Technical 1950s GMC 270 oil line alternative
Discussion in 'The Hokey Ass Message Board' started by 1942g506, Jan 20, 2025.
  1. 1942g506
    1942g506
    Hello all, I currently have an early 50s 270 with an oil bath cleaner. I put the first line on and realized it had never been flared. I would really like to ditch these lines all together as what I read they are GMC specific and seem very hard to find. What are my options? Thanks
  2. Gofannon
    Gofannon
    If that is the same fitting as the hard lines on your engine, you need these fittings from Edelmann. Then you can just make a hard line.
    302GMC and jimmy six like this.
  3. tubman
    tubman
    That looks like a "Ford Nut" to me. Probably not the same.
  4. 1942g506
    1942g506
    Ahh, makes sense. So these are probably compression fittings? No flare needed?
  5. Gofannon
    Gofannon
    Yes, compression fitting for 3/16" line. Use steel.
  6. 1942g506
    1942g506
    Thanks so much!
    Gofannon likes this.
