1956 chevy gasser build
Discussion in 'The Hokey Ass Message Board' started by Uncledirty616, Apr 28, 2012.
  1. Uncledirty616
    Uncledirty616
    back on all 4s , with the dana narrowed up (correctly, my measurements were right lol) and widening the wheel tubs
  2. Uncledirty616
    Uncledirty616
    starting to look like a race car =)
  3. Ive got a 56 and the front cap parts where rough. And there hard to find in my area. So I put a 55 front cap on it. It kinda grew on me . I like it better that way. Im really digging this build thread. Old Wolf
  4. Uncledirty616
    Uncledirty616
    Thank you Wolf. Kevin , the motor is a .030 over 454 , stock crank , eagle rods, JE 12.5 pistons, with my 107 cc combustion chamber 840 casting rectangular port heads.Its got a custom ground comp .714 lift roller in it, Victor Jr intake and i havent got a carb yet, but probably a 950 holley hp. The trany is a reverse manual valve body turbo 375(yes you read that correct) that has been worked over, and the guy guarantees it up to 1000 hp. We have a Dana 60 narrowed up running a spool with 4.10 gear. My only big regret is not getting a damn transbrake, next year i guess. With all that said, im really hoping to put her in the mid 10s.
  5. Uncledirty616
    Uncledirty616
    Cut the old cross member out, so we can move the motor back
  6. Uncledirty616
    Uncledirty616
    have the new tail pan installed, and started some of the rust repair, while waiting on the p***enger side rocker to show up.
  7. Uncledirty616
    Uncledirty616
    Got the new floor tacked in, waiting on p***enger rocker for final welding. [​IMG]
  8. rd martin
    rd martin
    from indiana
    im a dam ****er for a 56! lookin good guys!
  9. Slideways
    Slideways
    from Maryland
    Nice work.....instead of trans brake....can i suggest a " 3rd pedal" ?
  10. ol55
    ol55
    from Virginia
    With the '55 clip everybody WILL look at least twice!Have only seen a couple like that but I remember them...( was it a '56 clip on a '55 or a ...)
    Subscribed...
  11. derbydad276
    derbydad276
  12. Butch M
    Butch M
    Wow that bad boy is coming right along look'n good........
  13. Uncledirty616
    Uncledirty616
    @ derbydad276, this really bums me out, this was my super secret squirrel idea, me and the guy helping me build the car came up with. I thought we were on to something totally new. Oh well, at least now i know it will work lol
  14. Uncledirty616
    Uncledirty616
    from a one of my posts earlier.
  15. Snegrah
    Snegrah
    from Pacifica
  16. 55chieftain
    55chieftain
    Nice, are you making it down to the Meltdown Drags this year?
  17. Uncledirty616
    Uncledirty616
    Yessir!! I couldnt make it this past year, but i will this year come hell or high water!
  18. II FUNNY
    II FUNNY
    Yeah you have to make it to the Meltdown Drags and, before you buy a carb go check out pro systems just Google them. They are hands down the best carbs out there and they are almost exactly the same price as a mail order Holley only without the guess work.
    They guarantee to be within a jet size and each carb is built to your exact combination.
    Sent from my DROID device using the TJJ mobile app
  19. 1971BB427
    1971BB427
    from Oregon
    That might stop spring bind, but it will still bind when the axle travels vetically. The rear is solid to the axle, so the front will move straight up also, and that will try to compress the shackle up front. They should have mounted the shackle at a 45 degree angle, not straight up.
  20. Uncledirty616
    Uncledirty616
    Im doing mine from the other direction also, i am mounting the shackle below the front ladder bar mount.
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That makes better sense. I was going to comment about the video but just figured I'd sit it out till someone said something. The clips version had me thinking that if the shackle angle wasn't right, things could get worse than better. Not to mention a violent unspringing if you had to back pedal all of a sudden.
  22. Uncledirty616
    Uncledirty616
    So i messaged pro systems, the carb they are building sounds pretty bad ***, gonna be a 1000 cfm 4150 using dominator metering blocks, he said typically i should see a 25 to 35 hp advantage over a stock 4150, and the price is just like you said, same if not cheaper then summit. thanks for the heads up.
  23. II FUNNY
    II FUNNY
    No problem. You won't regret the carb or the "Meltdown Drags".
  24. Uncledirty616
    Uncledirty616
    In tonight's turgid episode we look at the ramifications of a big block in a Chevy Bel Air, or "Does this big block make me look fat?"
  25. Uncledirty616
    Uncledirty616
    Oh yeah! That is nice!
  26. Uncledirty616
    Uncledirty616
    Since we are in there already, may as well move it back a little.
  27. Uncledirty616
    Uncledirty616
    got the dog house in today
  28. Uncledirty616
    Uncledirty616
    looks like we should have plenty of clearance even with the engine set back.
  29. Uncledirty616
    Uncledirty616
    and we started the wheel tubs
  30. Uncledirty616
    Uncledirty616
    Picked up some fenderwell headers today, they will have to prolly be modified to fit since they came from a blazer, but at least its a starting point, i think we are gonna step them anyway, so this should work nice.
