Projects 1950 Styleline coupe kustom build thread.
Discussion in 'Traditional Customs' started by Devin, Jan 14, 2015.
  1. Devin
    Devin
    from Napa, CA
    Does anyone have some suggestions on how to trim up the inner brace? I'm a bit stumped.
  2. 'Mo
    'Mo
  3. Devin
    Devin
    from Napa, CA
    Yeah that thread is the best. Maybe I missed how he did the inner structure. I'll have to go back and check it out again.
  4. Devin
    Devin
    from Napa, CA
    This deck lid was pretty rough so I figure I had little to lose. It's been hard finding definitive examples on how to go after the inner structure. I think I found a pretty simple sution. I'm not finished so we'll see how it goe but hopefully this can help someone in the future. I began by cutting the deck lid skin free 1.5" from the rear edge. ImageUploadedByH.A.M.B.1434085577.544636.jpg
    dlandberg likes this.
  5. Devin
    Devin
    from Napa, CA
    Then I marked off where to cut the reliefs on the inner structure. At first I wa going to cut the whole center section out an only leave the perimeter. I then decided to leave the rear section intact and cut a few reliefs so it could "hinge" down slightly. ImageUploadedByH.A.M.B.1434085804.025247.jpg ImageUploadedByH.A.M.B.1434085821.807770.jpg ImageUploadedByH.A.M.B.1434085839.174442.jpg ImageUploadedByH.A.M.B.1434085853.858195.jpg ImageUploadedByH.A.M.B.1434085879.307363.jpg ImageUploadedByH.A.M.B.1434086144.098129.jpg ImageUploadedByH.A.M.B.1434086159.632956.jpg
    50 customcoupe likes this.
  6. Devin
    Devin
    from Napa, CA
    Once the center wash pushed down enough to allow the skin to fit as well as it can the end of the cut sections overlap. The overlapped section will get trimmed off and the new ends will be **** welded together. This is pretty simple and straightforward and will hopefully look pretty stock once the welds are dressed. ImageUploadedByH.A.M.B.1434087302.258191.jpg
  7. Devin
    Devin
    from Napa, CA
    I had to stop, but I made a strip to fill in the section at the rear edge that was created when the skin was pulled down to meet the trailing edge. ImageUploadedByH.A.M.B.1434087416.955889.jpg
  8. Devin
    Devin
    from Napa, CA
    As you can see there will be only minimal pie cutting necessary. The fit is pretty good. There's about an inch to fill in on either side. If I were to do this again, I would only make the bottom cut of the pie cut and then push the skin down inside the outside edge, mark it off and the trim off the overlap. There would be much less filling and welding to do. I'm most happy though with the side profile. It definitely is sleeker but still has a subtle stockish appearance. I also like the fact that the profile pretty much matches the profile of the rear fender. ImageUploadedByH.A.M.B.1434087809.948187.jpg ImageUploadedByH.A.M.B.1434087832.880653.jpg ImageUploadedByH.A.M.B.1434087866.727604.jpg
  9. dlandberg
    dlandberg
    from Sweden
    Nice job with the lid! Looking good
  10. Devin
    Devin
    from Napa, CA
    Thanks! I cant wait to ****on it up and get it back on the car. I think the welding will be slow, the sheet metal really wants to warp so I need to be careful. Work is crazy so I'm not sure when I can bet back on it.
  11. Ratatouille
    Ratatouille
    from France
    Patience is the better part of valour......have fun, and congratulation for your work.
  12. Devin
    Devin
    from Napa, CA
    Snail's pace!!!
  13. Devin
    Devin
    from Napa, CA
  14. Devin
    Devin
    from Napa, CA
    Started filling in the gap and made some relief cuts to get the edges to meet up and blend the radius. Work has been crazy. Barely any time for this I was glad to get in some work this afternoon. ImageUploadedByH.A.M.B.1435545232.574887.jpg ImageUploadedByH.A.M.B.1435545271.972957.jpg ImageUploadedByH.A.M.B.1435545292.455698.jpg
    50 customcoupe and dlandberg like this.
  15. hacknwhack
    hacknwhack
    from mass
    Nice work.
    Reminds me of the battles i went through...
    No time or money just picking away at it.
    Keep going, before you know it you will be buffing that thing out!
  16. drdave
    drdave
    Man, Devin, nice work!! I am impressed and encouraged by your metal work. I have not yet begun fabricating my own panels, but you have given me a nudge to give it a shot. Looking forward to your progress. I wouldn't call it snail's pace....you are out pacing a whole lot of us out here. :)
  17. G V Gordon
    G V Gordon
    from Enid OK
    A perfect example of "less is more" A subtle thing that most won't pick up on when it's done but makes a huge difference in the overall look of the car. Nicely done.
  18. Devin
    Devin
    from Napa, CA
    Thanks gents!
  19. Devin
    Devin
    from Napa, CA
  20. 50 customcoupe
    50 customcoupe
    Devin, that trunk is really looking good, great work. Ray...
  21. Devin
    Devin
    from Napa, CA
    You haven't seen it up close then lol[emoji12] it's a bit warped and is going to require some filler but the overall appearance is an improvement I think. I just wish I had a solid block of time to get it done.
  22. Devin
    Devin
    from Napa, CA
    ImageUploadedByH.A.M.B.1437577374.864123.jpg the internal metal is pretty rough. I'm going to have to fab up some new bracing or search for a more solid deck lid and start fresh. Are coupe deck likes different from sedans? I see a couple deck lid for sale on Craigslist.
  23. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    I think you're singing our song with that one. If we all just had a good solid block of uninterrupted time to work on our cars, we'd be driving them instead of building them.
    cptn60 likes this.
  24. Devin
    Devin
    from Napa, CA
    Can I get an AMEN!
  25. Devin
    Devin
    from Napa, CA
    Cut out the pitted inner structure and replaced it with clean shiny metal. ImageUploadedByH.A.M.B.1437881989.925991.jpg
  26. Bruce A Lyke
    Bruce A Lyke
    Nice work on the replacement, once again you have demonstrated what can be done if needed to reclaim a rusted part.
  27. Devin
    Devin
    from Napa, CA
    Got some skin in the game now! ImageUploadedByH.A.M.B.1437936078.859701.jpg ImageUploadedByH.A.M.B.1437936091.192114.jpg ImageUploadedByH.A.M.B.1437936105.291393.jpg ImageUploadedByH.A.M.B.1437936119.391533.jpg
  28. dlandberg
    dlandberg
    from Sweden
    Great job on the lid!
  29. Buddy Palumbo
    Buddy Palumbo
    Nice progress . Keep pushing forward , even in little steps !
  30. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Devin: You make feel like a lazy *** old fool! I am going out to the shop and cut something up!!! with that said, GET BACK TO WORK AND POST SOME MORE UPDATES!!!!!!! lol great work as always Larry
