COE 1954 coe ideas?
Discussion in 'Off Topic Hot Rods & Customs' started by Ace61, Dec 16, 2018.
Tags:
  1. Ace61
    Ace61
  2. Badmoonreizen
    Badmoonreizen
    from Howell, MI
    On my '56 Ford C600, I used a 2003 E350 ch***is. I am sure a GM van ch***is should work, just measure widths and track.
    Regards, Mark
  3. Ace61
    Ace61
    Did you use the stock engine location?
  4. I would find another medium duty ch***is if you want to update the running gear, or if you want to keep it more original (engine, trans, etc.) swap modern axles under the present ch***is. Thinking F450-F650 or the little Freightliner. Hopefully you can find something of the correct width.
    Edit Don't forget the modern coe box trucks Mitsu. Isuzu/GM etc.
  5. Ace61
    Ace61
    I measured a gmc C4500 and a fl70 freightliner and they were too wide. I'm thinking of going with independent front suspension and was told to look at rv's.
  6. I've seen guys take a front axle that is too wide and narrow it. I wouldn't suggest you do it unless you are a good welder or know someone that you can trust to do it right.
    If you want independent front suspension GM P-30 (bread truck) is probably the best bet.
  7. Ace61
    Ace61
    I looked at a bunch of frito lay chip step van trucks and they all had solid front axles tomorrow I'm going to look at some fedex step vans, still looking for an older rv to measure.
  8. vintage56
    vintage56
  9. Ace61
    Ace61
    Wow, did not even think about how hard it would be getting rid of a RV body, thanks!
  10. RMR&C
    RMR&C
    from NW Montana
    JOYFLEA and vintage56 like this.
  11. iwanaflattie
    iwanaflattie
    I have a 1979 c20 step van... Ifs and rides like a dream.. I can take measurements if u want
