1952-59 Ford 1954 belt line trim
Discussion in 'Off Topic Hot Rods & Customs' started by subjectdelta, Mar 9, 2025.
  1. subjectdelta
    subjectdelta
    can anyone tell me how to remove the doors and and under rear window? thank you
  2. shortshift
    shortshift
    under rear window is bolted down inside trunk and under rear seat side panel..My door panel trim just popped off the clips with a little prying
    orangedog likes this.
  3. evintho
    evintho
    Like shortshift said^^^. Most of the rear window beltline trim is bolted in (crawl inside the trunk and look up to see). The long sections simply clip on. There's 4 or 5 clips to each side. Carefully pop the trim off. Pry it off from the top down. When installing, install from the bottom up.
    The door beltline trim just clips on. Same clips as the rear window trim. Pry from the top down.
    nosford and orangedog like this.
