1955 ford rear end compared to 57-59
Discussion in 'The Hokey Ass Message Board' started by A Rodder, Jul 22, 2010.
  1. ramblin dan
    ramblin dan
  2. patsurf
    patsurf
  3. jimmy six
    jimmy six
    Funny, the listing for Fords doesn’t start with the 1949-1956 the first of Fords “modern era”.
  4. jimmy six
    jimmy six
    Not the early Monte Carlo 1970-1977…
  5. Andrew Samson
    Andrew Samson
    from Minnesota
    It's in a 1955 Ford customline. Just trying to identify it so I can fix it or replace it.
  6. Andrew Samson
    Andrew Samson
    from Minnesota
    Is there a certain year that would bolt up to a 55 Ford customline?
  7. Andrew Samson
    Andrew Samson
    from Minnesota
    What's this rear end on?
  8. gimpyshotrods
    gimpyshotrods
    No.
    The brackets will need to be cut off, and fresh perches welded on.
    Andrew Samson likes this.
  9. miker98038
    miker98038
    It’s time to bite the bullet and fit a more modern rear end. I’ve dealt with the Dana’s (my bird has a 44, probably out of a truck, not the usual 42 mentioned above years ago). Even if you could find one, you’ll regret it. Unless you’re making a lot of power and side stepping the clutch, the 8.8 will live just fine.
  10. gimpyshotrods
    gimpyshotrods
    It will be fine, even with big power.
    I have build numerous 4x4 rigs with 10.44:1 transfer case gears.
    3.83:1 first gear x 10.44:1 transfer case gear, through 4.88:1 rear gears puts 300lb-ft of torque from the engine to the axle as 58,538.3328lb-ft, split between the front and rear, or 29,269.1664lb-ft., each.
    miker98038 likes this.
