1952-59 Ford 1956 Mercury project update 1
Discussion in 'Off Topic Hot Rods & Customs' started by tcoupekyle, Jul 10, 2023.
  1. 56longroof
    56longroof
  2. Dos Cincos
    Dos Cincos
  3. tcoupekyle
    tcoupekyle
    IMG_0467.jpeg IMG_0466.jpeg Got some trim kinda half on, my neighbor made a door trim for the p***enger side out of a handful of other 4dr trim since I don’t have that doors trim. Looks pretty good for a patch job.
    bobss396 and down-the-road like this.
  4. tcoupekyle
    tcoupekyle
    thank you guys alot and thanks to this board for answering all my dumb questions.
  5. tcoupekyle
    tcoupekyle
    After a bit of sanding and buffing. I’m not an expert, anyone got advice? obviously I think it needs more
  6. tcoupekyle
    tcoupekyle
    72040711784__C8850EC3-DEF0-4EA1-8B55-2627E4253B77.jpeg I think I have learned something through trial and error.
    bobss396 likes this.
  7. 56longroof
    56longroof
  8. tcoupekyle
    tcoupekyle
    @Texas57 you mentioned non hardening sealant? What do you use? For that
  9. tcoupekyle
    tcoupekyle
    Thanks! I got plenty more buffing to do and need to inspect what I have done in the day light but Its getting where I want it.
    56longroof likes this.
  10. orangedog
    orangedog
    Looking nice. You have come a long way in just a few months.
    tcoupekyle likes this.
  11. Texas57
    Texas57
    3M caulking strips. It's a rope-like caulking, about 1/4" in diameter, 10" or so long. comes in a box with wax paper between the layers of strips. Your paint supply shop should have it. Heads up: make sure the box you get wasn't crushed.
  12. tcoupekyle
    tcoupekyle
    thank you both!!
  13. tcoupekyle
    tcoupekyle
    Bumper and some trim is on, skirts came in too
    Texas57, bobss396 and Dos Cincos like this.
  14. Rustvelle SS
    Rustvelle SS
    Looks great! Nice work!
  15. tcoupekyle
    tcoupekyle
    Thank you sir!
  16. tcoupekyle
    tcoupekyle
  17. the-stig
    the-stig
    Looking better every day!
    Dos Cincos and tcoupekyle like this.
  18. tcoupekyle
    tcoupekyle
  19. tcoupekyle
    tcoupekyle
    Trims on, skirts on, lights work, and I think it’s about done needs a bath and little things and more buffing, but it won’t look much different until I can put together enough money to lower it more and some other things like electric wipers and so forth.
    thanks alot to this group.
  20. Texas57
    Texas57
    Man you work fast! Looking really really good. I noted you found the ****erfly clips.
    ffr1222k and Dos Cincos like this.
  21. tcoupekyle
    tcoupekyle
    Thanks man! Yeah they were a pain but I like they they hold the trim tight.
    I had to use 2 factory clips on the fender trim and 2 on the under headlight trim but luckily the originals were ok and luckily I had exactly enough of them.
    drove it today, to get exhaust but they quoted me too much money in my opinion so we rode around a bit have a little trouble with it over heating but I think cheap Chinese fan and radiator are the culprit.
    ffr1222k, jimmy six and Dos Cincos like this.
  22. tcoupekyle
    tcoupekyle
  23. tcoupekyle
    tcoupekyle
    IMG_0687.jpeg 72333075431__0EAF31EC-D72B-4A51-9C96-76E029AF232F.jpeg image000000.jpeg IMG_0675.jpeg So I did a little wet sanding and buffing on the car and that made it look allot better.
    I bought an 8” rearend with a 3.00 gear to be rid of the Dana 45 and 4.x gear.
    So little more progress.
  24. ffr1222k
    ffr1222k
    Looks great! You really did a lot in a short time on that car.
    Texas57 likes this.
  25. tcoupekyle
    tcoupekyle
    Thanks! I still got to finish the rear end swap and ac. I would like to put disc brakes as well but those items will come as money is available
  26. jimmy six
    jimmy six
    If your radiator has 2 rows it should be fine. Just make sure coolant moves thru it at idle as that’s the problem with YBlocks. A fan shroud really helps and I’ve made them from circle track kits from Summit. With less room I’ve used 1” aluminum cookie sheets against the radiator and cut a hole for the fan. A ring of aluminum added for depth or mounting an electric fan in my race car.
    I don’t know if the Merc had them but Fords also used a panel above the radiator and its mount to seal to the hood forcing all the air thru the grille into the radiator, that really helps.
    It’s fun following your build.
  27. orangedog
    orangedog
    When you get to your rear end swap can you post a picture of your third member. I'm trying to figure out what mine is. I have it out now getting it ready to replace the bearings.
  28. tcoupekyle
    tcoupekyle
    Sure can but mines a Dana 45 and loads from the back
  29. tcoupekyle
    tcoupekyle
    thanks alot Jimmy, I have a 302 in this car and one thing I noticed is that radiator flow is very low at idle however, I’m idling at 500rpm raise to 700 and there’s flow. With the new spal fan I can’t get it to run hotter. It runs at 140 now so I’m changing the fan switch when I get back in the garage.
  30. orangedog
    orangedog
    Thanks tcoupekyle that's what I was wondering.
