Projects 1951 Chrysler New Yorker
Discussion in 'The Hokey Ass Message Board' started by Anthony hall, May 8, 2025.
  1. Sharpone
    Sharpone
    You gotta Hemi in that thing?
    One of the greatest questions in Hot Rod land!
    Dan
    VANDENPLAS and RodStRace like this.
  2. tubman
    tubman
    Yep. The E-Brake is on the transmission on these cars, which makes a different rear end (with provision for emergency brakes) almost mandatory.
  3. bobss396
    bobss396
    The e-brake is very essential to sort out on those cars. Parts are available, I used an old Motors Manual to do one around 1975.
    This was after it had caught fire on a friend's 1951 Dodge.
    chryslerfan55 and Sharpone like this.
  4. gene-koning
    gene-koning
    The E brake drum on the end of the transmission was the park position. The transmission was basically put in neutral, and the "park" lever on the push ****on console slid to lock. Then the e brake on the transmission was applied to the restrict movement of the driveshaft for parking.
  5. 57Fury440
    57Fury440
    The '51 transmissions were not push ****on. The Powerflyte did not come out for a few years yet.
  6. Anthony hall
    Anthony hall
    Thanks for the input everybody
  7. d2_willys
    d2_willys
    from Kansas
    Push ****on transmissions did not happen till 1956, and ones with parking brake lever came in 62 or 63.
  8. All that has been said above check all the basics , while only smoking a bit at idle then clearing up is fine , an engine with a road draft tube will always smoke a bit when not moving .
    a Hemi is a glorious engine , with the fluid drive trans makes for a fun driver , I had a 53 Windsor years ago and hands down in stock form drive absolutely fantastic , easily kept up with traffic , the drum brakes ( if adjusted correctly) stoped the car perfectly fine and the power steering worked great .
    a Hemi engine would not be cheap to rebuild , but in saying that all the externals , carb , tune up parts , gaskets seals etc are not to costly .
    An engine swap would involve a ton more then just “ the engine “ essentially a complete driveline swap with all the incidentals of mounts , brakets , cooling system , parking brake , wiring , hoses , trans , possible diff etc etc etc .
    when Chevy introduced the small block they made engine swaps easy , all the other car brands out their , not so much . Plus ….. pretty much nothing is cooler than a Hemi !!
    can’t believe no one’s said it yet , POST SOME PICS OF THIS GLORIOUS LAD YACHT!!:D:cool:
