1956 chevy gasser build
Discussion in 'The Hokey Ass Message Board' started by Uncledirty616, Apr 28, 2012.
  1. Uncledirty616
    Uncledirty616
    And then to my horror realize that even tho i drained the block , it must have had some water still in. Once i got the motor pulled i noticed a freeze plug was popped. I don't have photos, i think i was to shaken. I'm hoping for the first time in recorded history freeze plugs do their job and i don't have a cracked block. Update will follow.
  2. GOATROPER02
    GOATROPER02
    from OHIO
    They are not really freeze plugs......core plugs for when the block is cast
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    To quote Carly Simon......"I'm no prophet, I don't know natures way". Anticipation
  4. black 62
    black 62
    from arkansas
    had a 318 mopar freeze and pop out 2 plugs, replaced them with the bolt in rubber ones---never had a problem...
  5. 58 pro ford
    58 pro ford
    I like the radius job on the rear wheel well
  6. Uncledirty616
    Uncledirty616
    Yeah, i know, just whining aloud lol
  7. GOATROPER02
    GOATROPER02
    from OHIO
    Don't blame you ....... Id be hopeful as well.....
  8. Uncledirty616
    Uncledirty616
    Great news! The block is NOT cracked, pulled out the old cam today and put in the new one. I currently only have Wednesday available to work on the car at the moment, so it will be a week for update. I did however order my clutch and bell housing, and they both should be here hopefully before next Wednesday. More to follow.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Good to hear :cool:
  10. II FUNNY
    II FUNNY
    Did you pull the whole motor apart? I plan on pulling mine this weekend. I hope I'm as lucky as you. If not I sure am going to learn an expensive lesson.
    Meltdown Drags July 18,19,20 2014
  11. Uncledirty616
    Uncledirty616
    No we were gonna pressure test it, but I talked to an old timer with a little more knowledge and experiences, he says the cracks should be visible, they crack on the outside, not the inside.
  12. II FUNNY
    II FUNNY
    Oh good. I'm still pulling mine out just in case.:D
  13. Uncledirty616
    Uncledirty616
    It was christmas today, got parts![​IMG]
  14. Uncledirty616
    Uncledirty616
    Ram clutch set up[​IMG]
  15. Uncledirty616
    Uncledirty616
    Had to test fit the clutch disk, i was certain something wouldnt be right with this mess (Mopar Trans/chevy engine) photo bomb by the wife[​IMG]
  16. Uncledirty616
    Uncledirty616
    i got my fingers crossed for ya!
  17. 1971BB427
    1971BB427
    from Oregon
    You may have already done this previously, but if not this is a good video explanation on setting up a Lakewood bellhousing to ensure it's centered properly. They are often out a little and can give big headaches if not dialed in.
    http://www.youtube.com/watch?v=rzc2tmFKUhI
  18. Uncledirty616
    Uncledirty616
    Thank you for the post, I will check it out, I didn't realize them being centered was that critical. Better to learn that now then when it's in the car lol
  19. VERY GOOD ADVICE!
    If you have any questions about how to do or correct this, shoot me a PM. I have done so much of this I can do it in my sleep.
    Make sure you get it right so you don't screw up that crash box's input shaft!
    See ya at Byron!
    AJ
  20. Uncledirty616
    Uncledirty616
    Dialed in my bellhousing today, we are within spec. Next week hope to attach the trans to the motor and drop it in the car.
  21. Another good idea (but seldom recommended) is to do a crankshaft endplay check before and after. Before the trans is installed to see what the crank endplay actually is, and then after its installed to confirm it is not preloading anything. The effects could wipe out the thrust main if severe enough.
  22. Uncledirty616
    Uncledirty616
    A little update on whats goin on with the car[​IMG]
  23. Uncledirty616
    Uncledirty616
    With the trans connected and in the car[​IMG]
  24. Uncledirty616
    Uncledirty616
    We have shifter!!!![​IMG]
  25. Uncledirty616
    Uncledirty616
    Engine is re***embled and back in the car also[​IMG]
  26. enloe
    enloe
    from east , tn.
  27. Can't wait to see how she runs with a gearbox when you got her all sorted out. Your gonna have a permanent smile tattooed on your face. Nothing like "rowing a shifter & sawing the wheel" at the same time.
  28. Joel:
    GO MAN GO!!!!!
  29. Uncledirty616
    Uncledirty616
    Started work on the framework for the front clip, should be a little lighter this time around. (The previous one was all steel)[​IMG]
  30. Uncledirty616
    Uncledirty616
    Trial fitting the front clip. Its nice to see the car as a 56 finally.
