Just took delivery of this today. I have been wanting a highway cruiser for awhile now, this should fill the bill. Previous owner had lowered it but it's otherwise stock, I'm gonna have to get the *** end down a bit more, add a set of lakes, some chrome tip's and some Appletons and then start on converting to 12 volt. Future plans are to nose, deck, shave the door handles and some sort of custom paint on the top. Suggestions?
Marty... Tell me what it is that you're seeing that makes you say it's a '50 model and that the motor is '51 or newer. Thank you...
I agree. In the past, shaving the nose and deck would separate you from the m***es, but today, on a late model, that would just involve peeling the stickers off. Anymore, leaving this stuff on gives the car some cl***. Sent from my SM-T350 using The H.A.M.B. mobile app
IIRC, the "stand-up" taillight housings with the "88" on them were '50 only. Also, the two "feet" on the hood ornament were longer on a '49 than on a '50 and wend further forward on the hood. I wouldn't touch the body, either.
It's def a 50s delux. I have had 10 or 12 of them / The eng has later v/c and intake with carb.One of the best eng mods on a 49 51 is to replace the 1.5 rocker arms with the 52 up 1.8 rockers. Probably a 20 /25 hp increase.Huge seat of the pants feel.
Thanks to all for the input. The v.i.n. is 517M****0, which say's it's a 1951 and the Fisher body tag reads... Style 51-3769 Body L-8406 Trim 1A Paint 58 Anybody know how to decode? 48fordnut... Thanks for the rocker arm info, that's good to know. I want to also switch the carb to a 4 bbl so with the later rocker arms it ought to pep it up!
I have heard of 50 olds that were actually 51s look the same. I also thought some one just made a mistake. Yours looks authentic. Never saw one with the vin nos. Congratulations. Actual 51 88s had a larger body style. That would account for the v/c and intake ,carb system.
Again, thank you for the information. The car actually beat the ***le here, it should be here Monday and that will hopefully clear things up. Thankfully no money has changed hands yet!
A closer look reveals it's a 51 88A. The giveaway is the letters Oldsmobile on the hood are in an arc, and the 49-50's were flat below the world. They were built as 2 and 2 door sedans only, using up all of the leftover ch***is. Car looks great !
To use the 1.8 rockers, you must also get 1.8 rocker shaft stands. .I might have a 303 4 barrel intake & carb, but shipping would be pricey as they are heavy. The 303 intake will have the small ports to match your 303 heads. The 54-56 324 intake will bolt on, but the runners are much larger, so it would be best to open up the head ports, but then you need to pull the heads. You can try it as is, but you'd need 324 intake gaskets either way. >>>Edit, I think you may need a thin plate with 303 gaskets on the head side, then 324 gaskets on the intake side Not sure if I have spare 1.8 stands and rockers, but I can take a look if you can't find them local. .
'51 eh? Now that you mention it, I seem to remember something about this. My old man had a new '49 and '51 (as well as a '53, '55, '58, and '62) and the '51 sure didn't look like your car. The taillights and grille were different, and it seemed to be a bigger car.
The later 55 56 intake works good with the intake having a more modern carb. If you really want something out of a 49 51 303, mill the heads .125 use a shim j2 head gasket and use the 1.8 rockers .The stands must be shimmed .125 to make up the difference. I saw this in the 50 s in HRM/or carcraft. It really makes a change in the car without doing any thing drastic. Just my experience.
'51 88 A … all '51 parts in a '50 body. Yours should read Style 51-3769 D, or the stainless gravel shields were added later. Bought many for parts, was very unhappy to learn all the 3 speed stuff was for selector trans. Your '51 hydro has 1 advantage over the earlier - you can shift into reverse without stopping the drivetrain, helping rock out of snow or mud … Please reconsider adding more jewelry - the '49 '50 Olds doesn't need that stuff.
Brings back memories of the 51 I bought right out of high school in 79,can not remember if it was a 88A but it did have a comp*** where your clock is and a clock on the steering wheel that can bring good money these days. Got it from the original owner for 150.00 but it had never seen a garage.
HRM had the story on i.8 rocker arms. 15 HP. I have put 1.8 arms on 49-50 motors with the stock stands,but what do I know. FE Ford roller rockers on 371 Olds. I have a real nice set of 56-58 rockers for a $100.00.
A few years ago I bought a 1951 88 4 door like the OP's car. Oldsmobile continued to offer the 88 in 1951, as stated in above post, in the 2 and 4 dr sedan models only. The Super 88 was the new model for 1951 and offered a more complete lineup of body styles. The Super 88 was based on the GM 'B' body shared with Buick.
Dan thanks or the info on the magazine I not remember I do remember toting a head as a 16 y/o to get it milled 125. and the 371 shim gaskets. I walked with the head 1.5 miles . Left the head. walked back home and brought the other head ,picked the 1st one up, went home and installed it, then he routine all over again. I used a set of rockers off of a junk yard eng. The machinist , Jack Samples , East Lake auto parts B'ham Al told me to make some shims. .I did,then used a later intake with a large carb .It sure worked .Best mods for the buck I have ever done. If you can remember the month of the HRM I sure would like to get one or have the article. thanks, jim
