1954 chevy chop top
Discussion in 'The Hokey Ass Message Board' started by Geach, Sep 9, 2010.
  1. Geach
    Geach
    I know there is a lot of info out there in the forums already about this subject BUT I was seeing if anyone could show me build pics of a 54 chevy chop while keeping the rear gl*** and belt line?
    Thanks
  2. Jalopy Joker
    Jalopy Joker
    no pics, but consider lowering the rear and front gl*** down into the body-use an open channel lined with rubber to protect edge of gl*** and help support gl***. you can have front chop area less than rear doing this as long as you plan out retaining stock angles for gl***-use stock rubber channel along sides and top of gl***-at lower edge along body use black silicon sealer along gl***. do a lot of research if this is your first time chopping.
  3. 49ratfink
    49ratfink
    welcome to the HAMB. there are plenty of threads here about chopping 54's. while one more won't hurt, you should use the search function and find the old ones too since when you speak with 10 guys who have done it you will get 10 different ways to achieve the look you want.
  4. dodgord
    dodgord
    im keen to see some too! i think there are too many chops done without it, i know its easier to replace the gl*** but surely there must be ways to keep the curved rear gl***, lets see them!
  5. The new re-pop back gl***es from china (I know, me too) are laminated and can be trimmed to fit the opening
