1952-59 Ford 1956 Mercury Monterey Engine Question
Discussion in 'Off Topic Hot Rods & Customs' started by Sgt. John, May 18, 2023.
  1. Sgt. John
    Sgt. John
    from Virginia
    Good Morning I have a question. Good friend gave me a 351m Engine and Transmission it has good compression and has low miles and was rebuilt..The accessories are on it.Im going to change the Durospark **** and go with the HEI..
    BIG QUESTION IS DO THEY HAVE A MOTOR MOUNT TO USE IN THE MERC AND What about Space not running Headers..Thanks Not a 390 IT A 351M 20230515_084636.jpg Screenshot_20230517_101402_Gallery.jpg ...
  2. knucklenutz
    knucklenutz
    I have a 351M in my 56 Monterey Wagon. Stock front motor works fine. Driver side stock exhaust manifold is a tight fit. The p.o. cut a notch ( and welded ) in the rear to clearance the steering box. P1050389 2.JPG P1050392.JPG
    JeffB2 likes this.
  3. Sgt. John
    Sgt. John
    from Virginia
    Okay Thanks ..What did you do for linkages and how does the 351M perform..Thanks
  4. knucklenutz
    knucklenutz
    The 351M is a DOG ! ( rated at 155 hp ) I totally re-did the motor. Edelbrock RPM Aluminum heads, roller rockers, r.oller cam, Airgap Performer intake manifold. Headers will be installed this winter. Running a Lentech AOD in place of the C6. Lokar throttle and shift linkages
    JeffB2 likes this.
  5. Paul2748
    Paul2748
    I had a 351M in a 76 wagon - it was a pig
  6. Sgt. John
    Sgt. John
    from Virginia
    Thanks again
  7. Sgt. John
    Sgt. John
    from Virginia
    I wished I had known about this ford mess...I might have to go with it..I'm just going to Cruise with it and a little highway driving
  8. Mark T
    Mark T
    These engines aren’t that hard to wake up, a 4 barrel intake and carburetor and a set of headers are easy to bolt on. A camshaft change will also do wonders but is a little more involved.
  9. Sgt. John
    Sgt. John
    from Virginia
  10. Sgt. John
    Sgt. John
    from Virginia
    I understand that..I just sold my ProStreet Cutl*** and I'm done with high performance..I just want to have a Cruiser
  11. jimmy six
    jimmy six
    I’ll bet if you advanced the cam 6* you would not believe it’s the same engine. This era retarded the cams for emissions.
    JeffB2 likes this.
  12. Sgt. John
    Sgt. John
    from Virginia
    Okay Thanks for that information
  13. Fairlane 62
    Fairlane 62
    Their not bad engines. Just a bit heavy and Unfortunately they were hampered by having to comply with the new emissions requirements of the seventies. Their basically a tall deck Cleveland with low compression and retarded timing but they powered millions of Ford trucks and the larger Ford/Mercury/Lincoln cars of the era.
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    The distributors were also retarded to match, back then a swap to a Mallory or Accel would really wake these smog motors up along with an advanced timing set.
    ffr1222k likes this.
  15. Sgt. John
    Sgt. John
    from Virginia
    Thanks
