Technical 1950 Shoebox need help
Discussion in 'Traditional Hot Rods' started by Scottg951, Jan 8, 2025.
  1. Scottg951
    Scottg951
    I currently have 205/75/15 Coker’s. I do have airbags and it sits pretty low. I’m looking at buying chrome Allied Supremes 15x7 but am not sure of the backspacing and offset needed. I’ve seen people say 3.5 backspacing but what about offset. Summit racing app says -12mm offset with 3.5 bs won’t fit but they don’t know I have airbags. Any input?
  2. lothiandon1940
    lothiandon1940
  3. lothiandon1940
    lothiandon1940
    Always hit the "full image" ****on.
  4. lothiandon1940
    lothiandon1940
  5. Mr48chev
    My experience says that you can't get away with a very deep reverse on wheels on a shoebox especially if it is lowered in the rear if you want to be able to change the tire without a lot of h***les. If you have access to a reverse wheel the depth you are thinking about with a tire the size you want I'd try putting it on just to see if there are any h***les getting it on or off. H***les include having to let the air out of the tire to get it between the fender and the drum. Even oversize tires on stock rim can give you a battle at tire change time. It's one thing to take the shocks loose and let the axle drop down on a hoist in the shop but a pain in the **** on the side of the road when you have to fight one out and one in.
    lothiandon1940 likes this.
  6. If you have wheels on it now that fit and work just measure them. If you have room to spare add that amount to your numbers.
  7. wheeltramp brian
    wheeltramp brian
    15 / 7 is going to be way too wide. I'd go with 5 inch.
  8. evintho
    evintho
    As mentioned, take meticulous measurements! On my '54 Customline, there's not a lot of room in the rear wheelwells. I had to roll the rear lip but I can easily stuff these Allied Supremes under there with no issues changing tires (but then, I don't have airbags). https://www.performanceplustire.com/buy-wheels-online/allied-wheel/67-supreme-chrome/ws:15x7/
    My tires are 225/60R15s. Allied does make 15"x6"s........https://www.performanceplustire.com/buy-wheels-online/allied-wheel/67-supreme-chrome/ws:15x6/ ...........I threw together a homemade wheel/tire checker that worked well, especially with the turning radius.
  9. lothiandon1940
    lothiandon1940
