Projects 1955 Gasser Build
Discussion in 'The Hokey Ass Message Board' started by jsxtreme, Apr 11, 2025.
  1. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Some older cars, a few, had 4-link style suspensions. Technology advancements are often not embraced early on. It sometimes takes a while for the advantages of various improvements in ch***is science to be seen. So today, here we are.
    Carry on...
    jsxtreme likes this.
  2. jsxtreme
    jsxtreme
    from Michigan
    Well, the motor is together, mostly. Just need to get the starter in and then we're going to break it in on the stand.
    My throttle bodies on my carbs look to be no good. I got them used, there's cracks in them, screws broken off, ect. So I am buying new ones and then the tunnel ram will go on at a later date.
    But man, those headers sure are cool!
  3. jsxtreme
    jsxtreme
    from Michigan
    Before we discovered the carb problem.
  4. AmishMike
    AmishMike
    I do not see a cooling system on your engine stand. Really need one to break in an engine. You should run it at least 20 minutes, vary rpm to properly break in cam & rings
    bobss396 likes this.
  5. jsxtreme
    jsxtreme
    from Michigan
    Yes, it will of course have cooling. Water temp will be monitored.
    catdad49 likes this.
  6. jsxtreme
    jsxtreme
    from Michigan
    Good luck little buddy!
    I should have the ch***is done this weekend and the body back on. Plan is to go to paint the 22nd.
  7. jsxtreme
    jsxtreme
    from Michigan
    Pretty exciting day. Finally called the ch***is "done" and put the body back on. Dragging it to the paint shop a week from today. I need to get the steering column in it.
    Couldn't be happier with the stance. Front end will come down a bit with the motor and trans in it. Rear end has room to adjust up. So I'm sure I will mess with it some.
  8. jsxtreme
    jsxtreme
    from Michigan
    Lets talk wheels. I'm going to roll around on the rallys for a little while, but I'd like to swap out the fronts. I don't really want to run the fake spindle mounts, but man they do look cool in my opinion.
    Leaning towards a 5 spoke of some kind, but I'm torn because I do have slotted and drilled rotors.... Not period correct but a hell of a lot safer. The rally's hide those pretty well.
    seb fontana and Tickety Boo like this.
  9. swade41
    swade41
    from Buffalo,NY
    I'm not a fan of rally except on certain 4x4 pickups/blazers with some big mudders.
  10. Dave G in Gansevoort
    from Upstate NY
    Put Moon discs on and no one will know…
  11. DDDenny
    Anything but those faux spindle mount wheels!
  12. Tickety Boo
    Tickety Boo
    from Wisconsin
    Cragars or grey Touq Thrust ;)
  13. Hollywood-East
    Hollywood-East
    Stock steelies, before fuax spindles..
  14. jsxtreme
    jsxtreme
    from Michigan
    I was kicking around the idea yesterday of stock steelies with dog dishes. I like that look on lowered cars, not sure about a g***er. I will have to mess around with photoshop.
    Loud and clear on the faux spindles. I'm leaning towards a 5 spoke up front and stock steelies out back, just black.
  15. 66 caprice
    66 caprice
    Cragars!!!
    Tickety Boo likes this.
  16. anothercarguy
    anothercarguy
    How 'bout chrome steelies...think American Grafitti '55.
  17. jsxtreme
    jsxtreme
    from Michigan
    That's a great idea, I really like that. I'm sure I'll have two or three sets by the time I'm done.
    benchseat4speed and Tickety Boo like this.
  18. DDDenny
    I like dog dish hubcaps (on the right car), for a "street" g***er, no so much, besides, hubcaps were one of the first things to be removed on the real thing back in the day.
  19. Hollywood-East
    Hollywood-East
    Ok... out in left field.. A wheel i hated as a kid, Chrome slot skinny's with steelies out back,chrome lugnuts, B(.)(.)B's..
    rod1 and jsxtreme like this.
  20. swade41
    swade41
    from Buffalo,NY
    If you raised your back up it could be close to this hamber owned 57
  21. seb fontana
    seb fontana
    from ct
    I don't think that the parallel 4 bar will work. In my case I got wheel hop with my soft street tires; severe enough to break axles. I fixed the problem before I went to slicks. Take it easy on first tests..
  22. seb fontana
    seb fontana
    from ct
    Why?
  23. swade41
    swade41
    from Buffalo,NY
    More of a g***er look
  24. jsxtreme
    jsxtreme
    from Michigan
    Well that is concerning to hear.
    Tony from "stay tuned" runs this 4 link in his NASCAR powered '55 that he takes to all the drag and drives and it works well. He did bend one of the mounting brackets for the coil overs, but the car hooks well.
    Noted though. I wont be able to beat on it hard with this rear end anyways, and Im only making ~400 HP. (maybe)
  25. jsxtreme
    jsxtreme
    from Michigan
    Thats one cool thing about the 4 link - adjustability. In the photo I posted its at its lowest setting - I did that so I could measure tire clearance. But it can come up 3" total.
  26. 1971BB427
    1971BB427
    from Oregon
    My personal choice is American Torq Thrust TTO's. They have the old school look of the 60's, and can be purchased as cast finish, or dark spokes. I chose as cast for my g***er.
    55Belairman, SS327, rod1 and 8 others like this.
  27. Tons of drag race and street cars run parallel 4 links. I think shock choice and spring rate and bar adjustment can correct most issues.
    @seb fontana what did you fix to correct wheel hop?
    SS327, Tickety Boo and jsxtreme like this.
  28. swade41
    swade41
    from Buffalo,NY
    Just Gary, seb fontana and loudbang like this.
  29. seb fontana
    seb fontana
    from ct
    The OP has no adjustment for top bar angle like in above #19 post. I started out with parallel bars and had the wheel hop. Lucky I made the brackets with lots of adjustment holes, put angle in top bar like above and fixed issue. ""Tons of drag race and street cars run parallel 4 links. I think shock choice and spring rate and bar adjustment can correct most issues"". Once you adjust the bars they are no longer parallel; are they?o_O
    saltflats likes this.
