up on the Cherokee rear end. I've been wondering what one I should be looking for!
  13. jaracer
    jaracer
    When I was about 13, I started hanging around a filling station. The owner had a son about a year younger and my older cousin was also there. It was a Standard Oil station with a small used car lot. The owner gave his son a 52 Plymouth to fool around with. The paint wasn't real good so we painted it flat black with a lot of rattle cans. There was an open field next to the station so we put a lot of miles driving around the field and practicing speed shifting. We did a lot of work on the car and it still ran even though none of us really knew what we were doing. It was a pretty sturdy old car.
    chryslerfan55, MO_JUNK and Hnstray like this.
  14. Tricky53
    Tricky53
    from Bend, OR
    That's a great story! There's definately something to be said about these old Plymouths!
  15. JMHO, but that car is too nice to cut up. Make it a reliable driver and enjoy it.
  16. choptop40
    choptop40
    ....most of us here slice and dice em...lower em , hop em up . best of luck with your new ride.........
  17. MMM1693
    MMM1693
    Very sweet score but I say no to the visor and chop. IMHO
  18. rusty1
    rusty1
    ...I'd leave as is except for the twin pipes..and radials
    F-ONE, MO_JUNK and '28phonebooth like this.
  19. I had a 53 Chrysler with the flat six and a fluid drive trans .
    I found a factory duel carb manifold with Ball and Ball carbs and all the linkages ( was originally on a dodge dump truck). And used cheap steel tube style split exhaust .
    fresh tune up , rebuilt carbs and distributor etc etc.
    I could cruise at 65-75 all day .
    they are great cars that drive well .
    41 GMC K-18 and chryslerfan55 like this.
  20. BDUB77
    BDUB77
    Nice car! I have a 50 Plymouth as well. Stock drivetrain and will do highway speeds no problem. I live in the mountains and it will do 50 headed up the mountain from the bottom. It’s not fast, but definitely has some torque.
  21. Tricky53
    Tricky53
    from Bend, OR
    Gorgeous car there BDUB77. Stance is right on! What did you do to get it to sit like that?
  22. goldmountain
    goldmountain
    I think that car would look better with a level chop than a tapered one. Check out the tapered look on half*** customs.
  23. Tricky53
    Tricky53
    from Bend, OR
    The roof is so flat on these cars that when there chopped even front and rear, it seems to make the roof look even flatter to me. I'm weird like that
  24. choptop40
    choptop40
    51 chopped.jpeg 51 chrysler..beauty IS in the EYE of thr BEHOLDER....i like em both ways...
  25. v8flat44
    v8flat44
    Tricky, that's gonna be a neat car. My cousin had 1 just like it. Rebuilt the 6, put a split manifold on it & different ignition. Too many years back to remember everything, but it sounded SO COOL & was a good runner. Have fun with it !!!!
  26. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    I believe in preserving something as nice as that car. To do something as radical as you want to would destroy a piece of automotive history that is fast disappearing. There are plenty of cars out there to make a nice hot rod out of. I am in the process of acquiring a nice '48 Chrysler that will be preserved as is.
    As for top speed, that car should keep up with most freeway traffic. I would definitely get rid of that air cleaner and run through a good tuneup. A compression check is in order, too.
    This is just my opinion and not trying to bash your ideas. Nice find!
  27. Slopok
    Slopok
    Not every car needs to be chopped, you will gain nothing by a chop on that particular car.
    leon bee, '28phonebooth and Hnstray like this.
  28. Moedog07
    Moedog07
    Great score!
    I have a '51 Coronet that my other half finds "stodgy" but I like those early 50s Mopars. You could wear a hat in those cars. I have found another thread to follow because mine is nooooo where as nice as yours.
  29. Hillbilly Werewolf
    Hillbilly Werewolf
    I believe it was Mr. Chrysler who once said ' I build cars to sit in, not piss over'
    '28phonebooth and Moedog07 like this.
  30. Tricky53
    Tricky53
    from Bend, OR
    This is great. A lot of cool cars and fellow car nuts commenting. We all have our own styles. We all have our likes and dis likes.
    I bought this car to keep and really make it mine. The things I do to it will make me happy. I don't need to worry about what it might do to the resale value...
    Choptop40 said it perfect! Nice car BTW
