1956/2012 : A hot rod then / A hot rod again
Discussion in 'The Hokey Ass Message Board' started by Flop, May 20, 2012.
  1. Flop
    Flop
    thanks ooltewah!!
    thanks draider
    skaterman i doubt pittsburgh has anything on hawaii!!
    nz i may end up doing some body work and primer on this one
    well the panel above the decklid needs some work... looks like at one time someone had some 47 chevy style hinges on it and changed it to a decklid instead of a rumble . boy that really stretched it to hell!
    brasssssssss my enemy!
  2. bgbdlinc
    bgbdlinc
    .... a great detailed post. Thanks for taking the time to show how it SHOULD be done...
  3. teejay99
    teejay99
    Amazing work ...feel like I've just "gone to school " . Apparently you CAN make chicken salad out of chicken shit . ;)
    T
  4. Jimbacca
    Jimbacca
    Great thread. Love seeing projects being brought back to life. Beautiful work so far.
  5. hammered30
    hammered30
    from west aus
    Thanks for posting the pictures. your work is first class
  6. Flop
    Flop
    thanks bgb.
    it takes some work teejay but this was a very nice car to begin with .
    thanks Jim.
    no prob hammered thanks!!
    this panel was really really really stretched from the decklid hinges being bolted to it
    really dont want to think of how many shrinks are in it
  7. Mucho talent-o dude, diggin this transformation big time. ~sololobo~
  8. what holds the body panels to the subframe members?
  9. Flop
    Flop
    rivets at the firewall. spot welds under the cowl . the panel simply wraps at the lower quarters . rivets, wrap and a few spot welds on the wheel wells . the quarter corner has a spot weld as well .
    thanks sololobo
  10. Do you use one of those shrinking disks or just an O/A Torch to shrink??
  11. Flop
    Flop
    flt blk. i was using a stud gun to shrink .
  12. so you just put the stud on to add heat, then cut it back off?
    Next time I'm Pitt to visit my Brother in law I need to stop by.
  13. Flop
    Flop
    they have a shrinking tip you can buy for em ! i like it no need to mess with torches having someone else around to hold the torch while you hammer on the red spot etc
    messed with the gaps on the drivers door tonight and got it fitting pretty well
    then i decided to tack in the handmade patch i made for the drivers side.
    back at it tomorrow!
  14. 117harv
    117harv
  15. Outstanding work Flop!! Makes me wanna work on my junk,of course after a hour I would want to beat the hell out of it with a hammer.
  16. Been there done that 6 years ago!! Good work it looks nice
  17. Flop
    Flop
    thanks 117 1
    thanks firepower .this car got hit with a hammer for the past 6 hours hahah
    thanks fuzzy
    half way through welding the quarter in
    and from the back
    finished up the panel then burned some lead out of the bead
    getting back into shape one panel at a time!!
  18. TexasSpeed
    TexasSpeed
    from Texas
    Very nice work as always. Quick business question..
    How do you determine what you work on every day? You've got several Model As and that scooter you post pictures of but you're a one-man shop. Just curious as to how you decide that..
  19. Flop
    Flop
    Thanks Matt ! I have a certain number of hours per week into each project so eveything progresses nicely .
    put the triangle braces in this morning
    green lines are stress cracks .
    i welded them after the braces were in just incase the weld penetration prevented the pieces from sitting together nicely
    a little tig work
    i cannot get over the fit of this panel !
    uncovering some old work
    some old lead i dug out
    does anyone have the measurement for the holes that go in the belt line behind the door?
  20. Flop
    Flop
    cut out the big hunk of brass
    and filled in the hole with some sheetmetal
    the top was pretty rough where they shaved the reveal where the tab comes through for the top
    so i made up a new piece
    after some welding and filing i am pretty pleased with it
  21. general gow
    general gow
    MODERATOR
    smooth man! so no top this time either?
  22. Flop
    Flop
    thanks General! I still have to make the reveal for the tab to come through . todays mission actually .
  23. Flop
    Flop
    well this is how i made the reveal for the top tab
    really nothing fancy and reallly close to looking stock
    cut it put it in the vice to straighten it out and tacked it together
    after it was tigged in
    alot of work in this little area to get it back to looking right
  24. tinmann
    tinmann
    An excellent step by step how-to by a talented metal worker.
  25. tjmercury
    tjmercury
    Lookng great, awesome metal work!
  26. general gow
    general gow
    MODERATOR
    super trick, and simple. love it.
  27. koolkemp
    koolkemp
    Wow Flop I cant beleive the fit and finish of this car!! I am sure it's better than when it was new! Thanks for taking us along for the ride! I gotta try and get a TIG someday !!
  28. captainjunk#2
    captainjunk#2
    wow making something out of really rough parts , good job , mad patience
  29. Flop
    Flop
    thanks tinmann!
    thanks tj
    its always easy to over complicate things general gow
    no prob koolkemp! thanks alot! tig helps out a ton in my book with easy of grinding and how much hammering it can take
    thanks captain !!
    wheel wells
    old rot
    a little shrinker work has a new panel made up in no time
    gonna finish the welding up today and put the break on the bottom !
  30. Lucky77
    Lucky77
    Really nice work! I've got a pile of 30-31 roadster parts I'm working on, thanks for the step by step.
