1952-59 Ford 1954 Ford 302/c4 SWAP
Discussion in 'Off Topic Hot Rods & Customs' started by Screenz, Aug 18, 2010.
  1. Screenz
    Screenz
    from Texas city
    I'm getting around to putting my motor in my car, I started with a 94 HO 302 and a c4 trans. Bored it out 30 over put some flat top pistons in it new freeze plugs and all that.... I'm gonna try to put up as many pics as I can I know I'll have a ton of questions along the way. I ordered my intake roller rockers and pushrods yesterday plan on getting the heads this weekend (AFR)..... Thanks Jeff for emailing me that info a while back
  2. ctfortner
    ctfortner
    from West TN
    What intake you running? I just pulled a victor jr single plane off 302 (347 stroker) that I am going to sell, and just installed a new edelbrock air gap. Havent driven with the new air gap yet since I am recurving my distributor, but should give me better low end throttle. The AFR's should work great, I have canfield heads on mine.
  3. Screenz
    Screenz
    from Texas city
    Ya ct thats the same intake I ordered the air gap. Cant wait to check it out I feel guilty for taking out my 292 but I have a baby girl she has to go everywhere with me....I need the reliability and A/C down the line.
  4. ctfortner
    ctfortner
    from West TN
    Wish I had known I would have told you to order from streetsideauto, they are awesome and saved a lot of money on mine. I have a 10% off coupon code (code is SAVE) plus edelbrocks $25 rebate and then got a $25 visa card, free shipping, saved a bundle on my new intake :) At that point I couldnt afford not to get it.
    Either way be sure to send in for your rebate with edelbrock if you didnt already know about it
    http://www.streetsideauto.com/promotions/edelbrock-rpm-air-gap-manifolds.asp
  5. Screenz
    Screenz
    from Texas city
    Damn that's a deal! Can you get the endurashine also I'll have to check it out when I get to my home pc
  6. Retro Jim
    Retro Jim
    Damn , I really like that color on your 54 ! What color is it and who's paint ? You don't need to feel guilty about the 302 swap . I am doing the same thing to my 55 Ford and backing it up with a C4 also . I just wanted an engine that if something went wrong on the road I could get parts very easily to fix it . The Y blocks are great engines but the parts cost so much more and performance parts are pricey too .
    What cam are you going to be running ? In my 302 I am going to run a comp Thumper cam and I am using heavily modified 289 heads . I have a 1984 short block with flattops and using a performer intake but also have an old RPM intake too . I was thinking about looking for a single plain intake to use too . Going to get a Street Avenger to run on top . I did get a nice set of Tri-Y headers to use also . They will be easier to modify to fit in the 55 much easier than standard headers due to the steering box . Got a old pair of Smithys mufflers to run . Will be nice when done .
    If you need any help or advice with your rebuild , just send me a email and will be glad to help you out . The sbf engine is the main engine I rebuild the most for people . Great engine !
    Jim
  7. Screenz
    Screenz
    from Texas city
    Thanks! It's restoration shop paint (very cheap) with ppg clear. I picked up a f303 ford cam should sound pretty good plan is to have it all ready to install early oct.
  8. Retro Jim
    Retro Jim
    The F cam is a very good mid to upper range cam . I have used them before and you are going to like it a lot . Pull like crazy once you get to about 2500 rpms .
    Jim
  9. greensheads
    greensheads
    A while back I built a similar combo (AFR 165s) on a .030 289 , in a Sunbeam Tiger. It Really runs strong!! lots of torque for such a small engine. Of course your car is a bit heavier.
    What size of afrs did you get? with a 302 185s are the biggest you should get unless it is going to turn 7k.
  10. EchoOfGecko
    EchoOfGecko
    Looking forward to seeing your pics of the build, this is the same swap I'm planning to do and it'll be a great resource to have! :)
  11. Screenz
    Screenz
    from Texas city
    185's is what I'm thinking! CT!! Good call I canceled my order just in time and got the one from the site for 350! Saved 25 bucks plus still got the card and the rebate
  12. ctfortner
    ctfortner
    from West TN
    Good deal screenz, glad it wasnt too late. They shipped my intake same day, got it in 2 days and the $25 visa was in the mail the next day. Service! They also price match so I will be ordering any new parts from them
    Just in case I better mention this one to, MSD has rebates right now to, so if your going MSD for anything, buy MSD products between August 1 and September 30, 2010 and get $20 back for purchases between $200-$299, and $30 for spending $300 or more. Then add that to streetsideauto discount code and get your 10% off that to and free shipping.
  13. ctfortner
    ctfortner
    from West TN
  14. Retro Jim
    Retro Jim
    Todd , looks like I am going to be modifying my dual plane intake ! I also have a spare 1" carb spacer too !
    Thanks for the extra power !
    Must be nice to have a Dyno at your shop !
    Jim
  15. Kustomline54
    Kustomline54
    Hey screenz good luck on the swap. the more pics you put up the better :). ill be doing the same swap sometime in the near future. Always dig your car whenever i see it
  16. Screenz
    Screenz
    from Texas city
    Got the heads in! Getin ready to rock and roll sent the trans off to be rebuilt now I need to start dressing out the block. I use a ford bronco oil pan right? and a early 289 timing cover? with a early style water pump? I still have a lot of questions I just wanna try to get as much right the first time! THANKS EVERYONE!
  17. Screenz
    Screenz
    from Texas city
    Parts are slowly coming in just a little update coming soon....look out for this
  18. missysdad1
    missysdad1
    I don't care what you say, Scott, I'm painting my next car green! :p
  19. jasone
    jasone
    Screenz, love your ride man, that thing is the ***s. I installed a 302/C4 combo in my '54 Mainline and never looked back. I hear some sort of 90's t-bird motor mounts are suppossed to work with the stock 292 mounts. I was not so fortuante, the guy I bought my car from hacked the mounts up bad, had to go with a Speedway kit.
  20. Screenz
    Screenz
    from Texas city
    Should be stabbed this week wait on torque convert and some other misc parts need to get new valve covers the ones I bought didnt clear the roller rockers (shouldve known better) Thanks for checking it out jasone.
  21. EchoOfGecko
    EchoOfGecko
  22. JeffB2
    JeffB2
    from Phoenix,AZ
    There are spacers available for your valve covers.The ugly part is the cost, $130 at Jegs' or run this thru Google: M-6582-R302 or M-6582-E302P I have the early version of these that say Ford Motorsports no problem with clearance,that last part number is about the same as the spacers.
  23. Screenz
    Screenz
    from Texas city
    Thanks Jeff thats what I was thinking I like the ones I have now....it's cheaper to buy the spacers rather than send my covers back and get new ones blah blah blah Tomorrow's the day!
  24. Retro Jim
    Retro Jim
    Screenz , you are going to love those AFR heads . Built a 347 for a guy and he had a set . Damn they are really nice right out of the box . The only think that should be done was match port the intake & exhaust ports . But what ever you do , DON'T touch the inside of the chambers ! Those swirls in there are for a special flow . BTW that 347 in the Mustang was a real strong running car ! He did have 2.02 in his . still one of the best heads you can buy for a 302 engine !
    Let us know how it turns out .
    OH I really love the looks of that " Hood ornament" on the front of your car ! :D
    Jim
  25. Screenz
    Screenz
    from Texas city
  26. Screenz
    Screenz
    from Texas city
    I know this has taken way to long I was off sick for a week and other BS but just about got the bottom done gonna get the car off the lift this weekend and ****on up under the hood......Here is how we did the tri-y
  27. mr. h
    mr. h
    looks good, i would like to see some photos of the engine mounted in the car if you could
  28. JeffB2
    JeffB2
    from Phoenix,AZ
    I thought you got that fancy finned aluminum oil pan to match your valve covers I emailed you about,$49.95 was a killer deal!
  29. Retro Jim
    Retro Jim
    Do you have anymore pictures on how you did your exhaust using tri-y headers ? I am going to use the same headers too .
    Jim
  30. old lady's mad
    old lady's mad
    jeff is that not a finned pan in front of the bell housing?
