Technical 1953 Chevy 6v Gen issues
Discussion in 'The Hokey Ass Message Board' started by Irongloves53, Apr 3, 2016.
  1. Hi,
    I need some help regarding my 1953 Chevy Bel-Air's 6v charging system. The issue is my charging system isn't working even after the following was performed:
    The generator was fully rebuilt with a NOS GM armature & a NOS Ace part# 319 field coils. New brush springs & brushes.
    A new BWD Voltage Regulator was installed as well.
    The wires from the Gen to the Voltage Reg were checked for continuity.
    The Gen was polarized thru the Reg and I even added a ground wire from the Reg to car frame to see if it made a difference.
    New Battery was installed as well, I feel like I'm chasing a ghost, where else should I be checking. Anyone's input would be most appreciated.
    -Victor
  2. Are you basing this on the ammeter reading or have you done an actual voltage check at the battery?
  3. 302GMC
    302GMC
    from Idaho
    First, momentarily jump between Bat. & Field terms on reg. while feeling the gen. pulley. If you can't feel it pulse, the fresh gen. doesn't work. Borrow a generator that works, & try again. New parts sold today for 6 volt systems are nowhere near the quality of the '60s - '70s Delco Remy parts. Seldom do we find D-R starters, generators, or regulators that can't be repaired by a good cleaning & lubing, filing points, turning armatures, etc. unless they're toasted.
    Truck64 likes this.
  4. Yes, the ammeter on the dash only indicates discharge whenever a light is turned on or a load applied. I did check voltages at several points including the battery while gently accelerating the engine.
