Technical 1955 Buick century
Discussion in 'The Hokey Ass Message Board' started by john compono, Mar 31, 2023.
  1. john compono
    john compono
    it seems when I'm driving the Buick, that the body has a slight shake or sway to it. any way to stabilize it and make it kinda more sturdy ? thanks for any help.
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    That's a rather vague description; what, exactly, does it do? If it wallows in the corners, that pretty much means that it's a '55 Buick. They were set up for a cushy ride, not handling.
    belair, 302GMC and 62rebel like this.
  3. texasred
    texasred
    from Houston
    Body mount bushing may be worn out or missing
    firstinsteele likes this.
  4. BJR
    BJR
    Check the bushings in the rear panhard bar.
  5. john compono
    john compono
    in the rear I just put new knee shocks, shock links and springs. front end was done by previous owner and is tight. maybe could be body mount bushing suggested by texasred or maybe I'll check the bushings in the rear lanyard bar suggested by BJR. and to mr heathen you pretty much described what it is. wallowing in the corners is what I kind of feel but I also feel it in other area's underneath. I'll check the suggestions from everybody. car does ride nice except for the little issues. thanks for all the help guys.
    Just Gary likes this.
  6. 62rebel
    62rebel
    A shaking sensation could also be coming from the torque tube if the inner bearing is worn (probably the biggest reason I dislike torque tube driveshafts)
  7. john compono
    john compono
    62rebel good suggestion. never thought of the torque tube bearing. definitely will look into that with all the other suggestions. thanks.
  8. What inner bearing?
    Ben
  9. Bird man
    Bird man
    from Milwaukee
    '56 & 57 Buicks used a slightly larger front sway bar, this would be an upgrade. Tires & alignment might be contributors?
    And of course the loose nut behind the wheel!
  10. nosnhojguy
    nosnhojguy
    Slightly bent wheels will give you a wallowing feeling
  11. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    I know from experience that a disconnected or inoperative rear shock on one side can make one of these cars wallow something awful. Check your new shocks to make sure they have the proper amount of fluid and if you have adjusting screws make sure they are set stiff enough and both set the same. I have had 2 that wallowed enough to make you sea sick. Both had a broken link on one side.
    SS327 likes this.
