Technical 1952 Olds starter
Discussion in 'The Hokey Ass Message Board' started by FirstNation, Aug 24, 2025.
  1. FirstNation
    FirstNation
    My Olds Rocket 88 was converted to 12 volts at some point. The 6 volt starter has quit and is beyond repair. I'd like to replace it with a 12 volt starter.
    I need to know if any of the later years bolt up to the block the same as the '52, with the only difference being 12 volt. Thanks.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
  3. skooch
    skooch
    Number of flywheel teeth changed from 145 to 176 teeth in 54. Any starter from 49 to 53 will work. Consider having your starter rebuilt.
    FirstNation and Paul like this.
  4. 42merc
    42merc
    Use a 1953 Olds starter.
    Proper tooth count & is 12 volt. No problem.
  5. Paul
    Paul
    Editor
  6. FirstNation
    FirstNation
    Thank you all !!!
  7. vtwhead
    vtwhead
    that should be a starter with a GM number of 1107603
    FirstNation likes this.
  8. bobss396
    bobss396
    Find a good auto electric shop.
  9. FirstNation
    FirstNation
    Ordered and on the way- thanks !!
