Technical 1954 chevy transmission
Discussion in 'The Hokey Ass Message Board' started by wbonebrake, Mar 6, 2021.
  1. wbonebrake
    wbonebrake
    Hello everyone! I recently bought a 54 chevy bel air, runs and drives. I heard a little bit of whining in the transmission, so I thought I'd check the oil in the gear box. It was super thick, as I'm sure is normal, but it had almost a grey color to it. Do you think the transmission is about shot? 20210306_130811.jpg
  2. Mr48chev
    Stick or automatic? A 3 speed stick takes 80/90 gear oil. Makes me wonder if someone hasn't used some sort of snake oil in that trans to quiet it down.
    wbonebrake likes this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I see air bubbles more than gray. The gray may mean trans has been sitting for sometime and condensation formed inside trans case and now has mixed in with gear lube.
    Budget36 likes this.
  4. 38Chevy454
    38Chevy454
    I think you just have condensation mixed with your gear oil. ***uming a 3 speed manual trans. Just dump out the old gear oil and refill with new 80/90 gear oil. Then a nice long drive to get things heated up and drive off any residual moisture.
    wbonebrake and Bob Lowry like this.
  5. Bob Lowry
    Bob Lowry
    Totally agree with 38Chevy454. Didn't see any br*** or metal sparkles so that's a good sign.
  6. KoolKat-57
    KoolKat-57
    from Dublin, OH
    I believe you should use GL-3 or4, a lot of the newer 80/90W is not for use in older transmissions.
    Just be careful and get the right oil!
    KK
  7. Rusty Heaps
    Rusty Heaps
    I use StaLube GL-4 in my older manual transmission cars.
  8. wbonebrake
    wbonebrake
    You're probably correct. I think the old car had sat around for quite a while before I bought it, so it's very likely the oil just has some condensation in it. Looks like I'll be changing the gear oil soon. Thanks for the advice! All I knew was that it didn't look right, and thought I'd see what some others thought about it
