Projects 1956 Customline
Discussion in 'Traditional Customs' started by Auslander, May 10, 2017.
  1. finn
    finn
    I didn't read all the posts, but in post 69 it looks like you're using an infrared heat gun to measure surface temperature of the exterior of the engine and a resistor to "tune" the aftermarket dash gauge to the IR reading.
    The coolant temperature will always be much warmer than the reading on the outside of the engine structures , so your gage is reading low with the resistor.
    To check calibration, stick the sending unit in a pot of boiling water. You can heat it with a torch. It'll read 212 degrees unless you live at high al***ude, where it will be a little lower.
    motion guru and Auslander like this.
  2. Auslander
    Auslander
    from Austin, TX
    Ended up using the Cl***ic Auto Air system. I liked the fact that it's cable driven and uses the original heat controls. Not to mention, it's an all in one heat/defrost/ac system.
  3. Auslander
    Auslander
    from Austin, TX
    Well, so far so good. She held a vacuum in the system, charged up well, and I don't see coolant all over, or pouring out of the heater core. And I'm showing a ~40ºF drop from the outside temp...
    mgtstumpy, Hunter73 and loudbang like this.
  4. Gman0046
    Gman0046
    Tri 5 two door post cars Ford or Chevy Rule.
    mikhett, loudbang and Auslander like this.
  5. Auslander
    Auslander
    from Austin, TX
    Finally off to get some seats installed...
    OahuEli, mgtstumpy, TomT and 2 others like this.
  6. Auslander
    Auslander
    from Austin, TX
    Wow, so car has been at upholstery shop for 3 months. Didn't realize it had been that long. It's been a challenge, finding a color match, and working with a car that had NO interior to start with. I'm slowly getting it all sorted out, here's where I am currently...
    20170912_131214.jpg 20170913_115107.jpg 20170913_120227.jpg 20170913_120238.jpg 20170831_135711.jpg
    OahuEli, Austinrod, loudbang and 2 others like this.
  7. jailbar joe
    jailbar joe
    looking very cool...luv the 56....got a 56 victoria myself
    Auslander and loudbang like this.
  8. Peanut 1959
    Peanut 1959
  9. Rocky
    Rocky
    Classified Editor
    I love these cars. I regret selling my 55 a few years back converted to 12 volts, running a 272/3 speed. Great cars.
    I had one in 66 too, right after graduation from high school...another 272, 3 speed with o.d. 55fordin66.jpg 55ford4.JPG
  10. Auslander
    Auslander
    from Austin, TX
    Back window back in; had to come out for the headliner. Gotta love it when you have a wife that not only supports our crazy habit, but also helps. She manned the paracord inside the car while I persuaded the window in...
  11. Bleach
    Bleach
    Very nice upholstery. I thought the tudors had more legroom in the back. I can sit OK in the back seat of my more door even with the front seat all the way back and I'm 6'-2.
  12. Auslander
    Auslander
    from Austin, TX
    Seats were just placed at this point. I've got the front seat bolted in now, and I've got like 6"inches between seats. The rear bench although sourced from a 2 door, seems like it must be from a 4 door, it doesn't quite fit. So there could be more room. I'll have to figure out a solution there...
    Bomb and loudbang like this.
  13. Bleach
    Bleach
    I tried checking the part numbers for the rear seat in the CD parts book that one of our members sells. Unfortunately even though the books cover up to 1959, the rear seats were no longer supplied by then, already obsolete.
    I have a couple of 1956 actual parts books that I can flip through sometime to see if what the part numbers are.
    Auslander likes this.
  14. Yeah, the rounded corners on the seat bottom identifies it as a 4-dr seat. The 2-dr seats have square corners.
  15. Bleach
    Bleach
    Yep, my rear seat has rounded corners.
  16. Auslander
    Auslander
    from Austin, TX
    Thanks! Great info!
  17. Auslander
    Auslander
    from Austin, TX
    Austinrod and loudbang like this.
  18. Auslander
    Auslander
    from Austin, TX
    Doing a little representing for the 50s Fords...
  19. loudbang
    Looks great :)
    MMM1693 and Auslander like this.
  20. Auslander
    Auslander
    from Austin, TX
    Some updates. Sourced a proper 2 door back seat and got it reupholstered. Replaced the ratty wheels with new Bullitt 17s and new rubber, and tidied up the interior and and added a made in the good ol ' USA Auto Meter Moon Tach...
    OahuEli, loudbang and Finn Jensen like this.
  21. MMM1693
    MMM1693
    You did a great job! Take this over a tri5 chevy!
  22. Auslander
    Auslander
    from Austin, TX
    Alright, alright, alright; at Top Notch after LSRU #17. What a cool journey...
  23. mikhett
    mikhett
    from jackson nj
    Nice,! I've got a 56 Vicky under construction! Check my profile for pics.Good luck.
