Projects 1950 Styleline coupe kustom build thread.
Discussion in 'Traditional Customs' started by Devin, Jan 14, 2015.
  1. TraditionalKustoms
    TraditionalKustoms
    Yes, like @chopolds said - cut from the inside. You need to have the patience of Mr. Miyagi with cutting the gasket but it can be done!
  2. Devin
    Devin
    from Napa, CA
    I had a chance to try and get a little but done today. I just got my shrinker/ stretcher so I wanted to see if I could fabricate the belt line patch panel around the sail panel. I started by making the belt line off of the same hammer form I used in the quarter windows. ImageUploadedByH.A.M.B.1423712164.870583.jpg ImageUploadedByH.A.M.B.1423712179.319038.jpg ImageUploadedByH.A.M.B.1423712191.336332.jpg ImageUploadedByH.A.M.B.1423712222.168939.jpg
  3. Devin
    Devin
    from Napa, CA
    Then I ran this through the shrinker stretcher to bend it to the contour of the sail and quarter panels. ImageUploadedByH.A.M.B.1423712301.435729.jpg ImageUploadedByH.A.M.B.1423712313.869032.jpg
    kiwijeff likes this.
  4. Devin
    Devin
    from Napa, CA
    This worked to a certain extent but I had difficulty twisting the belt line to confirm on all angles.
  5. Devin
    Devin
    from Napa, CA
    So I took a thin strip of metal the width of the belt line and ran that through the shrinker stretcher to see if his would work better. R ImageUploadedByH.A.M.B.1423712463.935615.jpg
    This worked better but It didn't have a flange to weld to the quarter and sail panels.
  6. Devin
    Devin
    from Napa, CA
    I began making a pattern to replace the upper quarter panel and the cat walk. ImageUploadedByH.A.M.B.1423712631.219319.jpg ImageUploadedByH.A.M.B.1423712643.552493.jpg ImageUploadedByH.A.M.B.1423712665.018968.jpg ImageUploadedByH.A.M.B.1423712677.485566.jpg ImageUploadedByH.A.M.B.1423712693.802213.jpg ImageUploadedByH.A.M.B.1423712713.202711.jpg
  7. Devin
    Devin
    from Napa, CA
    This is as far as I got. I sprayed the belt line and cat walk panels with ****m to scribe where they need to be trimmed to fit together. I'm going to do my best to weld them together on my next day off I'm a little worries about effing them up during the welding process. It's going to be a ***** fringing the weld beads down. We'll see how it goes. ImageUploadedByH.A.M.B.1423712952.652393.jpg
  8. Devin
    Devin
    from Napa, CA
    Picking up where I left off; did some t******* and planishing and tacked the pieces together. ImageUploadedByH.A.M.B.1424225338.332398.jpg
  9. Devin
    Devin
    from Napa, CA
    You guys weren't kidding when you said removing the rear window was a pain in the ***. Had to use a chisel and gamer to remove the dried up gasket from the inside. ImageUploadedByH.A.M.B.1424225451.114408.jpg
  10. Devin
    Devin
    from Napa, CA
    I expected the whole window channel to be Swiss cheese and I've been looking for a parts car for a replacement channel. As it turns out, only the bottom corners are bad and the rest is pretty good much to my relief. ImageUploadedByH.A.M.B.1424225616.480927.jpg
  11. Devin
    Devin
    from Napa, CA
    I bent up a strip of steel into a "Z" to fab a new corner. I ran this through the shrinker stretcher and made a couple relief cuts. Still needs more finessing but it's getting there. ImageUploadedByH.A.M.B.1424225737.330861.jpg ImageUploadedByH.A.M.B.1424225753.636374.jpg ImageUploadedByH.A.M.B.1424225773.836707.jpg ImageUploadedByH.A.M.B.1424225785.251895.jpg ImageUploadedByH.A.M.B.1424225796.434945.jpg
    This is where I left off. I hope to finish it tomorrow.
  12. Devin
    Devin
    from Napa, CA
    Ditched the z channel and bent up a piece of angle instead. ImageUploadedByH.A.M.B.1424312504.160131.jpg ImageUploadedByH.A.M.B.1424312513.645519.jpg ImageUploadedByH.A.M.B.1424312531.009448.jpg
  13. Devin
    Devin
    from Napa, CA
    Welded the belt line to the catwalk patch. ImageUploadedByH.A.M.B.1424312585.126352.jpg
    I'm not a very good TIG welder but I gave it a shot. Some of the wider gaps I had to MIG because they were blowing holes. It's amazing how much easier the tug welds are to clean up. ImageUploadedByH.A.M.B.1424312746.948273.jpg
  14. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
  15. SoCal52Deluxe
    SoCal52Deluxe
    This is a cool thread, I'm diggin' the step-by-step progress. Subscribed!
  16. Devin
    Devin
    from Napa, CA
    Thanks guys!
  17. 60 Belair
    60 Belair
    Nice work, I just picked up a 54 has some of the same cancer, will be watching!
    Andy
  18. Devin
    Devin
    from Napa, CA
    It's pleasure and pain working on this rusty ****!
  19. Devin
    Devin
    from Napa, CA
    Got a little bit of garage time in today. I got the patch just beginning to be tacked in before I had to pick up the kiddos. The gaps will need a bit of tweeting before I go further. I spent a lot of time trying to planishing the panel. It's ok but I need to get better at this. ImageUploadedByH.A.M.B.1424927205.590681.jpg ImageUploadedByH.A.M.B.1424927230.821487.jpg ImageUploadedByH.A.M.B.1424927271.439086.jpg
  20. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    You're doing a great job. The key is to take your time. It's just like anything else, the more you do it the better you'll get. I'm at the same point with making my floorpans, it's taking forever but I'm learning as I go.
  21. kidn1980
    kidn1980
    what an inspiration i just got this 49 in my avatar and it is plain nothing what so ever ill keep in tune for sure.
  22. Rui
    Rui
    Subscribed.
    You're doin a great job and I admire you're one piece at a time approach capability. I'd probably be just staring at those rocker panels and going catatonic about how would I solve those out.
    Keep us posted.
    There's a lot of info and very helpfull people at allmetalshaping.com and I believe you'll get prompt answers on any question that might pop up regarding fab.
    Regards.
  23. Devin
    Devin
    from Napa, CA
    Thanks all! All metalshaping is an awesome resource, it's helped me understand some if the fundamentals of how metal behaves. I screw a lot if stuff up but that's how you learn. The one piece at a time approach is dictated by my work / family schedule. If I can get an afternoon of work in a week I'm lucky. The car sat in my garage for a year after I gutted it. It was overwhelming looking at it until I actually started to do something.
  24. Devin
    Devin
    from Napa, CA
    Got the patch welded in. ImageUploadedByH.A.M.B.1425429625.108248.jpg ImageUploadedByH.A.M.B.1425429640.773805.jpg
  25. Devin
    Devin
    from Napa, CA
    Then started working on the rear window surround. ImageUploadedByH.A.M.B.1425429691.923933.jpg ImageUploadedByH.A.M.B.1425429708.673495.jpg ImageUploadedByH.A.M.B.1425429719.540101.jpg
  26. Devin
    Devin
    from Napa, CA
    ImageUploadedByH.A.M.B.1425429750.324103.jpg ImageUploadedByH.A.M.B.1425429774.323816.jpg
    Made the flange by clamping against an 1/8" piece of plate and using a chisel and socket to cork it in. ImageUploadedByH.A.M.B.1425429831.323766.jpg ImageUploadedByH.A.M.B.1425429841.323837.jpg ImageUploadedByH.A.M.B.1425429850.407506.jpg ImageUploadedByH.A.M.B.1425429869.806899.jpg
  27. Devin
    Devin
    from Napa, CA
    End result: ImageUploadedByH.A.M.B.1425429916.174426.jpg ImageUploadedByH.A.M.B.1425429929.173600.jpg
  28. Devin
    Devin
    from Napa, CA
    Trim, bend, weld. ImageUploadedByH.A.M.B.1425430001.608053.jpg ImageUploadedByH.A.M.B.1425430019.190567.jpg
    I didn't attach it to the sail panel or belt line as I will eventually be cutting it free anyways when I chop it.
    52Poncho and vwdave30 like this.
  29. Devin
    Devin
    from Napa, CA
    Since u was already working on that area, I decided to cut the corner out of the quarter window in preparation for chopping. I took out 5" from the rear. ImageUploadedByH.A.M.B.1425430162.690710.jpg ImageUploadedByH.A.M.B.1425430175.823620.jpg
    Rui and vwdave30 like this.
  30. Rui
    Rui
    Weldon(e)!
