Technical 1951 Ford radiator question
Discussion in 'Traditional Customs' started by Crenninger, Jan 16, 2023.
  1. Crenninger
    Crenninger
    So this radiator came with the 51 ford, i was told it is original to the vehicle BUT i never checked until i had to rebuilt. i went to install it and it sits to call plus about 1 1/2-2" off to mounting to the core support. any ideas what this goes to?
    Radiator core 21 1/2 inchs tall
    radiator core 19 1/2 inchs length
    mounting flange to mounting flange 23 1/4
    radiator hose inlet/outlet 1 1/2
    total lenth 29"
  2. Appears to be a 52-53 6 cylinder radiator.
    hemihotrod66 likes this.
  3. BJR
    BJR
    That radiator was never for a flathead, so Bangingoldtin may be correct.
  4. That fill neck is nothing Ford. In fact, I have never seen one like it.
  5. junkman8888
    junkman8888
    On the front of the upper radiator tank is some information stamped in the br***, maybe that will tell you what that radiator fits.
  6. Doctor Detroit
    Doctor Detroit
    Are you putting a Flathead into your '51 Ford, or something else? That radiator won't work with a Flathead. It needs two input ports and two output ports. Maybe the previous owner was planning on a SBF or something else.
  7. Replacement radiators list 49-53 as using the same one. 6 cylinder cars had the brackets positioned for the core to be in front of the support, V8 cars behind, hence my previous post. A couple of differences in your pics though- the brackets were wider on one side than the other (yours appear the same), and the ******s were 1.5"/1.75". The extended fill neck, as @Pist-n-Broke said, is not stock. Could have been something added so the cap would be above the bolt on air dam that goes above the support. What are the numbers on the top tank?
  8. Crenninger
    Crenninger
    These arw the numbers
  9. Crenninger
    Crenninger
  10. dwollam
    dwollam
    Doesn't look anything like the four 1951 radiators I have.
    Dave
  11. pgj
    pgj
    from aurora co.
  12. Crenninger
    Crenninger
    After much research, i have found out this radiator is for a Lincoln welder 200-250
    all specs are the same as mine. wish i would of done the research before spending money on rebuilding. owell live and learn
  13. Crenninger
    Crenninger
  14. Jalopy Joker
    Jalopy Joker
    my '51 had a '67 Mustang radiator - fit good.
