Projects 1954 Nash Ambassador
Discussion in 'The Hokey Ass Message Board' started by NolanRyanLady, Dec 28, 2022.
  1. NolanRyanLady
    NolanRyanLady
    Looking for some advice.. knowledge.. motivation.. not real sure right now
    I acquired a Solid 1954 Nash Amb***ador Super. 39k OG miles, 1 owner, clean ***le. Thing is.. SOLID and clean.
    Only problem is the motor is stuck-stuck. We've got the head off of it after some struggling. Cannot get the motor to turn over for nothin'. It's a LeMans Dual Jetfire engine.
    We've soaked the cylinders with anything and everything we could think of, ****** fluid, diesel, penetrating oil, vinegar, and marvel mystery oil. We've smacked the pistons with a wood block and hammer, We've used the big 'ol breaker bar to try to spin her over and still nothing. Can't believe how stuck she is.
    Does anyone know anything special or significant about these jetfire motors that we don't?
    We are fully tossing the idea around of calling 'er a boat anchor at this point and strapping on our fabricator pants and getting creative with puttin the whole car on a different frame and swapping to a regular 'ol small block. Since this car is a unibody car with a torque tube driveshaft, shock towers in the engine bay (making it a tight squeeze)...a motor swap seems it's going to take some work.
    Anyone done anything of this magnitude with a unibody Nash? If you have or haven't, what would you do?? 20221027_185541.jpg 20221120_130701.jpg 20221211_101812.jpg 20221210_133656.jpg Snapchat-267898421.jpg 20221028_173512.jpg 20221021_143716.jpg
  2. Mr48chev
    Why the hell would you even think about screwing up a pretty decent car with a ch***is swap? That doesn't make sense unless you were going custom ch***is from Art Morrison or another ch***is builder to build a high end show car out of it.
    I'm thinking that Nash and then AMC used that same basic six for years on end and if you can't get that one up to snuff I'd hunt down a bolt in replacement.
    This is one of those cars that the less you change the better chance you have of selling it and getting your money back when you get tired of it and move on. Sticking a different ch***is under it cuts the value to the people who whould actually be interested in it. I'm not a restorer by any means but this is one of those cars were the resale market is going to be for a pretty well original car.
    Torkwrench, 550Coupe, X38 and 6 others like this.
  3. NolanRyanLady
    NolanRyanLady
    Restoring and reselling isn't our bag. We are the get it running and drive the heck out of em type. We like the rusty/patina drivers.
    scrubby2009 and rockable like this.
  4. NolanRyanLady
    NolanRyanLady
    The 'drive em across the country and be able to stop anywhere for a part if need be reliability' type.
    rockable likes this.
  5. 49ratfink
    49ratfink
    well..you did what you could up top, now it is time to see what the bottom looks like. I say pull the motor. at the very least pull the pan and have a look see.
  6. 327Eric
    327Eric
    If it's that stuck, I would pull it and see what's up. A frame swap is a lot of work for little gain, if you just want to drive it, find a Chevy or ford inline six, and an open rear end. The car has no significant value, but is unique enough to try to keep as much original character as possible. Plenty of sixes out there that will be an improvement with readily available parts
  7. SS327
    SS327
    Have you tried putting it in gear and rocking it? Have you pulled the pan to make sure there isn’t a spun bearing?
    OahuEli likes this.
  8. SEAAIRE354
    SEAAIRE354
    Those cylinders don’t really look that bad. As others have said there may be something else going on in the bottom end. And I’m also with going with a more modern inline if that one isn’t salvageable.
    Cool car though.
  9. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Those pistons look dry as a bone.
    If you had any breaker juice in those cylinders, it wasn't much.
    Fill up those cylinders to the top of the block like you were filling up a pool with Marvel Mystery Oil and let them soak for a week or two.
    Then come back and try turning the crank pulley bolt from above with a breaker bar with the Mystery Oil still in the cylinders and see if she will pop.
    Don't use a block of wood and wack on the pistons.
    Is it a Automatic or Manual ?
    I can't tell from your interior pic you lounging in the back seat with a bull horn commanding directions to the hired help. o_O
    Or even better yet, with a buddy, get it up on a lift, if a automatic pull the trans cover ( if I remember there is is a cover) or the opening in the bottom of trans, or rear of the block and use a long bar on a fly wheel tooth and another guy with a cheater bar on the crank pulley bolt, and the both of you leverage pulling together. ( Just make sure you are trying to turn it in the same direction with leverage ) With those cylinders pooled with Marvell Mystery Oil and both of you pulling on the fly wheel and crank bolt at the same time I bet you get a 1/16" POP and that's all it takes to get it unfrozen. After that - alternate back and forth directions with both of you on the crank bolt and flywheel at the same time, until you get it moving completely turn round and round. By then you should be able to turn it with the crank bar.
    It may take you a few hours but both of you keep pulling back and forth and I bet it pops / unfrozen,
    Who gives a darn if the pistons push some MM Oil out, the more the better.
    That's your victory the Marvel Mystery Oil cup runneth over.
    PS- Don't even bother with a frame change unless you have nothing better to do, you are wealthy, don't work for a living and money doesn't matter.
  10. HEATHEN
    HEATHEN
    from SIDNEY, NY
    You've got nothing to lose by removing the engine from the car; it will give you a better oppurtunity to remove the pan and see what's what, and if it turns out to be total junk, you were going to have to remove it anyway.
  11. bobss396
    bobss396
    I'd go with what CCC suggests, it may take a while to let the juice creep down the cylinder walls. Keep the engine in the car, you'll get better leverage trying to spin it in a couple of weeks. I'm not sure how rare the pistons are, take care not to break them. But they may be junk anyway. Be on the lookout for another short block.
    IowaTom and hrm2k like this.
  12. hrm2k
    hrm2k
    A good friend of mine has an Avanti. Engine had been stuck for almost 20 years. We poured 2 gallons of WD40 down the carb. We tried to turn the crank with a socket and breaker bar for a couple of weeks. It finally broke loose. This was 7 years ago. He drives it almost everyday. We never even took the valve covers off.
    Listen to CornCobCoupe. He knows what he speaks of !!!!!!
    bobss396, IowaTom and 49ratfink like this.
  13. 51504bat
    51504bat
    IIRC others swear by Coke to free up a stuck engine. Or you can use the set it on fire method that CB SISSON on the Barn uses for freeing up stuck flatheads. This link isn't by GB but deals with using fire to free up a flathead.
    https://www.fordbarn.com/forum/showthread.php?t=61058
  14. squirrel
    Hmmm...I just got back from a 5000 mile trip around the country in a 6 cylinder 50s Rambler. So I probably don't know what I'm talking about....but....
    I would pull the engine out, and pull the pan off, start taking pistons out one at a time, carefully. When you get to the last one or two that are actually stuck, then you have to be really slow and patient. If you just can't get it out without damaging stuff, see if there are pistons available anywhere (nos or used or new). If not, you might be able to find a used engine somewhere. If not, then maybe an engine swap would be a good plan. But you might want to think a little out of the box, the Chevy small block is not the only engine in the world. Would a later AMC engine fit? How about a compact six from another carmaker? Length might be an issue though, the later more common engines like the Ford 200 had more main bearings and larger bores, so might not fit. But a newer four might fit and if it's new enough to not be hamb friendly, it might even make more power than the original six, and you could get parts for it.
    I got lucky, my 196 was not stuck, it just burned a lot of oil, so I was able to overhaul it for a couple hundred bucks, just replacing the rings and gaskets and lapping valves.
    Maybe you should just buy my rambler, it'll save you countless hours of work and frustration, if you are really just interested in driving an old Nashish thing around.
    bobss396, Los_Control, 302GMC and 4 others like this.
  15. sunbeam
    sunbeam
    One picture shows a clutch pedal
    hrm2k likes this.
  16. sunbeam
    sunbeam
    Pull it in high gear and pop the clutch.
    hrm2k likes this.
  17. hrm2k
    hrm2k
    good catch !!! I had to go look again and you are correct !!!!
  18. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Yep - I missed it.
    hrm2k likes this.
  19. das858
    das858
    Just for giggles unbolt the starter and move it away from the engine then try and turn it with your breaker bar. A friend of mine had a 6 cylinder Ford pickup that he thought was locked up , turned out the starter drive was stuck into the flywheel . I have seen this happen a couple of other times on GM cars also .
    lostmind, bobss396, Squablow and 4 others like this.
  20. guthriesmith
    guthriesmith
    This whole discussion reminds me that I need to go pull the plugs and soak down my 61 GMC 305 that is also stuck to see if I can get it broke loose. Thanks for the reminder. :D
    SS327, Squablow and hrm2k like this.
  21. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Don't just squirt a few squirts.
    Fill the cylinders up to the plug holes and forget about it for 2-3 weeks.
    Then come back (with open plug holes)with your breaker bar/socket on the crank pulley bolt and try tugging - break it loose.
    The whole idea is get those pistons to push the MM Oil Out out / as it rides up, the pistons hitting the soaked walls.
    Torkwrench, bobss396, Tman and 3 others like this.
  22. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    One more thing, instead of leaning over the car trying to pull a breaker bar, get it up on a lift high enough so you can reach up with the breaker bar/socket on the crank pulley bolt positioning it so you can literally pull with all your body weight
    ( feet off the floor) on the bar with socket on the crank pulley bolt. You can get more leverage that way - your total leverage weight than trying to pull on the bar standing up hanging over the front of the car.
    BUT - DO THIS.... put on or buy - wear some knee pads as if for any reason the socket slips and your hanging on the bar with the feet off the ground, if you fall on your knees , at least with the knee pads it won't hurt like a sonofa*****.
  23. guthriesmith
    guthriesmith
    Yep, I use my lift for everything like this anymore since it is so much easier than leaning over the fender doing it.
    SS327 likes this.
  24. hrm2k
    hrm2k
    And when it finally breaks loose, take the plugs out and spin it with the starter
    AND
    Do not be under the car when it spins. You will be covered in whatever you put into the engine to break it loose……….voice of experience…..I ended up wearing about a gallon and a half Of dirty WD40
    49ratfink likes this.
  25. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Don't listen to him :D....yea be underneath it, get WD40 or Marvel Mystery Oil all over you and after take pictures/ video of your oil messy success. Wear it with pride.
    A do***ented memory of a life time with your buddies.
    What fun !!!
    SS327, catdad49, 49ratfink and 2 others like this.
  26. sunbeam
    sunbeam
    How about use a braker bar from the bottom so you can use a floor jack to put pressure on the bar and walk away while the oil in the cylinders works.
    Stan Back, ClayMart and hrm2k like this.
  27. lippy
    lippy
    from Ks
    Is there any oil in the engine? May be an indicator of the condition. Maybe they ran it out of oil and seized it up? Lippy
  28. squirrel
    pretty surprising to read all these suggestions. Whenever I get a stuck engine, I just take it apart and fix it, saves a lot of time.
  29. wicarnut
    wicarnut
    I spent a lot of miles in my youth riding in 50's Nash cars, my Dad liked them, my older Sister had a Rambler American, I am a Wi. guy, lots of them here back in the day. I have seen a few of that vintage with swapped engines, if there's a will there's a way. They win the unique award. Good Luck and Have Fun.
  30. lippy
    lippy
    from Ks
    You can't do that Jim!!!!! That byp***es all the acetone/trans fluid-prybar/in frame dis***embly routine we all know and love.:D
    leon bee and squirrel like this.
