Projects '53 Mild Custom - Dads Hot Rod
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Jan 29, 2019.
  1. dwollam
    dwollam
    Sorry to hear this Oliver. Good on you for getting after it.
    Dave
    oliver westlund likes this.
  2. oliver westlund
    oliver westlund
    Looks familiar....
  3. oliver westlund
    oliver westlund
    We all have a ticking clock and having 3 little kids its too dang easy to get tunnel vision and let things fall by the wayside. Its a good wakeup call
    dwollam likes this.
  4. brEad
    brEad
    Hard to "like" this post. Praying for your dad and your family.
    oliver westlund and scotts52 like this.
  5. oliver westlund
    oliver westlund
    Wow, almost a year later... so dad has the c word, not horrible though. Hes getting treatment and while its taking a toll on him, he should be okay. Would you believe it? I had 2 more kids in a year!? So the trailer is empty and over at my folks and the 53 is about to finally get hauled over here to finish!
    scotts52, brEad, dwollam and 2 others like this.
  6. oliver westlund
    oliver westlund
    Okay, it has begun!
    1st I will pull the dash and paint and ***emble the best components I have as well as placing and routing the wiring harness
    Lone Star Mopar, Squablow and brEad like this.
  7. 53olds
    53olds
    Damn your about as bad as me haha how many projects are you doing at once??
    brEad and oliver westlund like this.
  8. oliver westlund
    oliver westlund
    Ummmm.... I have the custom roadster, I have my 30 model a roadster, I have dads 53 ford, I have my 33 dodge coupe, I have the model a roadster bits I was just given that Im putting together. I have a 37 chevy pickup, a 37 packard, a 66 charger to wrap up... a 56 merc wagon.... a 54 ford... thats...thats about it...maybe a few more here and there
  9. oliver westlund
    oliver westlund
    So I started thinking about it.. while its still warm out I am going to dive into body and paint first. I can wire the car in the winter but paint gets considerably harder to accomplish during the fall and winter months. That said I started by frenching the drivers side headlight. I had done the p*** side in the past but never finished 20240830_151824.jpg 20240830_151828.jpg
    Next goal is to finish stripping, primering and blocking the entire front end. Then I will work my way back
    scotts52, brEad and TrailerTrashToo like this.
  10. oliver westlund
    oliver westlund
    Okay, before I could put the front end in primer, I needed to figure out my grill. I love the 55 grill in a shoebox and so does dad but its a lot easier to fit one in a 54 than a 53...surgery was required to get it right and I am now in the process of patching and blending it all back together to look intentional.
    20240909_130735.jpg 20240909_124434.jpg 20240909_124349.jpg 20240909_131812.jpg
    guthriesmith, dwollam and brEad like this.
  11. oliver westlund
    oliver westlund
    Cut some cancer out today and wheeled up a patch. Gonna weld it in tomorrow...inch by inch. Will wire wheel and zero rust whatever I can get at before covering it up
    Horror Business, dwollam and brEad like this.
  12. oliver westlund
    oliver westlund
    Front ends just about prepped for primer
    brEad, dwollam, scotts52 and 2 others like this.
  13. oliver westlund
    oliver westlund
    Okay....huge change in this build and one I was on the fence about but am getting more and more excited about. My 1st car was a 1954 ford 4 door customline, 239 y block, 3 on the tree with overdrive. I still have it in fact. Its in primer, full of mice and has been sitting for 10-12 yrs. We have decided that the 54 isnt in very valuable condition. Instead of selling it for 800 bucks, we have decided to ch***is swap these 2 cars! The 53 custom coupe will go onto the 54 ch***is, it will get the overdrive trans a fresh clutch that was just installed in the 54 12 yrs ago and the 3x2 292 thats currently in the 53. This will also give the car ball joints! I will use the rear seat, dash and a handful of other bits as well
    brEad, scotts52 and 53olds like this.
  14. Double check the fit of the inner fender panels. Different cut outs for the suspension (kingpin vs. ball joints.). Also, not sure if 53/54 Ford is the same as Monarch here in Canada, but my 53 fenders wouldn't bolt onto 54 inners due to the rad support/inner fender panel mount design difference. I ended up modifying my 53 inners to clear the ball joint suspension.
  15. oliver westlund
    oliver westlund
    I think the only way to accomplish my goal is to use the 54 front end on the 53 body all on the 54 ch***is. This means unfrenching the headlights so I can reuse the rings or making new ones since in 54 they used pot metal. Big change but gonna be really neat. I will likely rob quite a bit from the 54
  16. oliver westlund
    oliver westlund
    Chuggin along again, yanked the engine for a rattle can rebuild. Also pulled the front clip and body mounts in preparation for the body swap 20250228_121538.jpg 20250228_121549.jpg
    SS327, dwollam, JeffB2 and 2 others like this.
  17. oliver westlund
    oliver westlund
    More progress! Also confirmed its a 59-60 292.
    20250302_100306.jpg 20250302_104131.jpg 20250302_130622.jpg 20250302_130630.jpg
    dwollam and The Chevy Pope like this.
  18. oliver westlund
    oliver westlund
    More... engines definitely a low mile rebuild! What a score with the intake and carbs for 700! 20250302_155033.jpg 20250302_161234.jpg
    brEad, Squablow, SS327 and 2 others like this.
  19. 53olds
    53olds
    Whatcha running for valve covers?
  20. oliver westlund
    oliver westlund
    Undecided... not that set, theyre dented up, I have an earlier non script set. I also have a nicer script set... wish I had some old finned ones but idk
  21. oliver westlund
    oliver westlund
    Chad adams AMBR car...
    Squablow likes this.
  22. 53olds
    53olds
    Gotcha. On my Y block I have just plain chrome ones but am gonna be taking them off soon..scored some Tbird ones at Albany swap, gotta have some holes filled first.
  23. oliver westlund
    oliver westlund
    I ended up ordering some chrome ones this mornin. Only 53 bucks for a brand new set! T bird ones are cool. I like the vertical finned ones speedway sells though. 300+ is too much though... Its cleaned up, need to look into powervalves and jets for the carbs before puttin em back on.
  24. JeffB2
    JeffB2
    from Phoenix,AZ
  25. oliver westlund
    oliver westlund
  26. oliver westlund
    oliver westlund
    Bit of inner rocker progress today! Made a video on it
    Here are the pics though for those of you who dont want to watch my incredibly entertaining and tediously edited short film...
    20250308_140231.jpg 20250308_141152.jpg 20250308_152126.jpg 20250308_152408.jpg 20250308_154916.jpg 20250308_161716.jpg
    Squablow and scotts52 like this.
  27. Squablow
    Squablow
    Looks like nice work. My 52 needed a bunch of inner rocker and floor support work but I had to work around an already nicely painted body, my 53 needs the same work. Must be common on these bodies.
  28. oliver westlund
    oliver westlund
    I think so, my buddy has one down at his shop, needs the same stuff, he said too much h***le. Honestly, not that hard as long as your careful about making sure the door still fits right
  29. oliver westlund
    oliver westlund
    Chrome rocker covers arrived!
  30. oliver westlund
    oliver westlund
    Thoughts? I have a favorite but Ive been enjoying folks thoughts on it!
    dwollam likes this.
