1952-59 Ford 1953 Customline Rear End Swap?
Discussion in 'Off Topic Hot Rods & Customs' started by rriehm, Oct 25, 2012.
  1. rriehm
    rriehm
    I saw some of the old discussions about rear end recommendations, but I didn't really find a case like mine.
    1953 Customline with a carbureted 5.0 (1990's era) and automatic. We got an engine mounting bracket kit from ButchsCoolStuff.com. It was less than $200 and worked great.
    I am worried that the original rear end (that has been leaking for a long time) won't stand up to the modern engine/HP. What do you recommend for a rear end replacement on a budget? We're keeping the drums on the front, so we're looking for drum brake rear end.
    I believe the backplate to backplate measurement is around 52".
    Any thoughts appreciated.
  2. leadsledjim
    leadsledjim
    from Iowa
    Thinking about doing a up grade to my 53 sometime. Have been looking into using a 8.8 Ford rear end. They come in either Drum or Disk. They are suppose to be lot of them out there in Junk Yards. Can be had cheap! They Say! I need to Check it out. Not sure what it takes to get one to fit either.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
