1952-59 Ford 1956 mercury project
Discussion in 'Off Topic Hot Rods & Customs' started by tcoupekyle, Jul 9, 2023.
  1. tcoupekyle
    tcoupekyle
    Finally got the 56 Mercury home.
    The previous owner put a 4.6 Ford in it so we pulled that out. And started the preliminary cleaning.
    I noticed the bolt pattern on the wheels seems to be 4 3/4 anybody ever seen this Chevy pattern on these cars?
  2. tcoupekyle
    tcoupekyle
  3. Mark T
    Mark T
    Your bolt pattern should 5 x 5 unless it’s been changed.
  4. tcoupekyle
    tcoupekyle
    That’s what I thought then I measured this morning and it measures 4 3/4. It doesn’t look changed but anything is possible I suppose
  5. Paul2748
    Paul2748
    How did you measure them - you do not get a correct reading if you measure one to the next on a five bolt pattern.
    An easy way to measure is to measure the distance from the center of the spindle (or axle) to the center of one lug, then double it.
  6. Texas57
    Texas57
    You pulled the 4.6???????? What do you know about it? Mileage? year? Pics? sohc or dohc? Was ****** with it?
  7. tcoupekyle
    tcoupekyle
    An easy way to measure is to measure the distance from the center of the spindle (or axle) to the center of one lug, then double it.[/QUOTE]
    I did not know this.
  8. tcoupekyle
    tcoupekyle
    Yeah it was just an empty block and heads and empty trans to make the motor mounts.
    But yeah I pulled it out. You can have it and the transmission if you want.
  9. Texas57
    Texas57
    Thanks for the offer, but no need for that. I'm just keeping my eyes out for a low mileage 93-95 dohc just in case I ever wear mine out. When I set mine up, I used a plastic mock-up block and empty ****** case........saves a lot of wear and tear on the back.
    I love '56 Merc 2dr htps, btw! Didn't those originally have that door trim up by the window, or was that an option?
  10. tcoupekyle
    tcoupekyle
    I think that was an option. This one is a medalist so it’s not very fancy like the Montclair.
  11. tcoupekyle
    tcoupekyle
    Checked it and you’re right, 5 on 5. Never knew that thanks!
