Technical 1954 Chevy 235" - 12V starter
Discussion in 'The Hokey Ass Message Board' started by memphis66, Mar 13, 2024.
  1. memphis66
    memphis66
    from Italy
  2. 52HardTop
    52HardTop
    There is no need to change the original starter. It will be fine on 12 volts. My 235 and many others here, have been using the original 6 volt starter for years with no problems.
  3. poco
    poco
    from oklahoma
    Yes what 52 hard top said, yes use your original one
    vtx1800 and memphis66 like this.
  4. memphis66
    memphis66
    from Italy
    Thank you very much. So, I will go like this ! Thanks again. Alberto
    VANDENPLAS likes this.
  5. memphis66
    memphis66
    from Italy
    Thanks !
  6. Bob Lowry
    Bob Lowry
    Yep, going on 30 yrs. having done it that way. And, it really wakes up the 6v starter.
  7. Just don't keep cranking for more than a few seconds (you won't have to if your engine is running right). You can still cook a 6V starter on 12V, only if you crank for an excessive time.
    Bob Lowry and memphis66 like this.
  8. memphis66
    memphis66
    from Italy
    Thank you ! I'll go like this !
  9. memphis66
    memphis66
    from Italy
    Perfect, thanks !
    Bob Lowry likes this.
  10. Hotwyr
    Hotwyr
    6 volt and 12 take a different flywheel. 6 volt will work fine.
    memphis66 likes this.
  11. Use the 6v
    I slung one apart due to ignorance on my part.
  12. 302GMC
    302GMC
    from Idaho
    On a few cars, we used a '55-'56 solenoid on the 6v starter to slow drive engagement into the ring gear. These were cars that ate a ring gear for some reason. We suspected the driver(s) must have hit the ****on with engine running. The 12v solenoid made them feel better ...
  13. Mr48chev
    They have to have your rebuildable core or pay a stiff core charge but the Filling Station in Oregon does sell rebuilt to 12 volt starters. https://store.fillingstation.com/detail/R-3500-12/Chevrolet_193854_REBUILT_STARTER_12_VOLT.html
    54 used a 139 tooth ring gear.
    55 and up 235 cars used a 168 tooth ring gear plus the bolt pattern for trans to bellhousing changed to the "Muncie" pattern in 55 so swapping flywheels and bellhousings and keeping the trans and rear isn't going to work.
  14. flatheadpete
    flatheadpete
    from Burton, MI
    I've used 6v starters on 12v a few times. My old Ford 9N is 12v and still uses the original starter.
  15. hepme
    hepme
    Absolutely use the old one. The old 6V is wound much better than the 12V and will stand a higher load, plus the thing will spin the engine almost twice as fast resulting in shorter start times. I did one on a 235 that lasted for years, perfect when I sold the truck.
  16. memphis66
    memphis66
    from Italy
    Thanks everybody for the advices. I am goin' to keep my old 6V starter. Thanks once again and greetings from ol' Italy !
    302GMC likes this.
  17. Chio Cuggi !
    Per favore , posta qualche photo della tua macchina
    Grazie bello agure !
    Chi piacciono le photo delle v*****e auto !!
